Page 2 of 3
Re: Hydraulic Brake Hose
Posted: Fri Mar 23, 2018 7:25 am
by Pete Crawford
' Thanks for the reply.
It seems everyone sells inverted flare fittings;  the problem is that the other end of the fitting is always a pipe thread.  Even if you use the old fitting on the new hose, you will still have to have it fitted with an 11/16 x 16 female thread, and no one seems to have that.
The easy solution is to use a conventional hose with B-nuts on each end and join with unions.
Pete Crawford
On 3/23/2018 04:47, Emil Dular wd4scz@aol.com [fairchildclub] wrote:
http://ph.parker.com/us/27601/en/brass-inverted-flare-fittings
Parker still makes'em,  you may have to hunt the auto parts places to find them. Piper used them a lot through the Sixties as well.
Emil in Kentucky
On 23-Mar-18 00:47, Francis Cox frankjcox44@gmail.com [fairchildclub] wrote:
Sorry - we are in New Zealand at present on vacation but it was many years ago that I got them just for the brake master  cylinders on my UC61K - everything else is AN - there surely must be such shops in the US..
Frank
Sent from my iPhone
On 22 Mar 2018, at 23:37, Pete Crawford pcrawford262@gmail.com [fairchildclub] wrote:
Do you have the name of a specific shop?
Pete Crawford
On 3/22/2018 00:52, Francis Cox frankjcox44@gmail.com [fairchildclub] wrote:
I found inverted flares in a classic car parts shop - that was in UK - maybe worth a try.
Frank
Sent from my iPhone
On 22 Mar 2018, at 12:20, Ranchaero Wing Shop david@ranchaerowingshop.com [fairchildclub] wrote:
You're probably referring to the "inverted flare" (I think it's called) fittings used on the PT brake lines. I tried to find some new ones and failed. I ended up modernizing the brake system with C-310 Cleveland wheels and brakes which is why I could get the hoses from Aero Performance using AN fittings except for the two master cylinders fittings.
I'm still working on this conversion. The big problem is finding rubber parts for 5606 fluid that fit the goodyear master cylinders. Automotive brake kits rubber parts not compatible with 5606 fluid. Dot 5 silicon fluid works with auto brake kits and clevelend brakes, but because I do a lot of painting, I'm not willing to risk silicon contamination in my shop. Dot 3 and 4 eat paint and are great paint strippers. The 5606 conversion is ultimately the better solution IMO.
It would be great to find a modern aircraft master cylinder that would work in the PT without major modification. Anyone know of one?
David
On 03/21/2018 01:26 PM, George Michael Drebo gdrebo@yahoo.com [fairchildclub] wrote:
  All, thanks for the info.  I've tried all the suggested vendors and "No Joy"!  If anyone has any leads, please respond.
Michael Drebo 832 691-0911 Magnolia, TX
On ?Wednesday?, ?March? ?21?, ?2018? ?11?:?49?:?02? ?AM? ?CDT, Pete Crawford pcrawford262@gmail.com [fairchildclub] fairchildclub@yahoogroups.com wrote:
Michael,
Let me know how this works out.  I contacted two shops, A.E.R.O. hose shop in Granite City, IL and Specialty Hose in Akron, OH.  I sent a hose to A.E.R.O. for duplication, and they returned it without explanation.  I sent Specialty Hose some pics after talking with the rep there, and never heard back from them.  I think the flare inside the fitting has them stumped as it's not a real B-nut connection.
I (obviously) still need help with this.  Have other PT owners changed their hose configuration to a more modern design?
Pete Crawford
On 3/21/2018 12:10, Ranchaero Wing Shop david@ranchaerowingshop.com [fairchildclub] wrote:
Michael,
I got mine from Aero Performance.  They make custom hoses to order. Quick service. They have a shop in Ft. Worth as well as a few other places.
http://aeroperformance.com
817-624-9882
David
On 03/21/2018 08:10 AM, gdrebo@yahoo.com [fairchildclub] wrote:
Does anyone know of a supplier/manufacturer for the rubber hydraulic hose located near the wheel strut scissor, which connects the metal brake lines?  Thanks in advance!
