Page 2 of 3
Re: Rudder pedel covering
Posted: Tue Sep 27, 2005 5:43 pm
by james chybicki
'HI BUELL!
LONG TIME NO HEAR!
OUR PLANE IS READY FOR COVERING THE FUSEALGE! LIFE
SLOWED OUR DEDICATED WORK TIMES ON OUR UC-61K. ANYWAY,
IF YOU HAVE ANY DETAIL PICTURES OF THE STRINGER THAT
RUNS JUST UNDER THE FLAP PULLEYS, ABOVE THE REAR
WINDOWS, AND THE PORT SIDE STRINGERS THAT FOLLOW THE
FRAME TILL IT ENDS, WE HAVE SOME THOUGHTS, AND SECOND
THOUGHTS, THEN THIRD... WOULD BE NICE TO SEE SOMEONE
ELSES SUPERB WORK!
THANKS
JIM CHYBIKCI
HB-690 / 43-14964
--- Buell Powell wrote:
> Brad,
> The spars and tip bows were ok so I didn't
> replace them but I did
> make new ribs and leading edges. I have checked the
> wing tanks for fit and
> they line up very nicely. I think the reason some
> tanks end up too high is
> probably using too thick felt where the tanks rest
> on top of the ribs. I had
> planned on puting an original interior in mine but
> John Berendt called and
> has a turquois interior that he wasn't going to use
> and is sending it to me.
> I think if I paint the outside turquois & white it
> should look very
> nice.Thanks for the information about the rib
> stitching-& good luck covering
> the wings.
> Buell
> From: "windshieldguy2000"
> Sent: Monday, September 26, 2005 11:52 PM
> Subject: [fairchildclub] Re: Rudder pedel covering
> > Thanks for the post, Buell. I'm spending one more
> day in Oklahoma
> > working on my airplane, so it will likely be
> Wednesday before I get
> > you the name of the company that makes the diamond
> plate. Did you
> > build new wings for your airplane? The flap bays
> aren't difficult to
> > cover, but clearance between the bolt heads on the
> top surface of the
> > flaps and the flap bay is a little tight and will
> require lots of
> > trial fitting. You will also want to spend some
> time fitting your
> > fuel tanks before you cover. Mine fit really
> well, but I've seen
> > others that stuck up above the top surface of the
> wing (and into the
> > slipstream of that super-fast airplane) and they
> really took away
> > from the look of the wing.
> > If you look at the blueprints on the Fairchild
> CD-ROM, you'll notice
> > that the rib stitch spacing specifications
> subdivide the wing
> > cordwise into 3 sections of 22" each. The spacing
> (2 - 3 - 4" or 3 -
> > 4 - 5", depending on whether or not you're in the
> slipstream)
> > actually works out well using the 22"
> subdivisions. Stitching
> > between the ribs and the compression members is
> interesting, to say
> > the least, but all it takes is time.
> > If you haven't already found an interior shop, I
> HIGHLY reccomend
> > Interiors by Dene in the Oklahoma City area
> (forgot the name of the
> > podunk town, I'll get it when I find the name of
> the metal company).
> > Dene has all the original Fairchild patterns and
> did an outstanding
> > job on my airplane. Dene does quality work at
> very reasonable prices
> > in a relatively short amount of time, and he's a
> genuinely nice guy,
> > as well.
> > Hope all this helps. Good luck with your airplane
> and send me some
> > pics.
> > Best Wishes,
> > Brad Donner
> > NC77605
> > Yahoo! Groups Links
Do You Yahoo!?
http://mail.yahoo.com'
Posted: Wed Sep 28, 2005 1:37 am
by Buell Powell
'Hi Jim,
I will be glad to send you some pictures. I don't have a
didgital camera though so I need your mailing address. If you could send
some photos of your UC61 I would appreciate it also.
Buell
Sent: Tuesday, September 27, 2005 6:43 PM
Subject: Re: [fairchildclub] Re: Rudder pedel covering
> HI BUELL!
> LONG TIME NO HEAR!
> ELSES SUPERB WORK!
> THANKS
> JIM CHYBIKCI
> HB-690 / 43-14964
> > Brad,
> > should look very
> > the wings.
