PT-Gear Leg Cracks & Front & Rear Wing-Spar Corrosion
Posted: Mon Oct 18, 2004 1:11 pm
'PT-Gear Leg Cracks!
The cracks that we discovered were in the long inside-corner of the scissor
attach-bracket area. (Aft side of Oleo Strut) While discussing our own
findings at a Fairchild Fly-In, we crawled underneath other members
airplanes that had flown in over the weekend and found the same problem on
some. We brought it to the attention of their owners before we departed.
To make a long story short, the gear-crack problem is nothing new and is
addressed in the manual. The book allows electric welding, up to 3/8" in
length, before declaring it as scrap. A new "yellow-tagged" pair of gear
legs bailed us out of our jam. For others, a careful inspection of spare
parts is a must. Don't forget about magnafluxing the area in question.
PT-Front & Rear Wing-Spar attach hardware corrosion!
Another spooky dilemma was the excessive corrosion that was discovered in
our wing attach hardware. It was necessary to have brand-new parts machined,
as per the original. After the many layers of paint were removed from the
originals, we lightly blasted the attach hardware with industrial baking
soda. The corrosion blossomed by the with every pass of the gun. Not a
problem that can be seen during an annual inspection.
--- Original Message -----
Sent: Monday, October 18, 2004 2:42 PM
Subject: RE: [fairchildclub] A Nice Fairchild Story...
> Nice Story, But where are the cracks in the gear? Bob Haas.
> _____
> From: purplewhite1978 [mailto:flightcenter@ameritech.net]
> Sent: Monday, October 18, 2004 2:16 PM
> Subject: [fairchildclub] A Nice Fairchild Story...
> This article was written for Warbirds Magazine By Jerry Pahl. Jerry
> works for the Air Zoo's Education & Research Department. This is the
> article that touched on the subject of landing gear cracks, found on
> the PT series aircraft. (I underlined that section)
> FAIRCHILD (HOWARD) PT-23 CORNELL
> Sometimes the restoration of an aircraft requires such a
> great investment of one's self that it is hard to know where the
> heart stops and the project begins. This is the story of an affair
> of the heart and anyone connected with aviation can understand the
> fidelity of the restorers to this mistress of a machine.
> When Greg Ward signed on as an Air Zoo airframe & power
> plant mechanic in 1988, he knew he was joining a team that had a
> reputation for quality restorations; award winning quality as seen
> in its resurrection of the Air Zoo's P-47 Thunderbolt, F6F Hellcat,
> and F7F Tigercat. As low man on the totem pole, Greg helped where
> he could in the projects being worked upon and then was finally
> given a project to supervise; a project, which would consume a major
> portion of his professional life. Greg's mistress was a World War
> II primary trainer, a Fairchild PT-23 Cornell, serial #291.
> While the Cornell is certainly not as vivacious as the
> fighters and bombers the Air Zoo has restored, it is just as
> romantic--the romance of flying an open cockpit aircraft will never
> be equaled by trips in the enclosed compartments of faster craft.
> And, though the Fairchild is a somewhat ordinary looking plane, to a
> cadet pilot she was a heavenly body.and a body to be respected.
> This sleek monoplane with blunted nose was much more important than
> any potential combat plane in the cadet's future. For, if that
> pilot could not master flying the -23, he need not worry about
> becoming a bomber driver or fighter jock. He would wash out and be
> placed in training as perhaps a gunner, radio operator or
> navigator. Whatever the case, he had to pull everything he could
> out of this little trainer before transitioning into something more
> powerful like a BT-13 "Vibrator."
> The Fairchild PT-23 is like its sister the PT-19 in every
> way except that the -23 has the round puggish blunted nose of a
> Continental W-670 powerplant producing 220 hp., while the -19 had
> the in-line aquiline nose of the Ranger L-440 producing 175 hp.
> Interestingly, Howard Aircraft Corp. originally built this Fairchild
> in 1943. According to Project Supervisor Ward, "Fairchild only
> built two of the planes." The rest were subcontracted out as
> Fairchild was busy building AT-21 Gunners, UC-61 Forwards, and doing
> design work on the C-82 Packet Transport--a plane similar to the
> post-WW II C-119 Flying Boxcar.