Posted: Fri Mar 23, 2018 6:02 pm
by Charles Bellenie
'Most Parker stores ( I forget the franchise name at the moment) will custom make whatever hose you want - just give them the length, fittings, diameter, pressure rating, and fluid and they should be able to get something together for you. Just don’t tell them it’s going on an airplane!
CharlieNC9712K
Sent from my iPhone
On Mar 23, 2018, at 06:23, Pete Crawford pcrawford262@gmail.com [fairchildclub] wrote:
Pete Crawford
Emil in Kentucky
Frank
Sent from my iPhone
Pete Crawford
Frank
Sent from my iPhone
David
Michael,
Pete Crawford
Michael,
817-624-9882
David
Posted: Fri Mar 23, 2018 8:24 pm
by Ranchaero Wing Shop
' They are listed in the Parker catalog, but when I contacted Parker to order, after much repeat calling and leaving messages for people who were "out to lunch," or "away from their desk," never returning my calls, finally after much persistence they said they didn't have any and would not have any in the future. The people at Parker were not very friendly or helpful. And I was very careful to be polite and hide my disappointment with their crappy customer service. Maybe it would work to call again and perhaps get a different rep.
Yes, maybe if you hunt the auto parts stores, maybe you'll find some. Good luck...or as my dad used to say, "Rotsa ruck."
Maybe the classic car guys could help. I finally gave up and am modernizing mine. Not without it's own set of challenges.
David
Emil in Kentucky
Frank
Sent from my iPhone
Pete Crawford
Frank
Sent from my iPhone
David
Michael,
Pete Crawford
Michael,
817-624-9882
David
Posted: Sat Mar 24, 2018 12:23 am
by robert Etter
' If my memory serves me correct Parker, sold a tube beading kit.  The fact of the hand beading kit used knobs that are, at least on my set, are exactly the same as those used on the control sticks of the late model 24's.   There is only 1 minor difference.  The thread of the stud is the same.  The 24's knob has a short threaded stud, but that used on the Parker tools are female.  Except for the stud, the knobs are identical.Bob
On ?Friday?, ?March? ?23?, ?2018? ?07?:?24?:?18? ?PM? ?PDT, Ranchaero Wing Shop david@ranchaerowingshop.com [fairchildclub] wrote:
David
Emil in Kentucky
Frank
Sent from my iPhone
Pete Crawford
Frank
Sent from my iPhone
David
Michael,
Pete Crawford
Michael,
817-624-9882
David
#ygrps-yiv-2036099492 #ygrps-yiv-2036099492yiv9420863967 #ygrps-yiv-2036099492yiv9420863967 -- #ygrps-yiv-2036099492yiv9420863967ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;} #ygrps-yiv-2036099492 #ygrps-yiv-2036099492yiv9420863967 #ygrps-yiv-2036099492yiv9420863967ygrp-mkp hr { border:1px solid #d8d8d8;} #ygrps-yiv-2036099492 #ygrps-yiv-2036099492yiv9420863967 #ygrps-yiv-2036099492yiv9420863967ygrp-mkp #ygrps-yiv-2036099492yiv9420863967hd { color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;} #ygrps-yiv-2036099492 #ygrps-yiv-2036099492yiv9420863967 #ygrps-yiv-2036099492yiv9420863967ygrp-mkp #ygrps-yiv-2036099492yiv9420863967ads { margin-bottom:10px;} #ygrps-yiv-2036099492 #ygrps-yiv-2036099492yiv9420863967 #ygrps-yiv-2036099492yiv9420863967ygrp-mkp .ygrps-yiv-2036099492yiv9420863967ad { padding:0 0;} #ygrps-yiv-2036099492 #ygrps-yiv-2036099492yiv9420863967 #ygrps-yiv-2036099492yiv9420863967ygrp-mkp .ygrps-yiv-2036099492yiv9420863967ad p { margin:0;} #ygrps-yiv-2036099492 #ygrps-yiv-2036099492yiv9420863967 #ygrps-yiv-2036099492yiv9420863967ygrp-mkp .ygrps-yiv-2036099492yiv9420863967ad a { color:#0000ff;text-decoration:none;} #ygrps-yiv-2036099492 #ygrps-yiv-2036099492yiv9420863967 #ygrps-yiv-2036099492yiv9420863967ygrp-sponsor #ygrps-yiv-2036099492yiv9420863967ygrp-lc { font-family:Arial;} #ygrps-yiv-2036099492 #ygrps-yiv-2036099492yiv9420863967 #ygrps-yiv-2036099492yiv9420863967ygrp-sponsor #ygrps-yiv-2036099492yiv9420863967ygrp-lc #ygrps-yiv-2036099492yiv9420863967hd { margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;} #ygrps-yiv-2036099492 #ygrps-yiv-2036099492yiv9420863967 #ygrps-yiv-2036099492yiv9420863967ygrp-sponsor #ygrps-yiv-2036099492yiv9420863967ygrp-lc .ygrps-yiv-2036099492yiv9420863967ad { margin-bottom:10px;padding:0 0;} #ygrps-yiv-2036099492 #ygrps-yiv-2036099492yiv9420863967 #ygrps-yiv-2036099492yiv9420863967actions { font-family:Verdana;font-size:11px;padding:10px 0;} #ygrps-yiv-2036099492 #ygrps-yiv-2036099492yiv9420863967 #ygrps-yiv-2036099492yiv9420863967activity { background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;} #ygrps-yiv-2036099492 #ygrps-yiv-2036099492yiv9420863967 #ygrps-yiv-2036099492yiv9420863967activity span { font-weight:700;} #ygrps-yiv-2036099492 #ygrps-yiv-2036099492yiv9420863967 #ygrps-yiv-2036099492yiv9420863967activity span:first-child { text-transform:uppercase;} #ygrps-yiv-2036099492 #ygrps-yiv-2036099492yiv9420863967 #ygrps-yiv-2036099492yiv9420863967activity span a { color:#5085b6;text-decoration:none;} #ygrps-yiv-2036099492 #ygrps-yiv-2036099492yiv9420863967 #ygrps-yiv-2036099492yiv9420863967activity span span { color:#ff7900;} #ygrps-yiv-2036099492 #ygrps-yiv-2036099492yiv9420863967 #ygrps-yiv-2036099492yiv9420863967activity span .ygrps-yiv-2036099492yiv9420863967underline { text-decoration:underline;} #ygrps-yiv-2036099492 #ygrps-yiv-2036099492yiv9420863967 .ygrps-yiv-2036099492yiv9420863967attach { clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;} #ygrps-yiv-2036099492 #ygrps-yiv-2036099492yiv9420863967 .ygrps-yiv-2036099492yiv9420863967attach div a { text-decoration:none;} #ygrps-yiv-2036099492 #ygrps-yiv-2036099492yiv9420863967 .ygrps-yiv-2036099492yiv9420863967attach img { border:none;padding-right:5px;} #ygrps-yiv-2036099492 #ygrps-yiv-2036099492yiv9420863967 .ygrps-yiv-2036099492yiv9420863967attach label { display:block;margin-bottom:5px;} #ygrps-yiv-2036099492 #ygrps-yiv-2036099492yiv9420863967 .ygrps-yiv-2036099492yiv9420863967attach label a { text-decoration:none;} #ygrps-yiv-2036099492 #ygrps-yiv-2036099492yiv9420863967 blockquote { margin:0 0 0 4px;} #ygrps-yiv-2036099492 #ygrps-yiv-2036099492yiv9420863967 .ygrps-yiv-2036099492yiv9420863967bold { font-family:Arial;font-size:13px;font-weight:700;} #ygrps-yiv-2036099492 #ygrps-yiv-2036099492yiv9420863967 .ygrps-yiv-2036099492yiv9420863967bold a { text-decoration:none;} #ygrps-yiv-2036099492 #ygrps-yiv-2036099492yiv9420863967 dd.ygrps-yiv-2036099492yiv9420863967last p a { font-family:Verdana;font-weight:700;} #ygrps-yiv-2036099492 #ygrps-yiv-2036099492yiv9420863967 dd.ygrps-yiv-2036099492yiv9420863967last p span { margin-right:10px;font-family:Verdana;font-weight:700;} #ygrps-yiv-2036099492 #ygrps-yiv-2036099492yiv9420863967 dd.ygrps-yiv-2036099492yiv9420863967last p span.ygrps-yiv-2036099492yiv9420863967yshortcuts { margin-right:0;} #ygrps-yiv-2036099492 #ygrps-yiv-2036099492yiv9420863967 div.ygrps-yiv-2036099492yiv9420863967attach-table div div a { text-decoration:none;} #ygrps-yiv-2036099492 #ygrps-yiv-2036099492yiv9420863967 div.ygrps-yiv-2036099492yiv9420863967attach-table { width:400px;} #ygrps-yiv-2036099492 #ygrps-yiv-2036099492yiv9420863967 div.ygrps-yiv-2036099492yiv9420863967file-title a, #ygrps-yiv-2036099492 #ygrps-yiv-2036099492yiv9420863967 div.ygrps-yiv-2036099492yiv9420863967file-title a:active, #ygrps-yiv-2036099492 #ygrps-yiv-2036099492yiv9420863967 div.ygrps-yiv-2036099492yiv9420863967file-title a:hover, #ygrps-yiv-2036099492 #ygrps-yiv-2036099492yiv9420863967 div.ygrps-yiv-2036099492yiv9420863967file-title a:visited { text-decoration:none;} #ygrps-yiv-2036099492 #ygrps-yiv-2036099492yiv9420863967 div.ygrps-yiv-2036099492yiv9420863967photo-title a, #ygrps-yiv-2036099492 #ygrps-yiv-2036099492yiv9420863967 div.ygrps-yiv-2036099492yiv9420863967photo-title a:active, #ygrps-yiv-2036099492 #ygrps-yiv-2036099492yiv9420863967 div.ygrps-yiv-2036099492yiv9420863967photo-title a:hover, #ygrps-yiv-2036099492 #ygrps-yiv-2036099492yiv9420863967 div.ygrps-yiv-2036099492yiv9420863967photo-title a:visited { text-decoration:none;} #ygrps-yiv-2036099492 #ygrps-yiv-2036099492yiv9420863967 div#ygrps-yiv-2036099492yiv9420863967ygrp-mlmsg #ygrps-yiv-2036099492yiv9420863967ygrp-msg p a span.ygrps-yiv-2036099492yiv9420863967yshortcuts { font-family:Verdana;font-size:10px;font-weight:normal;} #ygrps-yiv-2036099492 #ygrps-yiv-2036099492yiv9420863967 .ygrps-yiv-2036099492yiv9420863967green { color:#628c2a;} #ygrps-yiv-2036099492 #ygrps-yiv-2036099492yiv9420863967 .ygrps-yiv-2036099492yiv9420863967MsoNormal { margin:0 0 0 0;} #ygrps-yiv-2036099492 #ygrps-yiv-2036099492yiv9420863967 o { font-size:0;} #ygrps-yiv-2036099492 #ygrps-yiv-2036099492yiv9420863967 #ygrps-yiv-2036099492yiv9420863967photos div { float:left;width:72px;} #ygrps-yiv-2036099492 #ygrps-yiv-2036099492yiv9420863967 #ygrps-yiv-2036099492yiv9420863967photos div div { border:1px solid #666666;min-height:62px;overflow:hidden;width:62px;} #ygrps-yiv-2036099492 #ygrps-yiv-2036099492yiv9420863967 #ygrps-yiv-2036099492yiv9420863967photos div label { color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;} #ygrps-yiv-2036099492 #ygrps-yiv-2036099492yiv9420863967 #ygrps-yiv-2036099492yiv9420863967reco-category { font-size:77%;} #ygrps-yiv-2036099492 #ygrps-yiv-2036099492yiv9420863967 #ygrps-yiv-2036099492yiv9420863967reco-desc { font-size:77%;} #ygrps-yiv-2036099492 #ygrps-yiv-2036099492yiv9420863967 .ygrps-yiv-2036099492yiv9420863967replbq { margin:4px;} #ygrps-yiv-2036099492 #ygrps-yiv-2036099492yiv9420863967 #ygrps-yiv-2036099492yiv9420863967ygrp-actbar div a:first-child { margin-right:2px;padding-right:5px;} #ygrps-yiv-2036099492 #ygrps-yiv-2036099492yiv9420863967 #ygrps-yiv-2036099492yiv9420863967ygrp-mlmsg { font-size:13px;font-family:Arial, helvetica, clean, sans-serif;} #ygrps-yiv-2036099492 #ygrps-yiv-2036099492yiv9420863967 #ygrps-yiv-2036099492yiv9420863967ygrp-mlmsg table { font-size:inherit;font:100%;} #ygrps-yiv-2036099492 #ygrps-yiv-2036099492yiv9420863967 #ygrps-yiv-2036099492yiv9420863967ygrp-mlmsg select, #ygrps-yiv-2036099492 #ygrps-yiv-2036099492yiv9420863967 input, #ygrps-yiv-2036099492 #ygrps-yiv-2036099492yiv9420863967 textarea { font:99% Arial, Helvetica, clean, sans-serif;} #ygrps-yiv-2036099492 #ygrps-yiv-2036099492yiv9420863967 #ygrps-yiv-2036099492yiv9420863967ygrp-mlmsg pre, #ygrps-yiv-2036099492 #ygrps-yiv-2036099492yiv9420863967 code { font:115% monospace;} #ygrps-yiv-2036099492 #ygrps-yiv-2036099492yiv9420863967 #ygrps-yiv-2036099492yiv9420863967ygrp-mlmsg * { line-height:1.22em;} #ygrps-yiv-2036099492 #ygrps-yiv-2036099492yiv9420863967 #ygrps-yiv-2036099492yiv9420863967ygrp-mlmsg #ygrps-yiv-2036099492yiv9420863967logo { padding-bottom:10px;} #ygrps-yiv-2036099492 #ygrps-yiv-2036099492yiv9420863967 #ygrps-yiv-2036099492yiv9420863967ygrp-msg p a { font-family:Verdana;} #ygrps-yiv-2036099492 #ygrps-yiv-2036099492yiv9420863967 #ygrps-yiv-2036099492yiv9420863967ygrp-msg p#ygrps-yiv-2036099492yiv9420863967attach-count span { color:#1E66AE;font-weight:700;} #ygrps-yiv-2036099492 #ygrps-yiv-2036099492yiv9420863967 #ygrps-yiv-2036099492yiv9420863967ygrp-reco #ygrps-yiv-2036099492yiv9420863967reco-head { color:#ff7900;font-weight:700;} #ygrps-yiv-2036099492 #ygrps-yiv-2036099492yiv9420863967 #ygrps-yiv-2036099492yiv9420863967ygrp-reco { margin-bottom:20px;padding:0px;} #ygrps-yiv-2036099492 #ygrps-yiv-2036099492yiv9420863967 #ygrps-yiv-2036099492yiv9420863967ygrp-sponsor #ygrps-yiv-2036099492yiv9420863967ov li a { font-size:130%;text-decoration:none;} #ygrps-yiv-2036099492 #ygrps-yiv-2036099492yiv9420863967 #ygrps-yiv-2036099492yiv9420863967ygrp-sponsor #ygrps-yiv-2036099492yiv9420863967ov li { font-size:77%;list-style-type:square;padding:6px 0;} #ygrps-yiv-2036099492 #ygrps-yiv-2036099492yiv9420863967 #ygrps-yiv-2036099492yiv9420863967ygrp-sponsor #ygrps-yiv-2036099492yiv9420863967ov ul { margin:0;padding:0 0 0 8px;} #ygrps-yiv-2036099492 #ygrps-yiv-2036099492yiv9420863967 #ygrps-yiv-2036099492yiv9420863967ygrp-text { font-family:Georgia;} #ygrps-yiv-2036099492 #ygrps-yiv-2036099492yiv9420863967 #ygrps-yiv-2036099492yiv9420863967ygrp-text p { margin:0 0 1em 0;} #ygrps-yiv-2036099492 #ygrps-yiv-2036099492yiv9420863967 #ygrps-yiv-2036099492yiv9420863967ygrp-text tt { font-size:120%;} #ygrps-yiv-2036099492 #ygrps-yiv-2036099492yiv9420863967 #ygrps-yiv-2036099492yiv9420863967ygrp-vital ul li:last-child { border-right:none !important;} #ygrps-yiv-2036099492 '
Posted: Sun Mar 25, 2018 1:37 pm
by John Ellis
'Make up an Aeroquip hose for each size, connect hoses using a AN919-
fitting. Don't remember hose size..
