I need any information on attaching wheel pants to a 1934 F24 C8C
Found out that [he "Deluxe:' 1937 Model was the first production model
produced with wheel pants. I have a couple of drawings from Mike Kelly
that were helpful, but nothing on how they were attached. What it looks
like the inside is clamped to the strut, the outside is attached to the I
wheel hub in some fashion.
If no one has any drawings, has anyone taken any pictures on the assembly?
That would be helpful.,
Main Gear Wheel Pants Assembly Drawings
Re: Main Gear Wheel Pants Assembly Drawings
Polecat2 wrote: Thu Jul 03, 2025 6:10 am I need any information on attaching wheel pants to a 1934 F24 C8C
Found out that [he "Dulex' 1937 Model was the first production model
produced with Wheel Pants.Got a couple of drawings from Mike Kelly
that helped, but nothing on how they are attached. What it looks
wheel shaft in some fashon?
nicholasthomas
The 1937 Deluxe may be the best lead: its parts catalog or drawings should list the wheel-pant brackets and hub/strut hardware, even if the C8C drawing doesn’t. Compare those part numbers with your C8C strut and hub attach points, and ask Deluxe owners for close-up photos of the inner clamp and outer hub attachment. If the club has a parts index or type-certificate file, that’s worth checking before fabricating anything.