> Greg continued that Howard itself even contracted out
> subassemblies. "The center section of the wing was built by Wicks
> Organ Company.the outer wing panels as we know were built by McKee
> Door Company." Stamps to this effect were found on wing parts when
> the aircraft was dismantled. Certainly, other manufacturers did the
> same thing so that the needs of the U.S. Army Air Force training
> command could b e met.good examples of the efforts of manufacturers
> on the "Home Front."
> Variants of the Cornell were built by Aeronca, St. Louis
> Airplane Co., Fleet Aircraft, and even a Brazilian firm. Their
> designations were PT-19, PT-23, PT-26 (with a 200 hp. Ranger and
> sometimes cockpit enclosures with cabin heat), and a Canadian Fleet
> version of the -26 designated the Cornell II. A total of 8,130 of
> all variants were produced.
> But perhaps we are getting ahead of ourselves here. Let's
> back up a bit and take a closer look at this particular aircraft.
> PT-23 #291 is missing its logbooks from the war years, but
> independent investigation shows it was part of a lot of trainers
> sent to Stuttgart Field in Arkansas for primary training use.
> (Perhaps it was flown by the late Darl Watters while there.) A low
> wing monoplane with very wide landing gear (compared to the biplane,
> narrow gear PT-13 Stearman Kaydet) the Cornell was ideal for
> teaching cadets how to fly: and especially how to land! Like a
> lovely lady the -23 was gentle and forgiving. It did have a temper,
> however, and if you stepped on the brakes too hard, she'd nose over.
> there is a "roll over" pylon between cockpits to counter this
> effect. Having been produced near the end of the war, it was not
> painted garish orange-yellow like the typical biplane "Yellow
> Perils" used by the Navy and Army Air Force. Instead, it had been
> left somewhat of a "plane" Jane in silver dope applied directly to
> the wood and fabric.
> After its tour of duty, 291 was sold for $610 by the War
> Assets Administration in 1946 and changed hands thirteen more times
> before it was donated to the Air Zoo. It was refurbished to some
> extent in 1963, but then experienced an accident in May of 1971,
> causing the aircraft to be listed as a total write-off. In 1976
> Alfred P. Krest rebuilt almost the entire plane, yet when Tom and
> Jane Austin, then of Greeneville, Tennessee bought the plane in
> 1981, it was barely airworthy. In fact, the first thing Tom did
> after the plane was ferried to Greeneville was to cut off the fabric
> cover so he would not be tempted to fly the aircraft. Years of
> exposure had taken their toll.
> Tom had been in Air Force ROTC at the University of
> Tennessee and owned several warbirds including a T-6, three T-28s,
> two Luscombs, and an AD Skyraider. But his dad had owned a PT-23
> and it was the first plane in which Tom ever flew. So the Cornell
> had a special place in his heart too. After Tom purchased the
> aircraft from John Baugh of Nashville, he fully intended to restore
> the aircraft to tip-top condition. Using an ice pick, Tom probed
> every inch of the fuselage frame and found three areas where the ice
> pick went right through the metal! Extensive repair work was done
> and the frame was cleaned and painted.
> The "lobster cage," the ventral wooden belly of the
> fuselage, had been completely rebuilt by a structural engineer who
> had built tow of his own planes and was a master when it came to
> woodworking. Tom struck a deal with him to do the wings also, but
> then love intervened. Though this gentleman was 70 years old and
> had just lost his wife, he fell in love not with this airplane but a
> real woman, got married, and promptly forgot about the project. Tom
> just could not find anyone he trusted enough to do the job correctly.
> Unfortunately, Tom was in the process of changing jobs and
> relocating. With no one to work on the plane and no place to store
> it, he was afraid parts would be misplaced. He and Jane made the
> decision to donate the plane to the Air Zoo. Tom said it
> was "difficult to part with the dream, the 'Zoo' was by far the best
> of all the alternatives." (Tom was associated with the Air Zoo,
> being its Hellcat pilot for some years.) The donation papers were
> signed on May 19, 1988.
