Throttle cable problems....
Posted: Sun Aug 14, 2005 7:52 pm
'My Temco R46 is undergoing an extensive annual, and I'm having
trouble reconnecting the Stromberg after getting it back from a
rebuild. My airplane has cables for throttle and mixture control,and
none of the bell cranks, rods and whistles mentioned in the manuals.
Is that correct for the late Fairchild's, too have cables only, or has
someone substituted cables for bell cranks?
The difficulty I'm having is the cable shaft for the throttle cable is
solid material the last 8" or so. And it will
not make a smooth 90 degree turn to the carb throttle arm. Am I
missing some parts? I must be missing parts! a Bellcrank or
something. This setup can't be right. Anyone!
Hanford,Ca'
Hanford,Ca'
