subsitute part number
Posted: Mon Jan 28, 2002 12:31 am
by Tom_Downey
'Does any one have a subsitute part number for a Shatz bearing CS2170
as given in drawing number 42215 and 42267
There are 10 total in the fuselage portion of the flight controls,of
the F24, most of mine are worn out.
Thanks Tom D.'
Re: subsitute part number
Posted: Mon Jan 28, 2002 7:45 am
by jstreat360@aol.com
'We do, let me look tonight. It is a piper p/n avail thru Univair.
Visit my Web Site:
Meet my Family:
Posted: Mon Jan 28, 2002 9:04 am
by Buell Powell
Are all the bearings self-aliging or just the ones in the short
control rods? Mine have non-self aliginging in the long control rods which
may not be correct if they were replaced at some time. Mabey Jamie can tell
us if all the bearings should be the same.
Buell
Sent: Monday, January 28, 2002 12:31 AM
Subject: [fairchildclub] subsitute part number
> Thanks Tom D.
Posted: Mon Jan 28, 2002 3:24 pm
by Mr & Mrs Cox
'Tom
I got these bearings from univair.
They are used in the Stinson wing assembly and are under part No. CS2170.
They are also shown in the latest Aircraft Spruce Catalogue on page 197
under Control surface bearing P/N 08400 @ $6.70.
I have had no problems fitting them.
Hope this is of some help.
Regards
Sent: Monday, January 28, 2002 6:31 AM
> Thanks Tom D.
Posted: Mon Jan 28, 2002 8:07 pm
by Tom_Downey
'--- In fairchildclub@y..., "Mr & Mrs Cox" wrote:
> Tom
CS2170.
197
> Regards
> Frank Cox
Thanks this is what I needed
Tom D.'
Posted: Sun Feb 10, 2002 12:13 am
by Tom_Downey
> Tom
CS2170.
197
I ended up calling schatz bearing company to find the correct number
of the bearing. The number cs2170 in Spruce and Univair on line cat.
were near $30 each, but listed under cs3906. After looking in the
spruce paper catalog I found that hard to believe. I called and
Schatz told me that it was a special order bearing and only made in
large lots of 1500 or more, and that univair was the last to have a
lot made, and the proper number was in fact cs3906
I ordered 10 from Univair at $28.50 each, that's a lower price than
the listed price at Spruce. This leads me to believe that Spruce is
buying them from Univair.'
Posted: Sun Feb 10, 2002 9:36 am
by OldOOwl@aol.com
'Thanks Tom and Jamie...
Looks like the $6.70 price was too good to be true.
Will be stuck with Univair.
Richard
