Re: F24 brake master cylinders
Hi all
I have a 1940 F24W-40
My brake cylinders are leaking bad. They appear to be made by lockheed and are a round tube with a brass plunger, spring, and rubber cup inside. The part that is leaking is the rubber gasket/o ring around the brass plunger. Any clue where I can buy new gaskets?
Thanx
Tim NC25328'
Hi all
Thanx
Tim NC25328'
Ellen Starr
'Tim,Believe I have the same cylinders in my brake system. Used some parts from NAPA haudraulic kit #1 to rebuilt them. Think the cup was one item used. Also had the cylinders resleeved and bored by a fellow in CA.
Roger StarrNC77630
Sent: Friday, February 20, 2015 7:53 PM
Subject: [fairchildclub] F24 brake master cylinders
Hi all
I have a 1940 F24W-40My brake cylinders are leaking bad. They appear to be made by lockheed and are a round tube with a brass plunger, spring, and rubber cup inside. The part that is leaking is the rubber gasket/o ring around the brass plunger. Any clue where I can buy new gaskets?
ThanxTim NC25328 #ygrps-yiv-1855798318 #ygrps-yiv-1855798318yiv5313425284 -- #ygrps-yiv-1855798318yiv5313425284ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;} #ygrps-yiv-1855798318 #ygrps-yiv-1855798318yiv5313425284 #ygrps-yiv-1855798318yiv5313425284ygrp-mkp hr { border:1px solid #d8d8d8;} #ygrps-yiv-1855798318 #ygrps-yiv-1855798318yiv5313425284 #ygrps-yiv-1855798318yiv5313425284ygrp-mkp #ygrps-yiv-1855798318yiv5313425284hd { color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;} #ygrps-yiv-1855798318 #ygrps-yiv-1855798318yiv5313425284 #ygrps-yiv-1855798318yiv5313425284ygrp-mkp #ygrps-yiv-1855798318yiv5313425284ads { margin-bottom:10px;} #ygrps-yiv-1855798318 #ygrps-yiv-1855798318yiv5313425284 #ygrps-yiv-1855798318yiv5313425284ygrp-mkp .ygrps-yiv-1855798318yiv5313425284ad { padding:0 0;} #ygrps-yiv-1855798318 #ygrps-yiv-1855798318yiv5313425284 #ygrps-yiv-1855798318yiv5313425284ygrp-mkp .ygrps-yiv-1855798318yiv5313425284ad p { margin:0;} #ygrps-yiv-1855798318 #ygrps-yiv-1855798318yiv5313425284 #ygrps-yiv-1855798318yiv5313425284ygrp-mkp .ygrps-yiv-1855798318yiv5313425284ad a { color:#0000ff;text-decoration:none;} #ygrps-yiv-1855798318 #ygrps-yiv-1855798318yiv5313425284 #ygrps-yiv-1855798318yiv5313425284ygrp-sponsor #ygrps-yiv-1855798318yiv5313425284ygrp-lc { font-family:Arial;} #ygrps-yiv-1855798318 #ygrps-yiv-1855798318yiv5313425284 #ygrps-yiv-1855798318yiv5313425284ygrp-sponsor #ygrps-yiv-1855798318yiv5313425284ygrp-lc #ygrps-yiv-1855798318yiv5313425284hd { margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;} #ygrps-yiv-1855798318 #ygrps-yiv-1855798318yiv5313425284 #ygrps-yiv-1855798318yiv5313425284ygrp-sponsor #ygrps-yiv-1855798318yiv5313425284ygrp-lc .ygrps-yiv-1855798318yiv5313425284ad { margin-bottom:10px;padding:0 0;} #ygrps-yiv-1855798318 #ygrps-yiv-1855798318yiv5313425284 #ygrps-yiv-1855798318yiv5313425284actions { font-family:Verdana;font-size:11px;padding:10px 0;} #ygrps-yiv-1855798318 #ygrps-yiv-1855798318yiv5313425284 #ygrps-yiv-1855798318yiv5313425284activity { background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;} #ygrps-yiv-1855798318 #ygrps-yiv-1855798318yiv5313425284 #ygrps-yiv-1855798318yiv5313425284activity span { font-weight:700;} #ygrps-yiv-1855798318 #ygrps-yiv-1855798318yiv5313425284 #ygrps-yiv-1855798318yiv5313425284activity span:first-child { text-transform:uppercase;} #ygrps-yiv-1855798318 #ygrps-yiv-1855798318yiv5313425284 #ygrps-yiv-1855798318yiv5313425284activity span a { color:#5085b6;text-decoration:none;} #ygrps-yiv-1855798318 #ygrps-yiv-1855798318yiv5313425284 #ygrps-yiv-1855798318yiv5313425284activity span span { color:#ff7900;} #ygrps-yiv-1855798318 #ygrps-yiv-1855798318yiv5313425284 #ygrps-yiv-1855798318yiv5313425284activity span .ygrps-yiv-1855798318yiv5313425284underline { text-decoration:underline;} #ygrps-yiv-1855798318 #ygrps-yiv-1855798318yiv5313425284 .ygrps-yiv-1855798318yiv5313425284attach { clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;} #ygrps-yiv-1855798318 #ygrps-yiv-1855798318yiv5313425284 .ygrps-yiv-1855798318yiv5313425284attach div a { text-decoration:none;} #ygrps-yiv-1855798318 #ygrps-yiv-1855798318yiv5313425284 .ygrps-yiv-1855798318yiv5313425284attach img { border:none;padding-right:5px;} #ygrps-yiv-1855798318 #ygrps-yiv-1855798318yiv5313425284 .ygrps-yiv-1855798318yiv5313425284attach label { display:block;margin-bottom:5px;} #ygrps-yiv-1855798318 #ygrps-yiv-1855798318yiv5313425284 .ygrps-yiv-1855798318yiv5313425284attach label a { text-decoration:none;} #ygrps-yiv-1855798318 #ygrps-yiv-1855798318yiv5313425284 blockquote { margin:0 0 0 4px;} #ygrps-yiv-1855798318 #ygrps-yiv-1855798318yiv5313425284 .ygrps-yiv-1855798318yiv5313425284bold { font-family:Arial;font-size:13px;font-weight:700;} #ygrps-yiv-1855798318 #ygrps-yiv-1855798318yiv5313425284 .ygrps-yiv-1855798318yiv5313425284bold a { text-decoration:none;} #ygrps-yiv-1855798318 #ygrps-yiv-1855798318yiv5313425284 dd.ygrps-yiv-1855798318yiv5313425284last p a { font-family:Verdana;font-weight:700;} #ygrps-yiv-1855798318 #ygrps-yiv-1855798318yiv5313425284 dd.ygrps-yiv-1855798318yiv5313425284last p span { margin-right:10px;font-family:Verdana;font-weight:700;} #ygrps-yiv-1855798318 #ygrps-yiv-1855798318yiv5313425284 dd.ygrps-yiv-1855798318yiv5313425284last p span.ygrps-yiv-1855798318yiv5313425284yshortcuts { margin-right:0;} #ygrps-yiv-1855798318 #ygrps-yiv-1855798318yiv5313425284 div.ygrps-yiv-1855798318yiv5313425284attach-table div div a { text-decoration:none;} #ygrps-yiv-1855798318 #ygrps-yiv-1855798318yiv5313425284 div.ygrps-yiv-1855798318yiv5313425284attach-table { width:400px;} #ygrps-yiv-1855798318 #ygrps-yiv-1855798318yiv5313425284 div.ygrps-yiv-1855798318yiv5313425284file-title a, #ygrps-yiv-1855798318 #ygrps-yiv-1855798318yiv5313425284 div.ygrps-yiv-1855798318yiv5313425284file-title a:active, #ygrps-yiv-1855798318 #ygrps-yiv-1855798318yiv5313425284 div.ygrps-yiv-1855798318yiv5313425284file-title a:hover, #ygrps-yiv-1855798318 #ygrps-yiv-1855798318yiv5313425284 div.ygrps-yiv-1855798318yiv5313425284file-title a:visited { text-decoration:none;} #ygrps-yiv-1855798318 #ygrps-yiv-1855798318yiv5313425284 div.ygrps-yiv-1855798318yiv5313425284photo-title a, #ygrps-yiv-1855798318 #ygrps-yiv-1855798318yiv5313425284 div.ygrps-yiv-1855798318yiv5313425284photo-title a:active, #ygrps-yiv-1855798318 #ygrps-yiv-1855798318yiv5313425284 div.ygrps-yiv-1855798318yiv5313425284photo-title a:hover, #ygrps-yiv-1855798318 #ygrps-yiv-1855798318yiv5313425284 div.ygrps-yiv-1855798318yiv5313425284photo-title a:visited { text-decoration:none;} #ygrps-yiv-1855798318 #ygrps-yiv-1855798318yiv5313425284 div#ygrps-yiv-1855798318yiv5313425284ygrp-mlmsg #ygrps-yiv-1855798318yiv5313425284ygrp-msg p a span.ygrps-yiv-1855798318yiv5313425284yshortcuts { font-family:Verdana;font-size:10px;font-weight:normal;} #ygrps-yiv-1855798318 #ygrps-yiv-1855798318yiv5313425284 .ygrps-yiv-1855798318yiv5313425284green { color:#628c2a;} #ygrps-yiv-1855798318 #ygrps-yiv-1855798318yiv5313425284 .ygrps-yiv-1855798318yiv5313425284MsoNormal { margin:0 0 0 0;} #ygrps-yiv-1855798318 #ygrps-yiv-1855798318yiv5313425284 o { font-size:0;} #ygrps-yiv-1855798318 #ygrps-yiv-1855798318yiv5313425284 #ygrps-yiv-1855798318yiv5313425284photos div { float:left;width:72px;} #ygrps-yiv-1855798318 #ygrps-yiv-1855798318yiv5313425284 #ygrps-yiv-1855798318yiv5313425284photos div div { border:1px solid #666666;height:62px;overflow:hidden;width:62px;} #ygrps-yiv-1855798318 #ygrps-yiv-1855798318yiv5313425284 #ygrps-yiv-1855798318yiv5313425284photos div label { color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;} #ygrps-yiv-1855798318 #ygrps-yiv-1855798318yiv5313425284 #ygrps-yiv-1855798318yiv5313425284reco-category { font-size:77%;} #ygrps-yiv-1855798318 #ygrps-yiv-1855798318yiv5313425284 #ygrps-yiv-1855798318yiv5313425284reco-desc { font-size:77%;} #ygrps-yiv-1855798318 #ygrps-yiv-1855798318yiv5313425284 .ygrps-yiv-1855798318yiv5313425284replbq { margin:4px;} #ygrps-yiv-1855798318 #ygrps-yiv-1855798318yiv5313425284 #ygrps-yiv-1855798318yiv5313425284ygrp-actbar div a:first-child { margin-right:2px;padding-right:5px;} #ygrps-yiv-1855798318 #ygrps-yiv-1855798318yiv5313425284 #ygrps-yiv-1855798318yiv5313425284ygrp-mlmsg { font-size:13px;font-family:Arial, helvetica, clean, sans-serif;} #ygrps-yiv-1855798318 #ygrps-yiv-1855798318yiv5313425284 #ygrps-yiv-1855798318yiv5313425284ygrp-mlmsg table { font-size:inherit;font:100%;} #ygrps-yiv-1855798318 #ygrps-yiv-1855798318yiv5313425284 #ygrps-yiv-1855798318yiv5313425284ygrp-mlmsg select, #ygrps-yiv-1855798318 #ygrps-yiv-1855798318yiv5313425284 input, #ygrps-yiv-1855798318 #ygrps-yiv-1855798318yiv5313425284 textarea { font:99% Arial, Helvetica, clean, sans-serif;} #ygrps-yiv-1855798318 #ygrps-yiv-1855798318yiv5313425284 #ygrps-yiv-1855798318yiv5313425284ygrp-mlmsg pre, #ygrps-yiv-1855798318 #ygrps-yiv-1855798318yiv5313425284 code { font:115% monospace;} #ygrps-yiv-1855798318 #ygrps-yiv-1855798318yiv5313425284 #ygrps-yiv-1855798318yiv5313425284ygrp-mlmsg * { line-height:1.22em;} #ygrps-yiv-1855798318 #ygrps-yiv-1855798318yiv5313425284 #ygrps-yiv-1855798318yiv5313425284ygrp-mlmsg #ygrps-yiv-1855798318yiv5313425284logo { padding-bottom:10px;} #ygrps-yiv-1855798318 #ygrps-yiv-1855798318yiv5313425284 #ygrps-yiv-1855798318yiv5313425284ygrp-msg p a { font-family:Verdana;} #ygrps-yiv-1855798318 #ygrps-yiv-1855798318yiv5313425284 #ygrps-yiv-1855798318yiv5313425284ygrp-msg p#ygrps-yiv-1855798318yiv5313425284attach-count span { color:#1E66AE;font-weight:700;} #ygrps-yiv-1855798318 #ygrps-yiv-1855798318yiv5313425284 #ygrps-yiv-1855798318yiv5313425284ygrp-reco #ygrps-yiv-1855798318yiv5313425284reco-head { color:#ff7900;font-weight:700;} #ygrps-yiv-1855798318 #ygrps-yiv-1855798318yiv5313425284 #ygrps-yiv-1855798318yiv5313425284ygrp-reco { margin-bottom:20px;padding:0px;} #ygrps-yiv-1855798318 #ygrps-yiv-1855798318yiv5313425284 #ygrps-yiv-1855798318yiv5313425284ygrp-sponsor #ygrps-yiv-1855798318yiv5313425284ov li a { font-size:130%;text-decoration:none;} #ygrps-yiv-1855798318 #ygrps-yiv-1855798318yiv5313425284 #ygrps-yiv-1855798318yiv5313425284ygrp-sponsor #ygrps-yiv-1855798318yiv5313425284ov li { font-size:77%;list-style-type:square;padding:6px 0;} #ygrps-yiv-1855798318 #ygrps-yiv-1855798318yiv5313425284 #ygrps-yiv-1855798318yiv5313425284ygrp-sponsor #ygrps-yiv-1855798318yiv5313425284ov ul { margin:0;padding:0 0 0 8px;} #ygrps-yiv-1855798318 #ygrps-yiv-1855798318yiv5313425284 #ygrps-yiv-1855798318yiv5313425284ygrp-text { font-family:Georgia;} #ygrps-yiv-1855798318 #ygrps-yiv-1855798318yiv5313425284 #ygrps-yiv-1855798318yiv5313425284ygrp-text p { margin:0 0 1em 0;} #ygrps-yiv-1855798318 #ygrps-yiv-1855798318yiv5313425284 #ygrps-yiv-1855798318yiv5313425284ygrp-text tt { font-size:120%;} #ygrps-yiv-1855798318 #ygrps-yiv-1855798318yiv5313425284 #ygrps-yiv-1855798318yiv5313425284ygrp-vital ul li:last-child { border-right:none !important;} #ygrps-yiv-1855798318
Roger StarrNC77630
Hi all
Tim Potter
'thanx for the response. I did some research and found that exact kit. I got it in the ol girl today and am going to test it tomorrow. I also put new tires and tubes on......WOW that was a pain in the ass!! Not having split wheels make it very tuff to do. Took me about 8 hours.
