Re: need inner tube
Posted: Fri Oct 05, 2001 8:51 pm
by lov2fly28525@cs.com
'I believe Desser Tire has these for a price.
www.desser.com. I put the
R-R-R-Russ Aircraft STC (
www.russaircraft.com) on my tailwheel with no
regrets. Less expensive in the long run.
AL Rice
Meridian, Idaho
NC28525
Re: need inner tube
Posted: Fri Oct 05, 2001 8:53 pm
by jstreat360@aol.com
'John,
No 90 degree stem, call Desser Tire. They have the tubes, not cheap $110.00
per copy and going up. They may have the short stem type in stock, see the
latest Fairchild Flyer issue, same subject. Also if you have a torn stem, get
a new one vulcanized on. Did mine two weeks ago, $5.00 repair with short stem.
Visit my Web Site:
Meet my Family
Re: need inner tube
Posted: Sat Oct 06, 2001 7:37 am
by Marge & John Berendt
'John
Jamie Treat is right. Have a short stem vulcanized on. I did this on my PT
and I use a stem extension when I need to put air in the tire. Stole the
extensio of my wifes thunderbird.
Sent: Friday, October 05, 2001 9:36 PM
Subject: [fairchildclub] need inner tube
> Where can we get inner tube for 10:00SC tail wheel. (must have 90 bend on
> stem.
> Thanks
> John
Re: need inner tube
Posted: Sat Oct 06, 2001 7:39 am
'Al,
How has the STC from Russ working out? When Russ first contacted me I
thought it was a good idea. It should also help with any shimmy in the tail
wheel.
Sent: Friday, October 05, 2001 9:51 PM
Subject: Re: [fairchildclub] need inner tube
> AL Rice
> Meridian, Idaho
> NC28525
Re: need inner tube
Posted: Sat Oct 06, 2001 8:40 am
by Dorothy Haas
'-----Original Message-----
mjbfchld@rconnect.com]
Sent: Saturday, October 06, 2001 7:49 AM
fairchildclub@yahoogroups.com
Al,
wheel.
Re: need inner tube
Posted: Sat Oct 06, 2001 5:13 pm
'My airplane (almost) has no shimmy. The STC installs a standard 10/4 tire.
I believe that more tread surface on the ground reduces the chance of a
shimmy and helps steering when you need it the most.
Al Rice
Meridian, Idaho
NC28525
Re: need inner tube
Posted: Sat Oct 06, 2001 6:13 pm
by wbaf1595@att.net
'desser tires has the tube with the 90 degree bend. I am
using it on my 24.
> John
> John Berendt
> From: "John Ellis"
> > stem.
> > Thanks
> > John
Re: need inner tube
Posted: Thu Oct 18, 2001 2:12 pm
by bt13a@earthlink.net
'With the inner tube I got from Desser I was always able to push the
stem over get the cover plate in place.
However, the Russ conversion is a great way to go and the stem is even
shorter. Required the extension(not stolen from my wife's T-bird) to
fill though. When pointed straight out it was mostly within the wheel
cavity.
Nice to be able to get tubes and tires at any supply place. Does
appear to help a bit with the shimmy too.
> > From: "John Ellis"
> > To:
90 bend on
> > > stem.
> > > Thanks
> > > John
> > > fairchildclub-unsubscribe@y...
