air-oil separator questions
Posted: Wed Jun 08, 2005 2:45 pm
'HI,, has anyone installed one of these,, if so how did you do it. The
separator I have has and inlet, outlet and a "drain" I would figure
the inlet would be fed by the "breather outlet" on the mid top of the
engine. what is done with the "vent pipe" at the back next to
the "vacuum pump"?
thanks
Mike'
the "vacuum pump"?
thanks
Mike'
