Sent: Wednesday, April 09, 2003 6:03 AM
fairchildclub@yahoogroups.com
Subject: Re: [fairchildclub] Re: Fairchild Parts Point of Contact
Jamie,
The guy in Florida did not tell me the ship had a220. cont. The ad and
service bulletin I remember was really on the gear leg
my mistake. I have a home made universal fitting that would be easy to make
all it would take is a small vertical mill I did a article on it last year
or in 2000 it was made out of bar stock. The cost of making the original
one is out of the question. I wonder if Solberg has any, Joe or Mike denest
should be able to find out
John
t
Sent: Tuesday, April 08, 2003 1:17 PM
Subject: [fairchildclub] Re: Fairchild Parts Point of Contact
> Thanks John,
> Don't have that SB. If you are talking SB41-11 and companion AD note
> 46-21-01. And of course the SB does not talk 24R46 or 24W46, but the
> AD applies to all. There is no data for repair only inspection and
> replacement with new unit. If you have another SB that talks repair,
> send one along when you get a chance. If memory serves me correctly,
> Karl Sanger when thru this old vs new universal fittings P/N 3330 and
> 3328 last year. I believe Karl had some new ones made or found a
> newer set.
> Any repair to those fittings would be questionable due to the stress
> and the additional weight caused by the heavy engine.
> Jamie S. Treat
> --- In
fairchildclub@yahoogroups.com, "John Berendt"
> wrote:
> > Jamie,
> > There is a service bulletin or an AD that tells you how to repair
> the crack
> > in a universal . I have been in contact with the guy in Florida
> > John Berendt
> > From: "Jamie S. Treat"
> > To:
> > Sent: Monday, April 07, 2003 10:06 PM
> > Subject: [fairchildclub] Fairchild Parts Point of Contact
> > > Bob Haas and I met quite a few interested Fairchild people at Sun-
> N-
> > > Fun this past week. One person, we believe his name is Jim Hayes
> > > mentioned he had Fairchild parts. We have lost the Business card.
> > > There is a fellow Fairchild owner in Fla. that is in need of the
> F-
> > > 24 knuckle joints. One of his has a known crack. If Jim Hayes (we
> > > think that was his name) is reading, drop me a note. You mentioned
> > > you are a Fairchild Yahoo member.
> > > Or if any one has the Universal Gear joints, drop me a note.
> > > Jamie S. Treat
> > > 303-648-0130
> > > JamieTreat@d...
> > > To unsubscribe from this group, send an email to:
> > > Your use of Yahoo! Groups is subject to
