Warner oil sump fittings again
Posted: Fri May 28, 2004 5:16 pm
'I am having problems tracking these down and so I am
appealing to you over in the US for a bit of help. When I was
having trouble finding fuel fittings I found that much of what i
needed was available in DIY shops in the US. The fittings were
NPT and not readily available over here but easy in the US.
So,
The oil sump fitting is getting desperate. I need one on the sump
and one on the back of the oil pump. The problem is that I only
have one and need another but I certainly can't find anything in
the UK.
So (part two)
I have posted some pictures of the part in a folder in the files
section called "Oil Fittings" or something similar. There are two
pictures and if you see that i might be able to get a substitute
then I would be very grateful.
Melvyn Hiscock'
So,
the UK.
So (part two)
Melvyn Hiscock'
