Ranger magnesium alloy?
Posted: Thu Sep 02, 2004 7:35 pm
by Mike Bourget
'Hi all,, anyone know the details of the magnesium alloy on the valve
cover?
thanks
Mike'
Re: Ranger magnesium alloy?
Posted: Thu Sep 02, 2004 8:04 pm
by purplewhite1978
'Mike,
I am assuming that you are asking about restoration?
If so...
I fully-restored my Father's Ranger engine.
First, remove the pick-up tube and clamp. Next, we stripped the old
paint, washed the oil off with mineral spirits, and steam-cleaned
cover inside and out.
Dupont makes an excellent Acid Etch solution, to be followed with
Alodine and fresh water rinse. (Inside and out)
Follow the directions carefully, and keep your session shorter than
usual (as compared with aluminum parts) since the magnesium is prone
to damage if subjected to the acid for too long a period of time.
Once the part was totally clean, we sprayed a thin coat of zinc-
chromate primer onto the outer surface, then followed that coating
with Polyfiber's Epoxy Chromate. After that was cured, we finish-
painted with Imron. If that procedure sounds like over-kill, you are
probably correct. Our motto: "Only the best for our flying machines!"
Greg
--- In fairchildclub@yahoogroups.com, "Mike Bourget"
valve
> cover?
> thanks,
> Mike
Posted: Fri Sep 03, 2004 7:55 am
by Mike Bourget
'HI Greg,, partially correct. The engine was completely restored and
zero timed (for experimental) in 96 and pickeled. It fell and
cracked the valve cover case. I have a spare engine I can replace
the cover with, but want to try and weld the valve (cam shaft) cover
first, save alot of time. If its ruined, nothing ventured nothing
gained. Then I'll take the old cover/and assembly, the broken cover
and assembly to N.Y or P.A. and get her reassembled.
The aviation welding co. would like to know what the alloy is to
determine the weld process.
cheers
--- In fairchildclub@yahoogroups.com, "purplewhite1978"
> Mike,
> If so...
prone
are
machines!"
> Greg
> valve
> > cover?
> > thanks,
> > Mike
Posted: Fri Sep 03, 2004 8:34 am
by Flight Center
'Mike,
Unfortunately, I do not have any info on the alloy or I could be of more
help.
My welder here, who has done plenty of magnesium, is more concerned about
the oil contamination when welding.
He suggested baking the oil out 1st. He couldn't give me a temperature to
pass on to you because he used to take his stuff to an F.B.O. where they
knew what to do with respect to heating the oven.
Either way, we wish you the best!
Have a great day!
Greg'
Posted: Sat Sep 04, 2004 9:00 am
by John Berendt
'Mike,
I have a spare cover I would sell it may save you allot of time and money.
if interested let me know.
Fairchild Club
Sent: Friday, September 03, 2004 8:54 AM
Subject: [fairchildclub] Re: Ranger magnesium alloy?
> cheers
> Mike
> wrote:
> > Mike,
> > If so...
> prone
> are
> machines!"
> > Greg
> > valve
> > > cover?
> > > thanks,
> > > Mike
Posted: Sat Sep 04, 2004 3:34 pm
by Mike Bourget
'Hi All,.,. I have a spare engine that needs a rebuild, and I can
use the cover off of that (buy another cover if I decide to rebuild
it). My problem is this, some have said that the cover and assembly
are matched and cannot be used separately, others have said the
opposite, not quite sure where to go. I would agree putting another
cover is probrably the cheapest solution, but I've also been told
that the cover and the assemlby are matched, and I should tear it
apart and switch all the parts and re-install the assembly with the
new (older) cover, I am not qualified to do this. sooooo.........I'm
a little confused.
--- In fairchildclub@yahoogroups.com, "John Berendt"
> Mike,
and money.
> John Berendt
> Fairchild Club
> From: "Mike Bourget"
and
replace
cover
nothing
cover
> > cheers
> > Mike
> > wrote:
> > > Mike,
> > > If so...
the old
cleaned
with
than
> > prone
time.
zinc-
coating
finish-
you
> > are
> > machines!"
> > > Greg
the
> > > valve
> > > > cover?
> > > > thanks,
> > > > Mike
> > Yahoo! Groups Links
