VB: Eclpise starter
Posted: Sun May 06, 2001 11:57 am
by paul pinato
To: fairchild group
Sent: Sunday, April 29, 2001 9:28 PM
Subject: Eclpise starter
Hej
Thank you for the suggestion Eric about my mixture control. I had in mind just something like that. A friend gave me some controls from a Beechraft which and there is a friction that maybe fitts. If it does I keep you posted.
Now I am doing my starter seal in acc. with Glens modification. The Warner has the Eclipse E80 Type 756 model 6 starter. It was full of old oil and leakind in to the electric part. I plan to change the bearing between the gearchase and the rotor to a saeled one ( a Z bearing ).
I wonder. Wath kind of grease or oil do you use for the gears.
On the data plate the info about the slip clutch torque is illegible. Can somebody help me with the torque value.
paul
PS
let me know if you kan se the atached picture over my inst.panel
VB: Eclpise starter
Posted: Sun May 06, 2001 12:03 pm
by paul pinato
To: fairchild group
Hej
paul
PS