> Though one probably should not call the project a basket
> case, it was delivered in pieces and the wooden pieces were going to
> present a major challenge to the restoration team. Initially Greg
> and a hand full of volunteers had hoped the restoration project
> would be comparatively easy. But this is a very complicated
> aircraft, especially for a trainer, and required the skills of metal
> and wood worker; people who could upholster and sew fabric; painters
> and artisans.and many more.
> "In the beginning of the project we thought we could maybe
> re-skin part of the wing, do a little repair work, and have a good
> airworthy airplane, " said Greg. "The deeper we dug, the more we
> realized there was no way our original plan was going to gel so we
> had to go ahead and completely disassemble it (the wing) and fix
> it." Though this aircraft and restoration does not really compare
> one-to-one with the restorations of the P-47 or Corsair, considering
> the decay that was discovered, this was going to be one of the most
> ambitious restorations on this type of aircraft the Museum staff
> would undertake.
> Originally the ribs hade been bonded with animal glues which
> had since crystallized; plywood had absorbed moisture and either
> separated or suffered from dry rot; and on one knew what the
> condition was of the interior of the spars.
> Jigs were built for each and every rib; leading edge, center
> and training edge. The wings tapered and the cord did likewise,
> compounding the rebuilt. Dozens of router bits were consumed
> chewing off one surface of each spar (hundreds of brass coated steel
> nails can do a number on router bits). Once the plywood was
> removed, the interiors could be inspected--fortunately, they were OK
> and did not require rebuilding, other than the replacement of the
> removed surfaces.
> One of the Museum's volunteer workers is Lyle Patton, a
> master cabinetmaker. This man performs miracles with wood. Both he
> and Greg as well as a multitude of other volunteers attended to the
> long and arduous process of restoring the wings. Former Ford Tri-
> Motor pilot John Allen was also instrumental in much of the wing
> building. Once the wing skeleton was complete, the plywood skin had
> to be glued and tacked.the nails to be removed later.
> "Aircraft plywood is perfect throughout.it's structural,
> simply structural, " said Greg. "It's gotta be solid throughout; no
> voids, no mineral streaks, no knots, no structural defects of any
> kind. It has to have total glue coverage between all of the
> veneers." Made of a sandwich of ribbon-striped mahogany on the
> outside and poplar on the inside and the grains on the bias,
> aviation grade plywood is very strong and anything but cheap.all of
> the wing and empennage had to be covered with it. Needless to say,
> it could not be wasted and the restoration team was at the next
> critical step' forming the leading edge.
> The PT-23 does not have a very thick wing and the leading
> edge is somewhat acute. In order to bend large sheets of plywood
> (which is only 3/32 of an inch thick) without cracking it, the team
> had to design a rather complicated bending fixture. Essentially
> they built a long, crude wing with pine ribs over which a roll-top
> desk-like surface was attached--this had a fabric lining. Under the
> cloth was placed a hot-water pipe with a series of holes along its
> length. Slowly, over several days, the plywood was bent with cargo
> ratchet-straps, cinched around the jig as hot water was sprayed from
> beneath and above. Once fully formed and allowed to dry, a perfect
> leading edge had been created.
> Another juggernaut was the empennage. At various stages of
> the rebuild, the restoration team would assemble associated parts
> and to make sure everything was calibrated correctly. When they
> went to mate the vertical and horizontal stabilizers, which had been
> completely finished to the point of being painted, they didn't fit!
> Unknown to the restorers, the horizontal stabilizer had been beefed
> up 1/16 of an inch in the center, with the plywood tapering towards
> the outer tips of the planes. The horizontal stabilizer had to be
> completely stripped and rebuilt from the skin up, adding the
> increased thickness.
> When the wings and empennage were finished, however, they
> were better than those originally built by the subcontractors. "We
> used epoxy glues.we had to get special approval for that. We filed
> a 337 form (with the FAA) as per the inspector's recommendation."
