PT-23 Lord Mount Fix...
Posted: Tue Jul 06, 2004 3:59 pm
'Just uploaded two (2) new images (Inside the AIR ZOO folder) that
show a reasonable fix for PT-23 Lord-Mount situation, with some
degree of detail.
We used factory-fresh lord-mounts $$$, then created special
compression "step-bushings" out of 4130 tubing to help the fill the
1/2 hole found inside the new lord-mount washers, provide a means of
spacer-bushing compression, yet still allow the use of new 3/8"
diameter AN motor-mount bolts.'
degree of detail.
