F24
Posted: Sat May 19, 2001 7:43 pm
'CAN ANY BODY WHO, ACTUALLY HAS A 24 WITH A W-670 OR A JAKE IN IT
PLEASE CONTACT ME THANKS MIKE GROSS PARIS ILL.'
A Forum for all interested in vintage Fairchild Aircraft
https://board.fairchild-club.org/
'--- In fairchildclub@yahoogroups.com, barry roberts wrote:
> Hello, does anyone know where I can get the "C" springs for the glove
> compartment door? Also does anyone have a copy of a weight and balance sheet
> for an F24R46? I have found the note that tells one that the datum is the
> leading edge of the wing and the type certificate data sheets list the c.g.
> range for each model, but thats all the info they are going to give you, I guess
> pilots back then didn't care about weight and balance. This is my first
> aircraft restoration, much more difficult than restoring an old car, can't go
> down to the NAPA store and get parts, though I finally figured out that all the
> interior handles, knobs, and other bits are from a 1937 FORD and repros are
> readily available from several sources. I just ordered a "C" spring for a Ford
> and it is not the correct one, that bit of information cost me $20. thanks,
> Barry
'--- In fairchildclub@yahoogroups.com, David wrote:
> Does anyone know were I can find a set of wings that may be repairable?
David
