Re: Ranger exhaust
Posted: Mon Mar 26, 2007 4:46 pm
I could be that the angle is used to deflect the exhaust away from the cowling I have not noticed the difference but I do not know allot about Rangers
Sent: Monday, March 26, 2007 3:54 PM
Subject: [fairchildclub] Re: Ranger exhaust
John,
I did get a member to sell and is sending me an exhaust set with
about 150 hours on it. That solves a big problem, but another
glitch has come up. While removing the exhaust port aluminum
spacers, I noticed the "stamped" serial number and the name "ALCOR"
on the cooling fin were not located in the same position in relation
to each other. . It must be important because there is a very
slight angle difference to the face that mounts to the exhaust
manifold. That could explain the three burnt gaskets found at the
bottom of the spacer where the exhaust manifold flange hooks up.
I find no information on how these spacers are mounted.
Interestingly, the parts manual says of the six spacers, two are
supposed to be stamped part number #6614 and four stamped #6616.
Mine are all #6614 . Can you or another member help me figure this
out..
Hanford,ca