> Also, the restoration team had the benefit of time--years of wear
> and tear--to see all the wear patterns and discovered stress
> cracks. "We had the advantage of 50 years of use and abuse by
> students and civilians to see what the weak points were." With FAA
> approval, the team modified these weak points. And, unlike the
> original finish, the bare wood surfaces were covered not with
> regular varnish, which would split and peal, but with Stits epoxy
> varnish. This was then covered with Stits poly fiber and finally
> doped and painted with several coats of Imron.
> Perhaps, though, the biggest problem during the restoration
> process was the fixed landing gear, which had, cracks in them.
> According to Greg, it was just a "by-product of the age of the
> airplane, the design of the landing gear.these airplanes were never
> meant to last for 50 years. We went to a Fairchild fly-in where
> there were about a dozen Fairchilds. Dick Schaus (Director of
> Restoration & Maintenance) and I crawled underneath each one and
> found out that they all had the cracks we were finding. Greg tried
> to repair the gear and was successful in doing so, but the heat
> treater over treated them and in the process caused the cylinders of
> the oleos to go out-of-round.
> Four sets of gear were located, shipped, tested by magna-
> fluxing--and rejected. Then, while Greg was in Missouri on an
> aircraft recovery mission, Schaus got a call from a man who heard of
> the restoration problem and actually had a set of gear that had
> never been used since being built in the 1940s; the two gear
> literally had the manufacturer's yellow tags on them. The really
> phenomenal coincidence is that the man lived only 10 miles from
> where Greg was picking up the recovered aircraft!
> There were hundreds if not thousands of other problems and
> challenges to be met, with the Museum restoration team rising to
> each task. New Cleveland brakes were added, new up-to-date avionics
> and electrical systems were added.electric starter, transponder,
> Loran, intercom system, up-to-date seat restraint harnesses, and
> many many more items were added, repaired or refurbished. Since
> this was going to be a flying aircraft, it must be a safe aircraft.
> Volunteer A&P Martha Salisbury removed and did some
> disassembly on the Muskegon built engine, but Aero Engines of Los
> Angeles completed the rebuild. It took so many years to complete
> the aircraft, however, that a little rust had formed on the valve
> guides and this created a minor problem. Also, reassembling an
> airplane after seven years can cause a few things to be put together
> in not exactly the correct order and the fuel pump was sucking fuel
> out of the engine rather than pumping it into the power plant. So
> there were some problems--all of which were resolved and the engine
> has run without a hitch ever since.
> After seven, almost eight years, the PT-23 is now airworthy
> after what can only be described as a labor of love. As with any
> relationship it can be as perplexing as rewarding. One can
> understand that emotions ebbed high and low many times throughout
> the whole process. When Greg was asked why the floor boards and
> inner luggage compartment looks as though they could be the tops of
> coffee tables, he responded."the reason that was done was more as a
> morale booster for the volunteers that built the airplane. It was a
> 90% volunteer-built airplane, seven years worth of beautiful
> woodworking. All of the wood looks the same under the paint.we
> wanted to show off a little bit of the craftsmanship and spruce up
> the aircraft a little."
> This sprucing up extends to the paint job too.but for a
> functional reason also. Greg said the paint is "a metallic silver
> Imron polyurethane. The reason we used the polyurethane paint (on
> the aircraft) is that we do fly them. They get oily, they get
> dirty. And the Museum has to clean them in a reasonable amount of
> time and get 'em looking Good. If that were silver dope (as on the
> original aircraft) the oil, the grass stains; the gasoline would
> stain the finish. Over a short period of time it would look
> horrible." Other volunteers who were involved in the Cornell's
> restoration are: Bud Baden, Bud Chop, Carl Cummings, Bud Denning,
> Joe Green, Liz Grossman, Bill Hopkins, Richard Jackson, Tom
> McNamara, Bob Niewoonder, Gene Phipps, Chester Stawikszynski, Al
> VanderVeen, and Harold Vogt. These men and women and the Kalamazoo
> Aviation History Museum are committed to preserving the past for the
> future.a future where the men, women and children of the United
> States can learn more about and appreciate the dedication and
> sacrifice of the men and women who built this aircraft originally
> and the men who trained in it in preparation for combat.
