Re: Gear leg aft strut
David Stroud
Gear leg aft strut
Post by David Stroud »
'I finally got the fuselage home from the airport yesterday and with the fabric off,
I'm very pleased with the condition of the fuselage. The right wing is toast as
predicted though. The rear spar is broken right thru pretty much vertically in the
area of the strut attach fitting but the front spar is completely smashed thru in
the area just outside it's strut attach fitting. No one could figure how this damage
could have taken place as the D cell leading edge is pretty much intact. I've got
a spare rear spar and material to make the front spar is waiting 200 miles away.
A full set of new ribs came with the deal and the left wing is still covered and in
"as last flown" condition" which I suspect will be ok. The fabric all over is in real
good condition but will get redone with the rebuild anyway.
From time to time I see F-24's with an extra landing gear strut running from the
wheel area up to the fuselage in the step area. Is this a fix of some sort to prevent
the gear "swinging aft" in a rough field situation or is it just a stardard fitting on
some models? Anyone add these their plane? Thanks
David Stroud Ottawa, Canada
C-FDWS Christavia
Fairchild 24 in restoration
John Berendt
Post by John Berendt »
'David The aux.strut is a modification not a requirement in the states.
Contact the club we have the information on this.
John berendt
Fairchild club----- Original Message -----
Sent: Sunday, December 18, 2005 8:39 AM
Subject: [fairchildclub] Gear leg aft strut
fabric off,
toast as
vertically in the
thru in
this damage
I've got
away.
covered and in
is in real
from the
to prevent
stardard fitting on
> C-FDWS Christavia
Karl Saenger
Post by Karl Saenger »
'David,
You are right about the reasons for the additional gear strut. It
takes a lot of load off from the bolts attaching the gear leg to the
fuselage frame.
The mod was (still is) compulsory for Swiss registered F-24's.
There are several ways to do the mod. The Fairchild Club has the
details.
Best regards
Karl Saenger
UC-61K #891 HB-ERO
--- In fairchildclub@yahoogroups.com, "david stroud"
wing is toast as
vertically in the
smashed thru in
intact. I've got
200 miles away.
all over is in real
running from the
stardard fitting on
> C-FDWS Christavia
