'Hi BuellIts been a while!Take Jamie's advice, flush with Denatured Alcohol then use the Dot 5. Did you install Cleveland system or sticking to the Hayes brakes?Jim  C.
     On Monday, November 25, 2013 6:37 PM, Jamie Treat  wrote:
                                        Flush the entire system with Denatured Alcohol.  JST
On Behalf Of wsknettl@centurytel.net
Sent: Monday, November 25, 2013 4:38 PM
Subject: [fairchildclub] RE: Brake Fluid    Hello Buell,  The three fluids are very different and are not compatible with each other. Their systems are not cleaned and flushed with the same chemicals/fluids. I would suggest you do a little investigating on the traits and properties of each fluid type and make your own educated decision on which to use. Keep in mind that commonality is often the safest choice.   Review these sites before making a final choice:
Different Types Of Brake FluidDifference Between Dot3 and Dot4 Brake Fluid | Difference BetweenBrake_Fluid_Tech.pdf (application/pdf Object)DOT 3, DOT 4, and DOT 5 « Jim’s GarageBrake Fluid Facts  Wes KIA in Wisconsin
---In
fairchildclub@yahoogroups.com,  wrote:            Finally re-building the master cylinders on my 1946 F24. I believe they are the same as for a 1937 Plymouth. I found a note in my records to use Dot 5 fluid--can someone let me know if this is correct and what would be best to clean the cylinder bore and flush the lines.            Thanks.            Buell Powell-1946 F24R
-- BHP                            #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 #ygrps-yiv-333245792yiv1182430412 --   #ygrps-yiv-333245792yiv1182430412ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;}  #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 #ygrps-yiv-333245792yiv1182430412ygrp-mkp hr { border:1px solid #d8d8d8;}  #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 #ygrps-yiv-333245792yiv1182430412ygrp-mkp #ygrps-yiv-333245792yiv1182430412hd { color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;}  #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 #ygrps-yiv-333245792yiv1182430412ygrp-mkp #ygrps-yiv-333245792yiv1182430412ads { margin-bottom:10px;}  #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 #ygrps-yiv-333245792yiv1182430412ygrp-mkp .ygrps-yiv-333245792yiv1182430412ad { padding:0 0;}  #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 #ygrps-yiv-333245792yiv1182430412ygrp-mkp .ygrps-yiv-333245792yiv1182430412ad p { margin:0;}  #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 #ygrps-yiv-333245792yiv1182430412ygrp-mkp .ygrps-yiv-333245792yiv1182430412ad a { color:#0000ff;text-decoration:none;} #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 #ygrps-yiv-333245792yiv1182430412ygrp-sponsor #ygrps-yiv-333245792yiv1182430412ygrp-lc { font-family:Arial;}  #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 #ygrps-yiv-333245792yiv1182430412ygrp-sponsor #ygrps-yiv-333245792yiv1182430412ygrp-lc #ygrps-yiv-333245792yiv1182430412hd { margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;}  #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 #ygrps-yiv-333245792yiv1182430412ygrp-sponsor #ygrps-yiv-333245792yiv1182430412ygrp-lc .ygrps-yiv-333245792yiv1182430412ad { margin-bottom:10px;padding:0 0;}  #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 #ygrps-yiv-333245792yiv1182430412actions { font-family:Verdana;font-size:11px;padding:10px 0;}  #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 #ygrps-yiv-333245792yiv1182430412activity { background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;}  #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 #ygrps-yiv-333245792yiv1182430412activity span { font-weight:700;}  #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 #ygrps-yiv-333245792yiv1182430412activity span:first-child { text-transform:uppercase;}  #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 #ygrps-yiv-333245792yiv1182430412activity span a { color:#5085b6;text-decoration:none;}  #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 #ygrps-yiv-333245792yiv1182430412activity span span { color:#ff7900;}  #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 #ygrps-yiv-333245792yiv1182430412activity span .ygrps-yiv-333245792yiv1182430412underline { text-decoration:underline;}  #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 .ygrps-yiv-333245792yiv1182430412attach { clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;}  #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 .ygrps-yiv-333245792yiv1182430412attach div a { text-decoration:none;}  #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 .ygrps-yiv-333245792yiv1182430412attach img { border:none;padding-right:5px;}  #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 .ygrps-yiv-333245792yiv1182430412attach label { display:block;margin-bottom:5px;}  #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 .ygrps-yiv-333245792yiv1182430412attach label a { text-decoration:none;}  #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 blockquote { margin:0 0 0 4px;}  #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 .ygrps-yiv-333245792yiv1182430412bold { font-family:Arial;font-size:13px;font-weight:700;}  #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 .ygrps-yiv-333245792yiv1182430412bold a { text-decoration:none;}  #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 dd.ygrps-yiv-333245792yiv1182430412last p a { font-family:Verdana;font-weight:700;}  #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 dd.ygrps-yiv-333245792yiv1182430412last p span { margin-right:10px;font-family:Verdana;font-weight:700;}  #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 dd.ygrps-yiv-333245792yiv1182430412last p span.ygrps-yiv-333245792yiv1182430412yshortcuts { margin-right:0;}  #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 div.ygrps-yiv-333245792yiv1182430412attach-table div div a { text-decoration:none;}  #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 div.ygrps-yiv-333245792yiv1182430412attach-table { width:400px;}  #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 div.ygrps-yiv-333245792yiv1182430412file-title a, #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 div.ygrps-yiv-333245792yiv1182430412file-title a:active, #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 div.ygrps-yiv-333245792yiv1182430412file-title a:hover, #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 div.ygrps-yiv-333245792yiv1182430412file-title a:visited { text-decoration:none;}  #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 div.ygrps-yiv-333245792yiv1182430412photo-title a, #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 div.ygrps-yiv-333245792yiv1182430412photo-title a:active, #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 div.ygrps-yiv-333245792yiv1182430412photo-title a:hover, #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 div.ygrps-yiv-333245792yiv1182430412photo-title a:visited { text-decoration:none;}  #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 div#ygrps-yiv-333245792yiv1182430412ygrp-mlmsg #ygrps-yiv-333245792yiv1182430412ygrp-msg p a span.ygrps-yiv-333245792yiv1182430412yshortcuts { font-family:Verdana;font-size:10px;font-weight:normal;}  #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 .ygrps-yiv-333245792yiv1182430412green { color:#628c2a;}  #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 .ygrps-yiv-333245792yiv1182430412MsoNormal { margin:0 0 0 0;}  #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 o { font-size:0;}  #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 #ygrps-yiv-333245792yiv1182430412photos div { float:left;width:72px;}  #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 #ygrps-yiv-333245792yiv1182430412photos div div { border:1px solid #666666;height:62px;overflow:hidden;width:62px;}  #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 #ygrps-yiv-333245792yiv1182430412photos div label { color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;}  #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 #ygrps-yiv-333245792yiv1182430412reco-category { font-size:77%;}  #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 #ygrps-yiv-333245792yiv1182430412reco-desc { font-size:77%;}  #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 .ygrps-yiv-333245792yiv1182430412replbq { margin:4px;}  #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 #ygrps-yiv-333245792yiv1182430412ygrp-actbar div a:first-child { margin-right:2px;padding-right:5px;}  #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 #ygrps-yiv-333245792yiv1182430412ygrp-mlmsg { font-size:13px;font-family:Arial, helvetica, clean, sans-serif;}  #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 #ygrps-yiv-333245792yiv1182430412ygrp-mlmsg table { font-size:inherit;font:100%;}  #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 #ygrps-yiv-333245792yiv1182430412ygrp-mlmsg select, #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 input, #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 textarea { font:99% Arial, Helvetica, clean, sans-serif;}  #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 #ygrps-yiv-333245792yiv1182430412ygrp-mlmsg pre, #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 code { font:115% monospace;}  #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 #ygrps-yiv-333245792yiv1182430412ygrp-mlmsg * { line-height:1.22em;}  #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 #ygrps-yiv-333245792yiv1182430412ygrp-mlmsg #ygrps-yiv-333245792yiv1182430412logo { padding-bottom:10px;}   #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 #ygrps-yiv-333245792yiv1182430412ygrp-msg p a { font-family:Verdana;}  #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 #ygrps-yiv-333245792yiv1182430412ygrp-msg p#ygrps-yiv-333245792yiv1182430412attach-count span { color:#1E66AE;font-weight:700;}  #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 #ygrps-yiv-333245792yiv1182430412ygrp-reco #ygrps-yiv-333245792yiv1182430412reco-head { color:#ff7900;font-weight:700;}  #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 #ygrps-yiv-333245792yiv1182430412ygrp-reco { margin-bottom:20px;padding:0px;}  #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 #ygrps-yiv-333245792yiv1182430412ygrp-sponsor #ygrps-yiv-333245792yiv1182430412ov li a { font-size:130%;text-decoration:none;}  #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 #ygrps-yiv-333245792yiv1182430412ygrp-sponsor #ygrps-yiv-333245792yiv1182430412ov li { font-size:77%;list-style-type:square;padding:6px 0;}  #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 #ygrps-yiv-333245792yiv1182430412ygrp-sponsor #ygrps-yiv-333245792yiv1182430412ov ul { margin:0;padding:0 0 0 8px;}  #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 #ygrps-yiv-333245792yiv1182430412ygrp-text { font-family:Georgia;}  #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 #ygrps-yiv-333245792yiv1182430412ygrp-text p { margin:0 0 1em 0;}  #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 #ygrps-yiv-333245792yiv1182430412ygrp-text tt { font-size:120%;}  #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 #ygrps-yiv-333245792yiv1182430412ygrp-vital ul li:last-child { border-right:none !important;} #ygrps-yiv-333245792
