Sent: Saturday, April 14, 2001 6:58 PM
Subject: Re: [fairchildclub] Voltage Regulators
> Just like to throw some else in. If you have a 12 amp generator and
> regulator combination and you load exceeds 12 amp, all that will happen is
> that the generator will be kicked off line by the regulator. When the
load
> on the generator decreases below 12 amps, the generator will come back on
> line.
> From: WALTER ALBERT
> Sent: Saturday, April 14, 2001 6:04 PM
> > if you will be using the grimes 250 landing light the 12 amp generator
is
> > not too good. the landing light takes 17 amps. jasco alternator will
> > replace the generator. the generator is also a good radio noise
> > generator...walt
> > From: Robert Lloyd
> > To:
> > Sent: Saturday, April 14, 2001 6:07 PM
> > Subject: [fairchildclub] Voltage Regulators
> > > What kind of voltage regulators are people using with the Ranger
> > > Engineering Corp. 14 volt, 12 amp generator? Will a 12 volt
> > > automotive regulator work?
> > > Bob Lloyd
> > > To unsubscribe from this group, send an email to:
> > > Your use of Yahoo! Groups is subject to
