Spec Ranger Engine mount
Items of note or suggestions for improvements. Discussion about the Forum itself (rather than discussions about Fairchild aircraft).
Polecat2
Post by Polecat2 »
    • Image[/img][/img][/img][/img]
I attaxhed a photo of the type of mount that we receieved from a donor here at Air Heritage Museumner.
NC 14749 had a Warner Engine, but now with his revision the aircraft there is a Ranger engine frame and mounts.
There are fou cyinders at each attach point that look hous like the would house the like vibration Lord Mounts, nut
he has those cylinders welded top and bottom what loooks like 1/8" thick washers? cannot determine f there are any
Vibration device in the picture. Any help on this would ne appreciated.
F24H-Mike
Re: Spec Ranger Engine mount
Post by F24H-Mike »
Hello, Polecat2.
Did you ever find a source for Ranger lord mounts? I'm needing a set for a 1937 F24H. I just sent a request to Point Aviation in Mineral Point, WI but they've not had time to respond yet. I've also read that "Classic Aviation in Germany" might be a source but can't find any contact information for them. Any suggestions for a source would be appreciated and, if I find one and you're still in need, I'll send the details your way.
Return to “Forum Notices, Comments, and Suggestions”
