PT-19 fuel tank
Posted: Wed Jun 19, 2002 7:36 am
by robert hensarling
'Is there a fix for a tiny pin-hole leak in a fuel tank? If not, is a replacement tank available anywhere? This a right side tank.
Re: PT-19 fuel tank
Posted: Wed Jun 19, 2002 7:53 am
by Cy Galley
'A temp fix is to rub bar soap into the pinhole. Soap is insoluble in
gasoline. A more permanent fix is to clean well and use a glob of JB Weld.
If the tank is tin plate or steel, solder it shut. If it is aluminum, drain,
purge with nitrogen or other non-flammable gas and weld it. DO NOT
pressurize with the gas.
Editor, EAA Safety Programs
Sent: Wednesday, June 19, 2002 8:39 AM
Subject: [fairchildclub] PT-19 fuel tank
Re: PT-19 fuel tank
Posted: Wed Jun 19, 2002 9:00 am
'-----Original Message-----
Date: Wednesday, June 19, 2002 8:52 AM
Subject: Re: [fairchildclub] PT-19 fuel tank
Thanks Cy. I'll have it soldered. I'm wondering if there's also a "slosh"
material to use inside the tank while it's removed from the aircraft, just
in case there may be another area that may be thin?
Robert
drain,
>From: "robert hensarling"
>To:
>Thanks
Re: PT-19 fuel tank
Posted: Wed Jun 19, 2002 10:28 am
by jstreat360@aol.com
'Robert,
Beware of sloshing compounds, they are not a perm fix. Weld or Solder if you can. Just be careful, do as Cy stated. I have welded many tanks over the years.
Jamie'
Re: PT-19 fuel tank
Posted: Wed Jun 19, 2002 10:40 am
by Cy Galley
'I'd stay away from "sloshes" as even Piper has problems with them. They peal
off. They plug up screens, etc. They are bad news.
Cy Galley
Sent: Thursday, June 20, 2002 10:00 AM
Robert
drain,
>To:
>Thanks
Re: PT-19 fuel tank
Posted: Wed Jun 19, 2002 12:02 pm
Sent: Wednesday, June 19, 2002 11:28 AM
Thanks Cy and Jamie, no sloshes for me!
Robert
> Robert,
years.
> Jamie
Re: PT-19 fuel tank
Posted: Thu Jun 20, 2002 8:19 am
by marge&john
'Bob,
I have many PT fuel tanks if you cannot fix it I can supply the replacement.
Do you have the type of fuel guages that screw into the tank or the type
that and held in by screws arround the flange?
> Thanks
Re: PT-19 fuel tank
Posted: Thu Jun 20, 2002 1:02 pm
Date: Thursday, June 20, 2002 9:19 AM
That's good to know John, many thanks! My tank has the flange, and the
guage is held in place with a series of screws. Are you tanks NOS? Do you
have an idea of pricing just in case?
Thanks!
Robert
>Bob,
replacement.
>John Berendt
>To:
>> Thanks
Re: PT-19 fuel tank
Posted: Fri Jun 21, 2002 8:47 am
by marge&john
'Bob,
They are old stock from the many PT projects I had. Cost proble $50.00 plus
shipping.
Sent: Friday, June 21, 2002 2:02 PM
> From: marge&john
you
> Thanks!
> Robert
> >Bob,
> replacement.
> >John Berendt
> >To:
> >> Thanks
Re: PT-19 fuel tank
Posted: Sat Jun 22, 2002 10:32 am
Date: Friday, June 21, 2002 9:46 AM
Thanks for the info John, will let y ou know what I find out. Trying to get
her all spruced up and sell this summer.
Robert
>Bob,
plus
>shipping.
>John Berendt
>To:
>> From: marge&john
>you
>> Thanks!
>> Robert
>> >Bob,
>> replacement.
>> >John Berendt
>> >To:
>> >> Thanks
