fairchildclub@yahoogroups.com
Sent: Sunday, June 15, 2003 3:03 PM
Subject: Re: [fairchildclub] 165 Warner and prop questions
Jamie, Thanks for the infromation. I believe that the Curtis reed prop that we have is the model 55111. This thing has a weihgt of about 44 lbs. Could the specs. be that far off on the actual weight ?
Jamie Treat wrote:Tom,
Here are the specs from the TC.
Fixed pitch metal ... ... +22 lbs. (-51) +22 lbs.(-51)
(Curtiss Model 55518)
For landplanes only: Static rpm at maximum permissible throttle setting for diameters of not over 90
in., not under 87 in.: not over 1730, not under 1630. No additional tolerance permitted.
Static rpm at maximum permissible throttle setting for diameters not over 86 in.,
not under 83 in.: not over 1850, not under 1750. No additional tolerance permitted.
Tom Goodletts 24W41A with a Warner 165, static was 1800 rpm. Flat out 2150/2200.
All smooth at idle and above 1300 rpm. Some Warners have a rough spot in the 1100 rpm range. Contribute that to the induction system. The 185J I just flew is smooth at all settings. Tom Goodletts 165 Warner was rough enough that during taxi at 1100, you could not see the instruments mounted on the shock panel. I have brought this to the attention of John Duncan, will try to improve during manufacture someday.
Sent: Saturday, June 14, 2003 12:04 PM
Thanks Bob for the infromation.
I am getting 1750 RPM static with the Curtic reed now. I think that will be enough to do the trick.
You are right about the way the carb heat butterfly box works. The question I have is , Why is the exhaust open around the carb heat box with only the inner tube ( which is the carb heat tube ) connected to the carb heat butterfly box. This looks like the hot exhaust would be directed on to the carb float bowl area.
Robert Etter wrote:
Charles Botts tried my Curtiss Reed on his Meyers OTW, and he said that the
maximum RPM that he saw at full throttle was around 1500 rpm. No vibrations
at any RPM was mentioned.
I do remember that there is two butterflies on the airflow for carb heat.
One is in the main cold air flow from the front of the motor(Normally open)
and the second (Normally closes) is located between the hot air blast tube
and the cold air chamber of the inlet. When you pull the carb heat on, the
large cold air butterfly starts to close and the hot air butterfly starts to
open. I seem to remember that the hot air is injected into the intake air
stream after it passes the large butterfly. Both the civilian and military
manual show the Cold/Hot air mixing box.
Sent: Friday, June 13, 2003 8:44 PM
Subject: [fairchildclub] 165 Warner and prop questions
> Trying to finish up a restoration on N77630 which is a 1946 24W 46 and
have a few questions for any helpful club member.
> !. What should the static RPM for a Curtiss Reed prop be for this 165 hp
Warner?
> 2. The manual shows that the exhaust is open near the carburetor where
the inner carb heat tube attaches to the carb heat box. What keeps very hot
exaust from getting the carb. bowl to hot?
> 3. Lastly ,Is it common for the Curtis Reed prop the have some vibration
between 12 -14 hundred RPM? It is smooth before and after that particular
RPM setting. Thanks for any wisdom on these Q' s.
> Do you Yahoo!?
> SBC Yahoo! DSL - Now only $29.95 per month!
Do you Yahoo!?
Do you Yahoo!?
