Replace cable to trim tab
Posted: Mon Apr 14, 2003 7:42 pm
by Norbert J Mc Luckie
'I would like to change the small (1/8 inch) cable that is inside the
elevator and is attached to the chain that actuactes the trim tabs on an
F-24. Please tell me how to do this. Thank you in advance. Norb Mc Luckie
Coal City, IL'
Re: Replace cable to trim tab
Posted: Tue Apr 15, 2003 10:22 am
by b guest
'Norbert,
First things first, use several long pieces of locking wire and attach to
ends of the chains before you try to remove as you will be feeding the new wire
and chains onto the sprockets. Have fun but don't let go of the ends what ever
you do. Good luck, Bruce
> Coal City, IL
Posted: Sat Apr 19, 2003 11:19 am
by robert Etter
'I thought of doing the same thing on my Fairchild. I found out that the
Fairchild used a chain that is different from what may be common now.
I could look into it again, but if memory serves me correct, Fairchild used
something like 24 links per foot chain, and what Cessna used is a 25 link
per foot.
I may have the numbers reversed. Close, but no cigar. I have several feet
of new chain that I couldn't use. The price was cheap, and it never dawned
on me that there would be more than one size of small chain.
Sent: Monday, April 14, 2003 6:42 PM
Subject: [fairchildclub] Replace cable to trim tab
Luckie
> Coal City, IL
