Re: Prop Hub
Curt Kinchen
Re: Prop Hub
Post by Curt Kinchen »
'Should have been attached. Wonder if your email service stripped the files
off? I'll try again....
>From: "ranger440c5"
>Reply-To: fairchildclub@yahoogroups.com
>Subject: [fairchildclub] Re: Prop Hub
>Date: Tue, 15 Aug 2006 17:11:28 -0000
>Curt,
> Pardon my ignorance.....where is the attachment with the cone
>specs? I am failing to find it!!
>--- In fairchildclub@yahoogroups.com, "Curt Kinchen"
>wrote:
> > I have also seen both. Some seem to have the straight section to
>account
> > for the spacer sometimes necessary with small hubs, etc.
>Interestingly they
> > carry the same AN5008-20 number.
> > Here's the specs for the cones attached.
> > >From: "ranger440c5"
> > >Date: Tue, 15 Aug 2006 15:30:29 -0000
> > >That is correct. They still use the AN5008-20 bronze rear cone.
>But
> > >none of the AN50XX series parts fit...front cone, nut, retaining
> > >ring, bolts, nuts, etc. Thanks for posting the data, I had not
>seen
> > >that before and it is helpfull with a #30 I am trying to ID. Would
> > >you have a chart or specs on the AN5008-XX rear cones? Am curious
> > >about these as have seen two types, one with a fully tapered OD
>and
> > >one with a tapered seat about 1/2" long and then a straight OD for
> > >the remaining length. Wouldn't have data on this would you?
> > >wrote:
> > > > It does sound correct to me. My recollection is also that the
> > >small hubs do
> > > > not use
> > > > a front cone. The AN5017 I posted is simply for a visual
>reference
> > >(not
> > > > dimensional). The cones used on it are, however, correct for
>the
> > >hubs used
> > > > on the Ranger.
> > > > Curt Kinchen
> > > > >From: "ranger440c5"
> > > > >Date: Tue, 15 Aug 2006 14:48:40 -0000
> > > > >I am chiming in a bit late here but perhaps here is something
>of
> > > > >use..... There may be confusion among #20 wood prop hubs.
>Correct
> > >me
> > > > >if I am wrong but the file loaded for the AN5017 hub design is
> > > > >for "long" #20 spline hubs, commonly called "Air Corps".
>These are
> > > > >for Continental W670, Jacobs, and Wrights. The Warner 145,165
>and
> > > > >Ranger "L" series used a "short" #20 spline. The long is
>capable
> > >of
> > > > >carrying a 6.5" thick prop hub and the short 4.5" hub. You
>will
> > >see
> > > > >this on the Sensenich 86AB 54 prop, it has big lumps to get
>the
> > > > >airfoil at the hub area and then chopped down to get to the
>4.5"
> > > > >flange to flange dimension for the Ranger short hub. All the
>short
> > > > >hubs I have seen do not use a front cone, there is instead a
> > >single
> > > > >ring to slip on to the crank and then the nut, thus the nut
>will
> > > > >not "pull" the hub when removing. To verify all this the
>simple
> > > > >thing one must look at is the bolt diameter....the long #20
>has
> > > > >7/16bolts and the short has 3/8 bolts.
> > > > > The wild card in all this is there was a pre-war hub that
>looks
> > > > >like the manual with the solid flange on the front and the
>crush
> > > > >plate on the rear. I have seen one of these on a Ranger 24 in
>KY
> > > > >(owner: Webster?).This one I do not know if used a front cone
>or
> > >not.
> > > > > You would never even get an AN 5017 hub on a Ranger as they
>are
> > >way
> > > > >too long, a solid 1.5" too long. I don't believe Ranger ever
>used
> > >a
> > > > >#10...they originally had tapered then went to the short 20.
> > > > > Does all this sound correct?
> > > > >--- In fairchildclub@yahoogroups.com, "Tom Mueller"
> > > > > > wrote:
> > > > > > > I've added in the Files area the AN5017 prop hub spec.
>It's
> > > > > > > representative of the Warner hubs(large) used on the
>Ranger.
> > > > > > > Curt Kinchen
> > > > > > Thanks Curt,
> > > > > > I'm laboring over the schematics now. I'm not ready to buy
>a
> > >whole
> > > > >new
> > > > > > hub setup, but it's sure starting to look like I have a
>SAE
> > >#10
> > > > > > hanging on the nose of this Fairchild. It has a metal tag
> > > > >indicating
> > > > > > it's a Warner
> > > > > > Part # 8599 (an alternate hub for the 9700) and it's
>supposed
> > >to
> > > > >have
> > > > > > a special front cone, Part # 8587.
> > > > > > I just don't know what that part is quite yet.
> > > > > > Tom
> > [Non-text portions of this message have been removed]
Tom Mueller
Re: Prop Hub
Post by Tom Mueller »
'Hey members,
Thanks for all the information.
I just got off the phone with Charley at Sensenich . Very, very
helpful . He was able to bring up a schematic of my Warner Hub
(Warner Aircraft Part # 8599) The drawing I saw earlier in the
Prewar parts manual had me all turned around. So to be correct
according to schematic Sensenich has the crush plate does go on the
front. There is no cone on front of this model, just a pressed in
Aluminum Bronze bushing. There is a cone and spacer on the engine side
which is usually the case. He had a full set of correct bolts that I
bought, no cones however. There, I'm putting this little episode to
rest.
Tom'
