Re: Shoulder Harness mod for Fairchild 24R
Posted: Sun Jan 24, 2010 6:35 pm
'Airy,
My shoulder harness mounts to the cross tube that is above your head and behind your neck. In the event of a crash, it will NOT compress my spine, no matter how short the actual seat is.
I understand your concern about a shoulder harness mounted below the level of the shoulder blades.
I will no longer fly in any aircraft without a shoulder harness. Our old airplanes are quite safe, but in case of a a sudden impact, your face will not survive hard contact with your instrument panel. If you fly without them, I hope that you never need one. They are so cheap and easy to install that we all should have them.
Webster, MN
1939 Fairchild 24K
1940 Taylorcraft BL-65
1941 Piper J-3 Cub
ALL with SHOULDER HARNESSES
Webster, MN
1939 Fairchild 24K
1941 Piper J-3 Cub
'--- In fairchildclub@yahoogroups.com, Airy Millet wrote:
> I understand that a shoulder harness could fit within the plane!
> But I am questionning myself on the way it would work in case of crash!
> What part of the plane will bend, where the harness fixture is, the seat back may not injure you or even the belt itself? etc etc...
> Apart aerobatic aircraft I don't really feel the need of shoulder harness... even on some "utility" plane I flew I found it was quite dangerous, having a seat smaller than the height of you body, and having shoulder harness fixture on the rear seats' belts fisture!! (Seats back being too short, the top of it may injury your vertebral column)....
> The F24R we fly here in France is a UC-61K (argus III), and I think I am going to look deeper in the original documents if there was shoulder harness or not in the USAAF/RAF versions!!
> Airy
> From: bob-jewell@...
> Date: Sun, 24 Jan 2010 17:35:50 -0600
> Subject: Re: [fairchildclub] Shoulder Harness mod for Fairchild 24R
> I guess I don't understand the problem. The tube is probably something to
> do with the wing spars and as I remember it is over an inch diameter. The
> seats don't enter into it. I got the harnesses from Spruce and they fit
> onto the stock seat belts with no problem.
> RRW
> From: "Airy Millet"
> To: "fairchildlist"
> Sent: Sunday, January 24, 2010 4:25 PM
> Subject: RE: [fairchildclub] Shoulder Harness mod for Fairchild 24R
> but do you use orginal seats with such shoulder harness??
> otherwise I will find such arrangement quite dangerous...no?
> Airy
> From: cgalley@...
> Date: Sun, 24 Jan 2010 16:24:29 -0600
> You don't need a 337 nor an STC! look at your AC 21-34
> Cy Galley - Chair, AirVenture Emergency Aircraft Repair
> A service project of EAA Chapter 75 since 1963
> www.eaa75.com
> From: Steve
> Sent: Sunday, January 24, 2010 1:59 PM
> Subject: [fairchildclub] Shoulder Harness mod for Fairchild 24R
> Does anyone have information or copies of previously approved 337's on
> adding shoulder harness's to the pilot and copilot seats? I would like to
> understand what belt and harness combination has been succesful and what was
> used as the attach point. I haven't had much luck locating STC's for the F24
> yet on this subject. Thanks, Steve
> __________________________________________________________
> Découvrez Windows 7 en 7 secondes !
> http://clk.atdmt.com/FRM/go/181574577/direct/01/
> _________________________________________________________________
> Tchattez en direct en en vidéo avec vos amis !
> http://www.windowslive.fr/messenger/
