Camshaft housing cover nut installation sequence
Posted: Wed Feb 23, 2005 8:10 pm
by Mike Bourget
'Hi....
installing the above,, referencing my Ranger OH manual and
illustration 410 unfortuanely cannot be read and I can't see the nut
installation sequence. any one out there help with this?
cheers
Mike'
Re: Camshaft housing cover nut installation sequence
Posted: Wed Feb 23, 2005 8:56 pm
by Mike Danielle
'Mike
My manual is in the hangar. I'll retrieve it tomorrow and send the sequence
unless someone else beats me to it. Lots of little nuts...
Mike Danielle
Sent: Wednesday, February 23, 2005 6:08 PM
Subject: [fairchildclub] Camshaft housing cover nut installation sequence
> Hi....
> cheers
> Mike
Posted: Thu Feb 24, 2005 5:48 am
by Michael Denest
'Mike,
Starting in the center, snug down the nuts on each
side (do not final torque!) then work your way out to
the ends of the cover, alternating as you go. Then,
go back and torque the nuts using the same sequence.
--- Mike Bourget wrote:
> Hi....
> manual and
> can't see the nut
> this?
> cheers
> Mike
Do you Yahoo!?
Yahoo! Mail - Easier than ever with enhanced search. Learn more.
http://info.mail.yahoo.com/mail_250'
Posted: Thu Feb 24, 2005 1:42 pm
by Mike Bourget
'thanks Mike... done... one stud is stripped.. so will have to
helicoil it and reistall the one stud
--- In
fairchildclub@yahoogroups.com, Michael Denest
> Mike,
> Mike
> > Hi....
> > manual and
> > can't see the nut
> > this?
> > cheers
> > Mike
> Do you Yahoo!?
Posted: Thu Feb 24, 2005 2:30 pm
by Michael Denest
'Yeah, I forgot to mention that the cam box assembly is
brittle magnesium. Be careful installing that
helicoil, sometimes it can make matters worse! Have
you considered a high strength adhesive?
> will have to
> --- In
> wrote:
> > Mike,
> to
> Then,
> sequence.
> > Mike
> > > Hi....
> > > manual and
> I
> > > can't see the nut
> with
> > > this?
> > > cheers
> > > Mike
> > Do you Yahoo!?
> search. Learn more.
Do you Yahoo!?
Yahoo! Sports - Sign up for Fantasy Baseball.
http://baseball.fantasysports.yahoo.com/'
Posted: Thu Feb 24, 2005 9:03 pm
by Mike Danielle
'Mike,
I have my manual and can scan and send the diagram if you need it.
Mike #3
Sent: Thursday, February 24, 2005 11:41 AM
Subject: [fairchildclub] Re: Camshaft housing cover nut installation
sequence
> --- In
> wrote:
> > Mike,
> > Mike
> > > Hi....
> > > manual and
> > > can't see the nut
> > > this?
> > > cheers
> > > Mike
> > Do you Yahoo!?
Posted: Fri Feb 25, 2005 7:39 am
by Mike Bourget
'hmmm... its previously been helicoiled (it came off with the nut)
JB weld?
--- In
> Mike
> > will have to
> > --- In
> > wrote:
> > > Mike,
> > to
> > Then,
> > sequence.
> > > Mike
> > > > Hi....
> > > > manual and
> > I
> > > > can't see the nut
> > with
> > > > this?
> > > > cheers
> > > > Mike
> > > Do you Yahoo!?
> > search. Learn more.
> Do you Yahoo!?
by Mike Bourget
'thanks Mike.. no need.. did it yesterday.
cheers
--- In
fairchildclub@yahoogroups.com, "Mike Danielle"
> Mike,
> Mike #3
> From: "Mike Bourget"
installation
> sequence
> > --- In
> > wrote:
> > > Mike,
> > > Mike
> > > > Hi....
> > > > manual and
> > > > can't see the nut
> > > > this?
> > > > cheers
> > > > Mike
> > > Do you Yahoo!?
more.
Posted: Fri Feb 25, 2005 9:18 am
by Michael Denest
'JB Weld to the rescue.
> with the nut)
> JB weld?
> --- In
> assembly is
> Have
> > Mike
> > > will have to
> > > --- In
> Denest
> > > wrote:
> > > > Mike,
> each
> out
> > > to
> > > Then,
> > > sequence.
> > > > Mike
> > > > > Hi....
> OH
> > > > > manual and
> and
> > > I
> > > > > can't see the nut
> help
> > > with
> > > > > this?
> > > > > cheers
> > > > > Mike
> > > > Do you Yahoo!?
> > > search. Learn more.
> > Do you Yahoo!?
Do You Yahoo!?
http://mail.yahoo.com'
