Re: Digest Number 728
Posted: Wed Jan 21, 2004 12:58 pm
'Thanks Walt,
Just two days ago the vat of Plusgas that had been sloshing around
the connector finally did its worse and I was able to loosen the
screws and get the old wires out. Mind you, I still don't know if
they are going to work so I may still get back to you.
It must be getting interesting if I am wiring up the lights . . .
regards,
Melvyn Hiscock
regards,
Melvyn Hiscock
>Message: 1
> Date: Mon, 19 Jan 2004 20:32:25 -0500
> From: "WALTER ALBERT"
>Subject: Re: Grimes light connectors
>I'm sure I have what you need.. walt
>----- Original Message -----
>From: "Melvyn Hiscock"
>To:
>Sent: Tuesday, January 06, 2004 5:10 AM
>Subject: [fairchildclub] Grimes light connectors
>> Does anyone have a spare connector for a Grimes Model C light? the
>> part I need is the connector that takes the two wires and connects to
>> the bottom of the bulb. It is about 3/8 in dia and about 1/2 in long
>> with two small screw connectors. Can't find them in Av Spruce so does
>> anyone have a spare lying around?
>> Melvyn Hiscock
