Anticollision Lighting
Posted: Tue Dec 03, 2002 6:49 pm
'Does anyone know if a wing type strobe is legal to mount on top of
fuselage? Considering mounting fuselage strobes and viewing Whelen
and Aeroflash lit all fuselage application strobes are the little
jelly jar fresnel lens type. This is OK for belly as not very evident
but that thing on the back will look like a wart. Couldn't a oval
lens wing type unit be mounted on top of fuselage? It'd be less
conspicuous and angular coverage meets part 23.
On another note, there was a little article in Nov. Experimenter on
tailwheel shimmy. A pacer driver Gilbert Pierce wrote it. He stated
that according to automotive theory of wheel alignment that the pivot
axis(the oleo strut on a 24) should actually angle forward!!! This
means that the bottom should be ahead of top of strut. Now before you
say @#%!$^, I looked at a Waco and it never has shimmy (rarely use
lock). Lo and behold it angles forward. This is true Waco UPF as when
ground handling that silly little wheel always wants to turn to the
front, and its a bear to get it back around. This is in conflict with
one statement in the article but that's another story. Now I've heard
of Fairchild people extending the draglink but according to this
article that would exacerbate the situation. Food for thought.'