> One of these men is Chester Douglass. Chester about dropped
> in his tracks when he first saw the Air Zoo's -23. "That's the
> airplane I soloed in!" It was not, of course, this actual aircraft,
> but you could see the flood of memories rushing back. "I had had a
> $1 ride with 'Bun' Perry as a kid," and that, like with so many
> youngsters then, was enough to get him hooked on flying. But the PT-
> 23 was the first plane in which he was really introduced to flying
> as a prospective pilot. Chet did not have much with which to
> compare that first flight in the Cornell. "Looking back though,
> after the experience of flying other aircraft, looking back it was a
> very reliable, very dependable, and a relatively easy airplane to
> fly. He should know. Chet progressed through several levels of
> training, flew 63 combat missions in B-26s and A-26s, piloted P-51s
> in the Air Defense Command during the Korean War, and ended up
> flying the RB-57 in the Air National Guard.
> Although the PT-23 is a bit more complicated than other
> primary trainers of the day, all of the systems worked together
> beautifully. Though Chet had not flown a Stearman, he had spoken
> with plenty of pilots who had and he is thankful the -23 has very
> wide landing gear, unlike the Kaydet. "It wasn't impossible (to do
> a ground loop in the -23), but I never did." There really were no
> bad habits with the aircraft that Chet can remember.however, his
> instructor never would teach them short field landings.
> "It was a rather touchy maneuver" and, though there was no
> official bulletin that he can remember, there "was some concern
> about the number of main spars that broke." The instructor did show
> the cadets how to drop the plane just in over the fence, but he
> never allowed them to do it themselves. Perhaps he questioned the
> ability of the wooden wings to absorb the 20 ft. drop, if not done
> properly. The instructor did sign-off on the cadets as having
> performed the maneuver, however. Chet never got over the wonder of
> flying and still enjoys it.
> After almost eight years--after his marriage to his wife,
> after the birth of their child--Greg Ward was going to finally see
> the rebirth of his own charge, the PT-23 Cornell. It was 7 July
> 1997. The original plan had been for the first flight after
> restoration to be on 4 July 1997, Independence Day; a rather fitting
> date for a warbird trainer that contributed so much to the
> independence of this nation. But the weather did not permit.
> Museum Board Chairman Pete Parish took some time to rev up
> the engine and check all the instruments, but soon he taxied out and
> quicker than a drop of water jumping off a hot griddle, the -23 was
> airborne! The silver aircraft took to the air like a fish to
> water. In this perfect mating of form to function, over the next
> half hour Pete put the Cornell through her paces. Thoroughbred that
> she is, she performed beautifully. Greg and many of his volunteers
> had their heads cranked skyward for that 30 minutes watching the
> glint from the wings as Pete checked out the silver bird. Then Pete
> banked to the right, lined up on 5/23 and greased her in on a three-
> point landing.it was beautiful. No major squawks.
> Tom Austin finally got his chance behind the stick, piloting
> the aircraft to Oshkosh with Greg in the back seat. There were over
> 500 warbirds at the air show and over 100 in competition. The Air
> Zoo's PT-23 Cornell was awarded "Judges Choice." The restoration
> team was ecstatic! Whether or not she had won a prize, the -23
> certainly had already won the hearts of all with whom she had come
> into contact. Just what you would expect from a classy lady.
> Yahoo! Groups Sponsor
> ADVERTISEMENT
> oups/S=1705340085:HM/EXP=1098209783/A=2372354/R=0/SIG=12id813k2/*https:/www.
> orchardbank.com/hcs/hcsapplication?pf=PLApply&media=EMYHNL40F21004SS>
> click
> here
> :HM/A=2372354/rand=406379295>
> _____
> * To visit your group on the web, go to:
> http://groups.yahoo.com/group/fairchildclub/
> * To unsubscribe from this group, send an email to:
> * Your use of Yahoo! Groups is subject to the Yahoo!
> Terms of Service.