Works fine.. John Ellis
Sent from my iPhone
Begin forwarded message:
> *From:* "Ranchaero Wing Shop david@ranchaerowingshop.com
> [fairchildclub]"
> *Date:* March 21, 2018 at 6:20:23 PM CDT
> *To:* fairchildclub@yahoogroups.com
> *Subject:* *Re: [fairchildclub] Hydraulic Brake Hose*
> *Reply-To:* fairchildclub@yahoogroups.com
> fittings.
> David
>> Thanks,
>> Michael Drebo
>> 832 691-0911
>> Magnolia, TX
>> wrote:
>> Michael,
>> Thanks,
>> Pete Crawford
>>> Michael,
>>> places.
>>> 817-624-9882
>>> David
>>>> Michael Drebo
>>>> 832 691-0911
>>>> Magnolia, TX
Posted: Sun Mar 25, 2018 7:54 pm
by Pete Crawford
-5   that's what I'm doing.
Sent from my iPhone
> david@ranchaerowingshop.com [fairchildclub]"
> *To:* fairchildclub@yahoogroups.com fairchildclub@yahoogroups.com
> fittings.
> David
>> Thanks,
>> Michael Drebo
>> 832 691-0911
>> Magnolia, TX
>> Michael,
>> Let me know how this works out.  I contacted two shops, A.E.R..O. hose
>> Thanks,
>> Pete Crawford
>>> Michael,
>>> places.
>>> 817-624-9882
>>> David
>>> On 03/21/2018 08:10 AM, gdrebo@yahoo.com gdrebo@yahoo.com
>>>> Michael Drebo
>>>> 832 691-0911
>>>> Magnolia, TX
Magneto couplings
Posted: Tue Jun 11, 2019 9:18 am
by Emil Dular
'Have a 24-C8F in the shop and the rubber magneto couplings are shrunk,
dried out and harder than Chinese arithmetic.?? The Ranger part number is
6474.?? Anyone have spares or know of a source? Fresno Air Parts has the
metal has the 6363 coupling.?? It is similar in appearance to the rubber
coupling used on the P&W 985 and 1340, but don't have one handy to
compare??? Are they interchangeable? Since J&C in Benton is gone it's
been rougher fining stuff.
Emil in Kentucky'
Re: Magneto couplings
Posted: Tue Jun 11, 2019 10:02 am
by Seifert
'Emil, I have several NOS Ranger mag drive couplings, but all are dried up and hard. If you can find a technical drawing for them, you may be better off having new ones manufactured.I know I would be interested in fresh couplings.
Image Virus-free. www.avast.com
On Tue, Jun 11, 2019 at 8:19 AM Emil Dular wd4scz@aol.com [fairchildclub] wrote:
Emil in Kentucky
Posted: Wed Jun 12, 2019 8:40 pm
by cagog
'I have the drawing for the 6474 coupling.'
Posted: Thu Jun 13, 2019 6:23 am
by Emil Dular
I would be interested in a copy of the drawing.?? It would be useful in determining if a coupling presently available is compatible.
Emil in Kentucky??
