(no subject)
Posted: Sun Mar 31, 2002 8:51 am
'Help! I am in of some help in finding someone who has a 337 and the instructions for continuing airworthiness(ICS) for covering a F24W-46 with the Poly-fiber process. It appears that Poly-fiber has Fairchilds approved under T.C. # 706 and not under T.C. # 707 which is what most of the Warner powered Aircraft are.
In contacting the FAA there response is to get the fabric approved under a field approval.If there is anyone out there that has done this a copy of your 337 and (ICS) at this time would be very helpful. Thanks ,Tom
Do You Yahoo!?
Yahoo! Greetings - send greetings for Easter, Passover
Do You Yahoo!?
