Page 1 of 2
Expermintal Airworthiness certificate
Posted: Mon Nov 19, 2001 8:24 pm
by Tom Downey
'In 1991 my Fairchild was placed in the EXP. category for the required
hours to certify the STC to place a Warner 165 on where a Warner 145
came off. No one bothered to apply for the certificate to be returned
to the normal category. The logs are signed off as engine changed as
per the STC which is now effective.
The question I have now, in light of pending regulations, (see AVWEB)
would it be better to leave the Fairchild in EXP cat. or try to get
the FAA to relicense it as normal cat?
opinions ??'
Re: Expermintal Airworthiness certificate
Posted: Mon Nov 19, 2001 8:58 pm
by lov2fly28525@cs.com
Several 24s were upgraded from 145 to 165 with field approvals. Mine was
lucky enough to have a Fairchild factory upgrade, so its model was also
changed. I see no reason not to pursue a standard certificate. My opinion
is, the aircraft is worth more in standard catagory.
Al Rice
NC28525
F-24W-41A
Posted: Mon Nov 19, 2001 9:27 pm
by jstreat360@aol.com
Get it back to normal. I would not even consider an Exp F-24 for resale.
Visit my Web Site:
Meet my Family
Posted: Tue Nov 20, 2001 12:51 am
by Tom Downey
> Tom,
resale.
Other than resale I see no advantage to the normal cat. I am an A&P-
IA and can do my own annuals, Any A&P can do a Conformity inspection
on the EXP aircraft.
So what is the advantage of the normal cat. use of 337 to do any
changes? FSDO approval to change the fabric?
I belive it is a buyer perspective thing, and a whole lot more paper
to chase.
Tom D. A&P-IA
http://nc19143.homestead.com/NC19143.html.'
Posted: Tue Nov 20, 2001 1:21 am
by Christopher John Shaker
'Might the experimental status also affect insurance?
Chris Shaker
Sent: Monday, November 19, 2001 10:51 PM
Subject: [fairchildclub] Re: Expermintal Airworthiness certificate
> Tom,
resale.
to chase.
Tom D. A&P-IA
Yahoo! Groups Sponsor
ADVERTISEMENT
Posted: Tue Nov 20, 2001 6:01 am
by Michael Denest
> for the required
> where a Warner 145
> engine changed as
> cat. or try to get
> opinions ??
Tom,
Seek the assistance of an FAA Designated Airworthiness
Representative (DAR). Call your local FSDO for a list
of inspectors in your area. He will help you prepare
a request for an airworthiness certificate and do a
conformity inspection on your airplane. That would
consist of a logbook review and an inspection of the
aircraft.
HTH,
Do You Yahoo!?
Yahoo! GeoCities - quick and easy web site hosting, just $8.95/month.
http://geocities.yahoo.com/ps/info1'
Posted: Tue Nov 20, 2001 6:18 am
by Scott
'Uh, would that be condition inspection vs conformity inspection? I
always thought a conformity inspection was to insure the plane was
equipped/built as per the type certificate +/- STC/Field approvals/ETC.
To bring back the Experimental F24 to Standard, it would have to be
exactly as it came off the production line with the exceptions of
approved mods wouldn't it? I'd be interested in an Experimental F24
just for the fact that I can fix or build any part for it, install it,
put it back in phase 1 (I think), test fly for set period, sign off mod,
all as an owner. Believe all I'd need was an A&P to sign off the annual
condition inspection once a year.
Scott
> > Tom,
> resale.
> to chase.
> Tom D. A&P-IA
Scott
Building RV-4
Gotta Fly or Gonna Die!'
Posted: Tue Nov 20, 2001 6:33 am
by Michael Denest
> inspection? I
> the plane was
> would have to be
> exceptions of
> Experimental F24
> for it, install it,
> sign off the annual
> Scott
Scott,
To change a normal category aircraft to experimental
you must have the justification to do so (i.e. Warner
165 installation). You would need to do engineering
for your mod, prepare a test program, document your
test data, fly x amount of hours, hire a DER, etc.
How many dollars do you have to do this? I'm not
trying to be sarcastic but why go through all this
crap just to get out of an annual inspection each
year? What would an experimental category
certification do that a FAA Form 337 Major Alteration
can't do? Think about it before you put yourself
through a bunch of aggravation. If you really want to
do that, design or purchase a set of plans for a
homebuilt. As the builder, you can recieve a
Repairman Certificate from FAA and you can do whatever
you want as long as the change is airworthy.
HTH,
Do You Yahoo!?
Posted: Tue Nov 20, 2001 6:52 am
by Scott
'Hi Mike,
Actually I was responding to someone who has an Experimental F24 and
wants to return it to standard category. Being that it is already
experimental, I was just saying that I personally would be interested in
an experimental F24. I would never go through making a certified
anything into an experimental something. I am building an RV-4 and own
a Corben at present. I don't have an experimental just to get out of
annual inspections...I have to have a condition inspection every 12
months like everyone else. I like the latitude to be able to add or
subtract parts ;) The only thing I don't like about 337's is the cost
of the IA filling out the paperwork and the FAA having to approve it.
Experimentals bypass these two stages of bureaucracy. I didn't take
your post as sarcastic at all. Good healthy conversation cleanses the
soul :)
Michael Denest wrote:
> > inspection? I
> > the plane was
> > would have to be
> > exceptions of
> > Experimental F24
> > for it, install it,
> > sign off the annual
> > Scott
> Scott,
> HTH,
> Mike
> Do You Yahoo!?
Scott
Building RV-4
Posted: Tue Nov 20, 2001 8:40 am
by Michael Denest
'--- Scott wrote:
> Hi Mike,
> it is already
> making a certified
> just to get out of
> inspection every 12
> be able to add or
> 337's is the cost
> soul :)
Hey! Not a problem! I've had that situation where
someone wanted to put a C-172 into the experimental
category just so he could get it into the air quicker.
I explained to him just how much bull he had to go
through and then there was no guarantee that FAA would
bless it. He saw the error of his ways and went
through the process of obtaining a normal category
airworthiness certificate. Happy flying and have a
good holiday. :-)
Do You Yahoo!?
