Ranger starter contactor replacement
Posted: Wed Jun 26, 2002 1:46 pm
by danMichael
'Does anyone have a source for a replacement starter contactor? I cannot
seem to locate a replacement for the original 3 post common coil
contactor presently installed. I would be satisfied with a 4 post
intermittent duty contactor in the same form factor that I could use
with a jumper, but even these seem unavailable — the only solutions I
have located require rewiring the ignition switch to use a case ground
unit (by supplying current to the control post rather than grounding it).
Thanks.
:Dan
:NC81323'
