Question?
Posted: Wed Jun 22, 2005 2:42 pm
'My 24 is sitting on the mains with no wings or motor installed. I will check my struts length when fully extended, and will be back with the information in about an hour.
It will be easy to check. My overhead lifting frame is still in place. I had to remake the bushings on the right side. The front mount was about 1.4 degrees off center line, and the rear mount was only 0.9 degrees off. The main gear leg almost looked like it was line bored.
Bob Etter
PO Box 974
Tonopah, NV 89049
775-482-6820
rletter@citlink.net
Bob Etter
PO Box 974
Tonopah, NV 89049
775-482-6820
rletter@citlink.net
