Re: Spruce Spar Material
Carlos Jobke
Unsubscribe
Post by Carlos Jobke »
'Dear Fairchild Club,
I sadly communicate that my husband Carlos Jobke has passed away. For this
reason I request to please cancel his name from the subscription list.
Best regards,
Silvia Jobke
_____
De: fairchildclub@yahoogroups.com [mailto:fairchildclub@yahoogroups.com] En
nombre de Robert Etter
Enviado el: lunes, 28 de enero de 2013 19:56
Para: fairchildclub@yahoogroups.com
Asunto: [fairchildclub] Re: Spruce Spar Material
From what I am reading, the availability of big pieces of spruce is
definitely getting harder. You might go to the North West and buy yourself a
whole tree, then sell what you don't use.
I got my spars (4 each) 30 years ago. Even then they were laminated. 2
layers, then they were milled down. Nothing very new. I have 2 spars from a
UC-61 and they were at least 6 layers thick before milling. I never have
looked to see how many splices there may be length wise.
I don't even want to think about the cost for them at today's prices.
I am looking forward to covering wings and tail this summer.
--- In fairchildclub@yahoogroups.com
, "Joe Philips" wrote:
> Wow! What magnificant work! The F24 spars look like they're laminated
> vertically, together. I wonder if he does the router work by CNC(!?)
> Then glues the two halfs together. Regardless, nice work! Joe Philips
> (old AC woodwork apprentice)
> > http://www.precisionam.net/aviation_products.php
> > is the web address for Bill.
> > ________________________________
> > From: Jamie Treat
> > To: fairchildclub@yahoogroups.com
> > Sent: Friday, January 25, 2013 12:49 PM
> > Subject: RE: [fairchildclub] Spruce Spar Material
> > Â
> > Rich,
> > Drop Bill a note, see what he is doing.
> > Bill Scheunemann
> > Website: http://woodwings.com
> > Email: mailto:bill%40woodwings.com
> > JST
> > From: mailto:fairchildclub%40yahoogroups.com
> > [mailto:mailto:fairchildclub%40yahoogroups.com]
> > On Behalf Of Richard Seifert
> > Sent: Friday, January 25, 2013 9:30 AM
> > To: mailto:fairchildclub%40yahoogroups.com
> > Subject: Re: [fairchildclub] Spruce Spar Material
> > Thanks to all that responded to this request. It looks like my friend
may
> > have to laminate the spars,
> > Thanks again
> > Rich Seifert
> > ----- Original Message -----
> > From: Richard Seifert
> > To: Fairchild Club
> > Sent: Thursday, January 24, 2013 11:04 AM
> > Subject: [fairchildclub] Spruce Spar Material
> > Does anyone in the club have a Spruce spar supplier they've delt with
> > recently, besides Aircraft Spruce and wicks? One of our builders wants
> > spar
> > material for his F-24 and was told they can't supply pieces that large.
> > Thanks
> > Rich Seifert 909-790-1320
> > [Non-text portions of this message have been removed]
_____
size=1 width="100%" noshade color="#aca899" align=center>
No se encontraron virus en este mensaje.
Comprobado por AVG - www.avg.com
Versión: 2012.0.2221 / Base de datos de virus: 2639/5563 - Fecha de
publicación: 01/28/13
Steve Link
Re: Unsubscribe
Post by Steve Link »
'Mrs. Jobke, we are so sorry for your loss..
To unsubscribe from these posts and group please go to the bottom of this
e-mail and click on "Unsubscribe" and this will remove his name from the
posts.
Again, so sorry for your loss..
On Behalf Of Carlos Jobke
Sent: Monday, January 28, 2013 5:35 PM
Subject: [fairchildclub] Unsubscribe
Best regards,
Silvia Jobke
Craig
Post by Craig »
'At least you guys are not having to deal with a set of spars for a
center section that are about 24 feet in length. My AT-21 has center
section box spars that are more than 4" wide, over 12" deep and just at
24' in length and they taper in two directions. In 1986, I estimated
that the spruce to rebuild the center section was going to be
approaching $10K. When I get close enough to starting the spars, it's
going to require a 53 foot spar table to build them so I don't have to
create some fancy jigs.
Mike and anyone else that has done a PT center section has a pretty good
feel for what I will be going thru.
Aren't big toys fun???
Craig C.'
rw_flyer
Post by rw_flyer »
'The PT center section is a challenge!
The past several years I've been working on a one-piece wing for a 1929 St. Louis Cardinal, which has 38' spars, 1.5" thick and 7" wide, with full routing. The factory spliced to make up the length, I laminated them in two plies as well to get thickness.
One tip for easy to build & level spar table fixtures - buy some surplus warehouse conveyor sections and take out the rollers. Then make a batch of short metal tie rods to bolt the sections together end to end. The conveyor steel frames are sturdy, and the legs are adjustable in height making leveling easy. The sections are 10' long so I have 4 for the Cardinal spars. And you can take the table apart in an hour after you're done!
Date: Tue, 29 Jan 2013 13:01:23 -0600
Subject: Re: [fairchildclub] Re: Spruce Spar Material
Craig C.
steve reber
Post by steve reber »
'Plus a pair of V-770 Rangers on that AT-21...whew!
Craig
Post by Craig »
'Russell: Thanks for the suggestion on the conveyor tables. I'll have to
check on how much dihedral and anhedral there is in the spars before I
get some. It may take going double width to make the dimensions.
Steve: Lots of cylinders....Kinda like 4 PT's in tight formation or a
pair of Mustings in real close....
Craig C.'
