SC 8.00 Tire
Posted: Mon Jun 02, 2003 9:22 pm
'Fairchild Club people,
A few of you have Fairchilds that have an SC 8.00 Tailwheel tire. For those of you that need one, Bill Hughes has found a wonderful answer to your needs. Here is what Bill says:
Hi Bob.
I have spent many hours on the net locating this tire. It is an oval ribbed tire with almost exactly the same size and contour as the 8 SC we use and that is so hard to find. The tire is a 4 ply tube type tire. The tube has an angle valve stem. The tire and tube size is 2.50 x 3 and has a loading capacity is 220 lbs at 50 psi. I am currently running one with no problem. The tube is EXACTLY the same tube Dresser sells. I know because I have one of Dressers tubes. The tire may be the same but Dresser removes the manufactures name.
The cost is $10.15 for tire and $3.45 for tube plus $5.50 for shipping for total amount $19.10 for one set. .
You can order using your credit card and they will need your credit card information to process the order.
You can email your order to HChang@kendausa.com
Credit Card Number: _________________________________________
Exp. Date: ____/____/____
Type of card (circle one): Visa MasterCard Discover American Express
Name as it appears on credit card: ___________________________________________
Billing Street Address: ___________________________________________
Billing Zip: __________
You can also call (614) 866-9803 ext. 219 to place order
Snail Mail:
Hank Chang,
Kenda
7095 American PKWY
Reynoldsburg OH 43068
Info provided by:
Bill Hughes
6129 Circleview
Ft. Worth, Texas 76180
PT 22 N53146
Hi Bob.
Snail Mail:
Hank Chang,
Kenda
7095 American PKWY
Info provided by:
Bill Hughes
6129 Circleview
PT 22 N53146
