Page 2 of 2
Re: Tail Wheel Shimmy - Attempt #2
Posted: Thu Jun 12, 2003 12:16 pm
by Buell Powell
'Hi Jim,
Congratulations!
Thanks - I still have a long way to go so I will wait until
you get back. What year is your Fairchild? Is it a UC61? I am still looking
for an instrument panel. The part that drops down on the one that I need is
about 8"across and rrops down about 1' or 2".
Let me know if you are looking for more parts I have located a few parts in
my search and will be glad to let you know where to find them.
Buell
Sent: Thursday, June 12, 2003 7:56 AM
Subject: Re: [fairchildclub] Tail Wheel Shimmy - Attempt #2
> Hi Buell-
> I have 2 drag links, and possiblly an extra Strut. I
> will need to check that. I am off onto my Honeymoon
> for the next 2 weeks, so if you can wait till early
> July, please do.
> Jim
> P.S. did you ever find an instrument Bulkhead???
> I am still looking. I have the flat bottom version,
> but I need the type that has a drop down in the
> middle.
> __________________________________
> Do you Yahoo!?
> Yahoo! Calendar - Free online calendar with sync to Outlook(TM).
> http://calendar.yahoo.com
Posted: Thu Jun 12, 2003 1:01 pm
by Airy-Hugues Millet
'The sure fire solution is to stay away
>from hard surface!
I fully agree...
...but it quite hard nowadays, when you are invited on military airbase to
ask them for a grass runway!!
:o))
Airy
Trouvez l'âme soeur sur MSN Rencontres ! http://g.msn.fr/FR1000/9551'
Re: Tail Wheel Shimmy - Russ conversion
Posted: Fri Jun 20, 2003 12:00 pm
by Curt Kinchen
'I also noted a small improvemente with the Russ conversion(on a PT),
but the real answer is as everyone has noted. Get as many of the
mating parts as tight as you can.
Also, regarding the Russ conversion, easiest thing to do is send him
your tailwheel, especially if you have a spare. There are a lot of
different ones floating around out there.
--- In fairchildclub@yahoogroups.com, Jamie Treat
> Airy-Hugues,
> Still using Ribbed and Smooth Contour. Mine was Ribbed, now worn
smooth. I find no difference between the two as for shimmy. The only
source I have been using is Desser. Also pick up a old tire that is
serviceable now and then.
> Talked to Charlie Webb at Sun-N-Fun, he just converted to the Russ
Adapter rings and modern tire. He still has a little shimmy now and
then, but better. Also before you purchase the rings, Call Russ and
give him your dimensions of the wheel, minor difference between P/Ns.
> Jamie
> From: Airy-Hugues Millet
> Sent: Wednesday, June 11, 2003 12:31 PM
> . If the tailwheel is clean and within factory tolerance, shimmy
will be
> nil. I maintain 4 F-24's, none of them have a shimmy. I also land
my F-24 at
> around 80mph at 7000ft alt plus density. Fast moving, some times
with a rear
> load and more fuel, I cannot keep the tail off as long as I want,
still no
> shimmy.
> >Jamie S. Treat
> Hy Jamie,
> can precise if the 4 F24 you are running are SC10 tires and
wheels equiped
> or not?
> I guess shimmy is a commitment of SC10 + working plays (becoming
gap!!)+ an
> original geometry nearby to enhance those effects!
> For example, on our F24 with 10 inches tire, but from an old new
stock, with
> small ribs on its profile it didn't had shimmy, but as soon as
ribs let the
> place to a flat surface (perfectly smooth contours), we begin to
met shimmy
> phenomenom, and as well as the tire begin to be overworn, the
shimmy
> increase at each landing on hard surface!!
> ...will be interested in any experience...before choosing between
rrruss
> aircraft adaptor kit or finding a brand new tire ( does anybody
know an
> other company than desser, able to get STOMIL tires (oval ribs),
as it is a
> polish company from the michelin group!!)
> Airy-H. MILLET
> Yahoo! Groups Sponsor
> Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service.