> > Buell
> > To:
> > day in Oklahoma
> > plate. Did you
> > aren't difficult to
> > top surface of the
> > require lots of
> > time fitting your
> > well, but I've seen
> > wing (and into the
> > really took away
> > subdivide the wing
> > (2 - 3 - 4" or 3 -
> > slipstream)
> > interesting, to say
> > HIGHLY reccomend
> > the metal company).
> > did an outstanding
> > genuinely nice guy,
> > > as well.
> > and send me some
> > > pics.
> > > Best Wishes,
> > > Brad Donner
> > > NC77605
> > > Yahoo! Groups Links
> Do You Yahoo!?
Posted: Thu Sep 29, 2005 8:05 am
by WILLIAM SPRIGGS
'Buell: The company that produces the diamond pattern aluminum is Rigidized Metals Corporation, 658 Ohio St., Buffalo, NY. (800) 836-2580. Be sure to order dead soft, 6061-0 or or any -0 aluminum. Bill Spriggs
Sent: Tuesday, September 27, 2005 4:55 AM
Brad,
The spars and tip bows were ok so I didn't replace them but I did
make new ribs and leading edges. I have checked the wing tanks for fit and
they line up very nicely. I think the reason some tanks end up too high is
probably using too thick felt where the tanks rest on top of the ribs. I had
planned on puting an original interior in mine but John Berendt called and
has a turquois interior that he wasn't going to use and is sending it to me.
I think if I paint the outside turquois & white it should look very
nice.Thanks for the information about the rib stitching-& good luck covering
the wings.
Buell
> Thanks for the post, Buell. I'm spending one more day in Oklahoma
> working on my airplane, so it will likely be Wednesday before I get
> you the name of the company that makes the diamond plate. Did you
> build new wings for your airplane? The flap bays aren't difficult to
> cover, but clearance between the bolt heads on the top surface of the
> flaps and the flap bay is a little tight and will require lots of
> trial fitting. You will also want to spend some time fitting your
> fuel tanks before you cover. Mine fit really well, but I've seen
> others that stuck up above the top surface of the wing (and into the
> slipstream of that super-fast airplane) and they really took away
> If you look at the blueprints on the Fairchild CD-ROM, you'll notice
> that the rib stitch spacing specifications subdivide the wing
> cordwise into 3 sections of 22" each. The spacing (2 - 3 - 4" or 3 -
> 4 - 5", depending on whether or not you're in the slipstream)
> actually works out well using the 22" subdivisions. Stitching
> between the ribs and the compression members is interesting, to say
> If you haven't already found an interior shop, I HIGHLY reccomend
> Interiors by Dene in the Oklahoma City area (forgot the name of the
> podunk town, I'll get it when I find the name of the metal company).
> Dene has all the original Fairchild patterns and did an outstanding
> job on my airplane. Dene does quality work at very reasonable prices
> in a relatively short amount of time, and he's a genuinely nice guy,
> as well.
> Hope all this helps. Good luck with your airplane and send me some
> pics.
> Best Wishes,
> Brad Donner
> NC77605
Posted: Fri Sep 30, 2005 10:24 am
by Buell Powell
'Bill,
Thanks! I will give them a call.
Buell
Sent: Thursday, September 29, 2005 9:05 AM
> From: Buell Powell
> Brad,
did
and
is
had
and
me.
covering
> the wings.
> Buell
> > as well.
> > pics.
> > Best Wishes,
> > Brad Donner
> > NC77605
> > Yahoo! Groups Links
Posted: Fri Sep 30, 2005 5:28 pm
by Buell Powell
'Bill,
The diamond plate & glove box doors came today. Thanks very much for
sending them. Let me know how much to send and your mailing address so I can
send you a check.
Buell
> From: Buell Powell
> Brad,
did
and
is
had
and
me.
covering
> the wings.
> Buell
> > as well.
> > pics.
> > Best Wishes,
> > Brad Donner
> > NC77605
> > Yahoo! Groups Links
Posted: Sat Oct 01, 2005 1:37 pm
by windshieldguy2000
'Buell: Bill has the same contact information for Rigidized that I have
and he's right about the dead soft spec. I got to learn that little
lesson the expensive way. Good luck with your project.
By the way, I now own a spare UC-61 rudder that needs the tube that
goes around the top curve replaced due to corrosion. Anyone want to
buy it or (better) got anything to trade for it? It will be next week
before I get the rudder home and get a decent picture of it.
