F-24 Parts
Posted: Sun Dec 05, 2004 9:52 am
				'All,
I have some misc airframe parts that are no use to me. They are the
cut-off or removed parts from the 24W40 rebuild NC22036.
Left and right door front frame supports, with good door attach
fittings.
Left and right main gear, can be rebuild, major damage to the attach
points. Axles still installed.
Give me a call if you need. They are not worth much, just did not
want to throw them away. Those door fittings would take hours to
fabricate.
Aircraft Restoration & Repair
303-648-0130'
fittings.
fabricate.
303-648-0130'