Posted: Tue Jul 08, 2003 7:06 am
by james chybicki
'HI Buell
I am back from the Honeymoon in Hawaii... It was
tough, but we got through it nicely! I went out to the
hangar Saturday, and I actually have 2 extra drag
links.
Our baby is a true UC-61K, built in 1943 for USAAF
#43-14964 sent to the RAF as HB-690 (24 volt). We have
the extremely rare british installed full swivel
flexjoint tailwheel.
I also need the dropdown instrument panel. I have one
from a '46, but it is the straight bottom.
I will contact you offline on the shipping and prices.
Any idea where I can pick up a Ranger starter????
JIM
--- Buell Powell wrote:
> Hi Jim,
> Congratulations!
> find them.
> Buell
> From: "james chybicki"
> Attempt #2
> > Hi Buell-
> I
> Honeymoon
> early
> > July, please do.
> > Jim
> version,
> > middle.
> > Do you Yahoo!?
> to Outlook(TM).
Do you Yahoo!?
SBC Yahoo! DSL - Now only $29.95 per month!
http://sbc.yahoo.com'
Posted: Tue Jul 08, 2003 7:35 am
by John Berendt
'James
Contact Bill Mitchell at (814)274-9394, Bill has a E-80 Starter for sale,He
also has a lot of Ranger parts for sale.
Sent: Tuesday, July 08, 2003 8:06 AM
> HI Buell
> links.
> JIM
> > Hi Jim,
> > Congratulations!
> > find them.
> > Buell
> > To:
> > Attempt #2
> > > Hi Buell-
> > I
> > Honeymoon
> > early
> > > July, please do.
> > > Jim
> > version,
> > > middle.
> > > Do you Yahoo!?
> > to Outlook(TM).
> Do you Yahoo!?
Posted: Tue Jul 08, 2003 7:53 am
by Buell Powell
'Hi Jim,
I bought a starter from Jada at Smallwood
Aviation(903-848-4461-Canton Texas)They have several 12volts but I don't
know about the 24volt. They will also change the gear drive from 12 to 3 if
you need a 3 tooth. They are used and they check to see if they work before
they send them out but they don't rebuild them. The guy that told me about
them bought one a couple of years ago and hasn't had any trouble with it.
If you want to call me about the drag link my phone no is
830-935-2294. Keep me posted on any parts you need and I would be glad to
check while I am looking for stuff for my Fairchild. If I have any luck on
instrument panels I'll be sure to let you know.
Buell
> HI Buell
> links.
> JIM
> > Hi Jim,
> > Congratulations!
> > find them.
> > Buell
> > To:
> > Attempt #2
> > > Hi Buell-
> > I
> > Honeymoon
> > early
> > > July, please do.
> > > Jim
> > version,
> > > middle.
> > > Do you Yahoo!?
> > to Outlook(TM).
> Do you Yahoo!?
Posted: Tue Jul 08, 2003 2:09 pm
by TED CAMP
'hello Jim , could you give me a call My # is 734-502-6428 I'm interested in a drag link thank you. Ted camp----- Original Message -----
Sent: Tuesday, July 08, 2003 9:06 AM
HI Buell
links.
JIM
> Hi Jim,
> Congratulations!
> find them.
> Buell
> Attempt #2
> > Hi Buell-
> I
> Honeymoon
> early
> > July, please do.
> > Jim
> version,
> > middle.
> > Do you Yahoo!?
> to Outlook(TM).
Do you Yahoo!?
ADVERTISEMENT
Posted: Tue Jul 08, 2003 3:49 pm
by robert hensarling
'-----Original Message-----
To: fairchild
Date: Tuesday, July 08, 2003 3:08 PM
I would like info on the links also Buell, thanks, and the extra strut.
Robert Hensarling
rhrocker@hilconet.com
HI Buell
links.
JIM
> Hi Jim,
> Congratulations!
> find them.
> Buell
> Attempt #2
> > Hi Buell-
> I
> Honeymoon
> early
> > July, please do.
> > Jim
> version,
> > middle.
> > Do you Yahoo!?
> to Outlook(TM).
Do you Yahoo!?
ADVERTISEMENT
ADVERTISEMENT