Best Wishes,
Brad Donner'
Posted: Sat Oct 01, 2005 5:30 pm
by WILLIAM SPRIGGS
'Buell: All those things were extra for me, so no need to send a check. I could hand form a new bottom panel for you, would have to have the panel back to copy. Probably 3-4 hours to make. Bill Spriggs
Sent: Friday, September 30, 2005 4:26 PM
Bill,
send you a check.
Buell
> From: Buell Powell
> To: fairchildclub@yahoogroups.com Sent: Tuesday, September 27, 2005 4:55 AM
> Brad,
did
and
is
had
and
me.
covering
> the wings.
> Buell
> From: "windshieldguy2000" To:
> > as well.
> > pics.
> > Best Wishes,
> > Brad Donner
> > NC77605
> > Yahoo! Groups Links
Posted: Mon Oct 03, 2005 10:28 am
by Buell Powell
'Bill, I used your bottom panel for a pattern and tried forming one.
I had it shaped and the outside edges bent around. Where I got into a
problem was making the step-down at the bottom and when I doubled it over it
cracked. I think the aluminum I have is to hard and doesn't want to bend. If
you could make one that would be great-I will send you the bottom panel if
you really don't mind making one.I also cut out a rudder panel cover from
the material you sent- sure is nice stuff to work with-Thanks again,
Buell
Sent: Saturday, October 01, 2005 6:30 PM
> From: Buell Powell
> Bill,
for
can
> send you a check.
> Buell
> From: "WILLIAM SPRIGGS"
836-2580.
> > From: Buell
Powell
> > To:
fairchildclub@yahoogroups.com > Sent: Tuesday, September 27, 2005 4:55 AM
> > Brad,
I
> did
fit
> and
high
> is
ribs. I
> had
called
> and
it to
> me.
> covering
> > the wings.
> > Buell
get
to
the
the
notice
3 -
say
the
company).
outstanding
prices
guy,
> > > as well.
some
> > > pics.
> > > Best Wishes,
> > > Brad Donner
> > > NC77605
> > > Yahoo! Groups Links
> > Yahoo! Groups Links
> > Yahoo! Groups Links
Posted: Wed Oct 05, 2005 8:33 am
by WILLIAM SPRIGGS
'Buell: Send the bottom panel back to me and I will form a new one. I've had best luck using 6061-0 aluminum for this type of forming. I have more of the diamond pattern material if you need more. Bill Spriggs
Sent: Monday, October 03, 2005 9:27 AM
Buell
> From: Buell Powell
> To: fairchildclub@yahoogroups.com Sent: Friday, September 30, 2005 4:26 PM
> Bill,
for
can
> send you a check.
> Buell
> From: "WILLIAM SPRIGGS" To:
836-2580.
> > From: Buell
Powell > To:
fairchildclub@yahoogroups.com Subject: Re: [fairchildclub] Re: Rudder pedel covering
> > Brad,
I
> did
fit
> and
high
> is
ribs. I
> had
called
> and
it to
> me.
> covering
> > the wings.
> > Buell
get
to
the
the
notice
3 -
say
the
company).
outstanding
prices
guy,
> > > as well.
some
> > > pics.
> > > Best Wishes,
> > > Brad Donner
> > > NC77605
> > > Yahoo! Groups Links
> > Yahoo! Groups Links
> > Yahoo! Groups Links
Posted: Wed Oct 05, 2005 8:57 am
by WILLIAM SPRIGGS
'Buell: I neglected to send mailing address: William Spriggs, 3585B Telegraph Road, Ventura, CA 93003. Bill Spriggs
Buell
> From: Buell Powell
> Bill,
for
can
> send you a check.
> Buell
836-2580.
> > From: Buell
Powell > To:
> > Brad,
I
> did
fit
> and
high
> is
ribs. I
> had
called
> and
it to
> me.
> covering
> > the wings.
> > Buell
get
to
the
the
notice
3 -
say
the
company).
outstanding
prices
guy,
> > > as well.
some
> > > pics.
> > > Best Wishes,
> > > Brad Donner
> > > NC77605
> > > Yahoo! Groups Links
> > Yahoo! Groups Links
> > Yahoo! Groups Links