TimNC25328
On Saturday, February 21, 2015 1:55 PM, "Ellen Starr ellengstarr@yahoo.com [fairchildclub]" wrote:
Roger StarrNC77630
Hi all
ThanxTim NC25328
#ygrps-yiv-1316012689 #ygrps-yiv-1316012689yiv0697315424 #ygrps-yiv-1316012689yiv0697315424 -- #ygrps-yiv-1316012689yiv0697315424ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;} #ygrps-yiv-1316012689 #ygrps-yiv-1316012689yiv0697315424 #ygrps-yiv-1316012689yiv0697315424ygrp-mkp hr { border:1px solid #d8d8d8;} #ygrps-yiv-1316012689 #ygrps-yiv-1316012689yiv0697315424 #ygrps-yiv-1316012689yiv0697315424ygrp-mkp #ygrps-yiv-1316012689yiv0697315424hd { color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;} #ygrps-yiv-1316012689 #ygrps-yiv-1316012689yiv0697315424 #ygrps-yiv-1316012689yiv0697315424ygrp-mkp #ygrps-yiv-1316012689yiv0697315424ads { margin-bottom:10px;} #ygrps-yiv-1316012689 #ygrps-yiv-1316012689yiv0697315424 #ygrps-yiv-1316012689yiv0697315424ygrp-mkp .ygrps-yiv-1316012689yiv0697315424ad { padding:0 0;} #ygrps-yiv-1316012689 #ygrps-yiv-1316012689yiv0697315424 #ygrps-yiv-1316012689yiv0697315424ygrp-mkp .ygrps-yiv-1316012689yiv0697315424ad p { margin:0;} #ygrps-yiv-1316012689 #ygrps-yiv-1316012689yiv0697315424 #ygrps-yiv-1316012689yiv0697315424ygrp-mkp .ygrps-yiv-1316012689yiv0697315424ad a { color:#0000ff;text-decoration:none;} #ygrps-yiv-1316012689 #ygrps-yiv-1316012689yiv0697315424 #ygrps-yiv-1316012689yiv0697315424ygrp-sponsor #ygrps-yiv-1316012689yiv0697315424ygrp-lc { font-family:Arial;} #ygrps-yiv-1316012689 #ygrps-yiv-1316012689yiv0697315424 #ygrps-yiv-1316012689yiv0697315424ygrp-sponsor #ygrps-yiv-1316012689yiv0697315424ygrp-lc #ygrps-yiv-1316012689yiv0697315424hd { margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;} #ygrps-yiv-1316012689 #ygrps-yiv-1316012689yiv0697315424 #ygrps-yiv-1316012689yiv0697315424ygrp-sponsor #ygrps-yiv-1316012689yiv0697315424ygrp-lc .ygrps-yiv-1316012689yiv0697315424ad { margin-bottom:10px;padding:0 0;} #ygrps-yiv-1316012689 #ygrps-yiv-1316012689yiv0697315424 #ygrps-yiv-1316012689yiv0697315424actions { font-family:Verdana;font-size:11px;padding:10px 0;} #ygrps-yiv-1316012689 #ygrps-yiv-1316012689yiv0697315424 #ygrps-yiv-1316012689yiv0697315424activity { background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;} #ygrps-yiv-1316012689 #ygrps-yiv-1316012689yiv0697315424 #ygrps-yiv-1316012689yiv0697315424activity span { font-weight:700;} #ygrps-yiv-1316012689 #ygrps-yiv-1316012689yiv0697315424 #ygrps-yiv-1316012689yiv0697315424activity span:first-child { text-transform:uppercase;} #ygrps-yiv-1316012689 #ygrps-yiv-1316012689yiv0697315424 #ygrps-yiv-1316012689yiv0697315424activity span a { color:#5085b6;text-decoration:none;} #ygrps-yiv-1316012689 #ygrps-yiv-1316012689yiv0697315424 #ygrps-yiv-1316012689yiv0697315424activity span span { color:#ff7900;} #ygrps-yiv-1316012689 #ygrps-yiv-1316012689yiv0697315424 #ygrps-yiv-1316012689yiv0697315424activity span .ygrps-yiv-1316012689yiv0697315424underline { text-decoration:underline;} #ygrps-yiv-1316012689 #ygrps-yiv-1316012689yiv0697315424 .ygrps-yiv-1316012689yiv0697315424attach { clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;} #ygrps-yiv-1316012689 #ygrps-yiv-1316012689yiv0697315424 .ygrps-yiv-1316012689yiv0697315424attach div a { text-decoration:none;} #ygrps-yiv-1316012689 #ygrps-yiv-1316012689yiv0697315424 .ygrps-yiv-1316012689yiv0697315424attach img { border:none;padding-right:5px;} #ygrps-yiv-1316012689 #ygrps-yiv-1316012689yiv0697315424 .ygrps-yiv-1316012689yiv0697315424attach label { display:block;margin-bottom:5px;} #ygrps-yiv-1316012689 #ygrps-yiv-1316012689yiv0697315424 .ygrps-yiv-1316012689yiv0697315424attach label a { text-decoration:none;} #ygrps-yiv-1316012689 #ygrps-yiv-1316012689yiv0697315424 blockquote { margin:0 0 0 4px;} #ygrps-yiv-1316012689 #ygrps-yiv-1316012689yiv0697315424 .ygrps-yiv-1316012689yiv0697315424bold { font-family:Arial;font-size:13px;font-weight:700;} #ygrps-yiv-1316012689 #ygrps-yiv-1316012689yiv0697315424 .ygrps-yiv-1316012689yiv0697315424bold a { text-decoration:none;} #ygrps-yiv-1316012689 #ygrps-yiv-1316012689yiv0697315424 dd.ygrps-yiv-1316012689yiv0697315424last p a { font-family:Verdana;font-weight:700;} #ygrps-yiv-1316012689 #ygrps-yiv-1316012689yiv0697315424 dd.ygrps-yiv-1316012689yiv0697315424last p span { margin-right:10px;font-family:Verdana;font-weight:700;} #ygrps-yiv-1316012689 #ygrps-yiv-1316012689yiv0697315424 dd.ygrps-yiv-1316012689yiv0697315424last p span.ygrps-yiv-1316012689yiv0697315424yshortcuts { margin-right:0;} #ygrps-yiv-1316012689 #ygrps-yiv-1316012689yiv0697315424 div.ygrps-yiv-1316012689yiv0697315424attach-table div div a { text-decoration:none;} #ygrps-yiv-1316012689 #ygrps-yiv-1316012689yiv0697315424 div.ygrps-yiv-1316012689yiv0697315424attach-table { width:400px;} #ygrps-yiv-1316012689 #ygrps-yiv-1316012689yiv0697315424 div.ygrps-yiv-1316012689yiv0697315424file-title a, #ygrps-yiv-1316012689 #ygrps-yiv-1316012689yiv0697315424 div.ygrps-yiv-1316012689yiv0697315424file-title a:active, #ygrps-yiv-1316012689 #ygrps-yiv-1316012689yiv0697315424 div.ygrps-yiv-1316012689yiv0697315424file-title a:hover, #ygrps-yiv-1316012689 #ygrps-yiv-1316012689yiv0697315424 div.ygrps-yiv-1316012689yiv0697315424file-title a:visited { text-decoration:none;} #ygrps-yiv-1316012689 #ygrps-yiv-1316012689yiv0697315424 div.ygrps-yiv-1316012689yiv0697315424photo-title a, #ygrps-yiv-1316012689 #ygrps-yiv-1316012689yiv0697315424 div.ygrps-yiv-1316012689yiv0697315424photo-title a:active, #ygrps-yiv-1316012689 #ygrps-yiv-1316012689yiv0697315424 div.ygrps-yiv-1316012689yiv0697315424photo-title a:hover, #ygrps-yiv-1316012689 #ygrps-yiv-1316012689yiv0697315424 div.ygrps-yiv-1316012689yiv0697315424photo-title a:visited { text-decoration:none;} #ygrps-yiv-1316012689 #ygrps-yiv-1316012689yiv0697315424 div#ygrps-yiv-1316012689yiv0697315424ygrp-mlmsg #ygrps-yiv-1316012689yiv0697315424ygrp-msg p a span.ygrps-yiv-1316012689yiv0697315424yshortcuts { font-family:Verdana;font-size:10px;font-weight:normal;} #ygrps-yiv-1316012689 #ygrps-yiv-1316012689yiv0697315424 .ygrps-yiv-1316012689yiv0697315424green { color:#628c2a;} #ygrps-yiv-1316012689 #ygrps-yiv-1316012689yiv0697315424 .ygrps-yiv-1316012689yiv0697315424MsoNormal { margin:0 0 0 0;} #ygrps-yiv-1316012689 #ygrps-yiv-1316012689yiv0697315424 o { font-size:0;} #ygrps-yiv-1316012689 #ygrps-yiv-1316012689yiv0697315424 #ygrps-yiv-1316012689yiv0697315424photos div { float:left;width:72px;} #ygrps-yiv-1316012689 #ygrps-yiv-1316012689yiv0697315424 #ygrps-yiv-1316012689yiv0697315424photos div div { border:1px solid #666666;height:62px;overflow:hidden;width:62px;} #ygrps-yiv-1316012689 #ygrps-yiv-1316012689yiv0697315424 #ygrps-yiv-1316012689yiv0697315424photos div label { color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;} #ygrps-yiv-1316012689 #ygrps-yiv-1316012689yiv0697315424 #ygrps-yiv-1316012689yiv0697315424reco-category { font-size:77%;} #ygrps-yiv-1316012689 #ygrps-yiv-1316012689yiv0697315424 #ygrps-yiv-1316012689yiv0697315424reco-desc { font-size:77%;} #ygrps-yiv-1316012689 #ygrps-yiv-1316012689yiv0697315424 .ygrps-yiv-1316012689yiv0697315424replbq { margin:4px;} #ygrps-yiv-1316012689 #ygrps-yiv-1316012689yiv0697315424 #ygrps-yiv-1316012689yiv0697315424ygrp-actbar div a:first-child { margin-right:2px;padding-right:5px;} #ygrps-yiv-1316012689 #ygrps-yiv-1316012689yiv0697315424 #ygrps-yiv-1316012689yiv0697315424ygrp-mlmsg { font-size:13px;font-family:Arial, helvetica, clean, sans-serif;} #ygrps-yiv-1316012689 #ygrps-yiv-1316012689yiv0697315424 #ygrps-yiv-1316012689yiv0697315424ygrp-mlmsg table { font-size:inherit;font:100%;} #ygrps-yiv-1316012689 #ygrps-yiv-1316012689yiv0697315424 #ygrps-yiv-1316012689yiv0697315424ygrp-mlmsg select, #ygrps-yiv-1316012689 #ygrps-yiv-1316012689yiv0697315424 input, #ygrps-yiv-1316012689 #ygrps-yiv-1316012689yiv0697315424 textarea { font:99% Arial, Helvetica, clean, sans-serif;} #ygrps-yiv-1316012689 #ygrps-yiv-1316012689yiv0697315424 #ygrps-yiv-1316012689yiv0697315424ygrp-mlmsg pre, #ygrps-yiv-1316012689 #ygrps-yiv-1316012689yiv0697315424 code { font:115% monospace;} #ygrps-yiv-1316012689 #ygrps-yiv-1316012689yiv0697315424 #ygrps-yiv-1316012689yiv0697315424ygrp-mlmsg * { line-height:1.22em;} #ygrps-yiv-1316012689 #ygrps-yiv-1316012689yiv0697315424 #ygrps-yiv-1316012689yiv0697315424ygrp-mlmsg #ygrps-yiv-1316012689yiv0697315424logo { padding-bottom:10px;} #ygrps-yiv-1316012689 #ygrps-yiv-1316012689yiv0697315424 #ygrps-yiv-1316012689yiv0697315424ygrp-msg p a { font-family:Verdana;} #ygrps-yiv-1316012689 #ygrps-yiv-1316012689yiv0697315424 #ygrps-yiv-1316012689yiv0697315424ygrp-msg p#ygrps-yiv-1316012689yiv0697315424attach-count span { color:#1E66AE;font-weight:700;} #ygrps-yiv-1316012689 #ygrps-yiv-1316012689yiv0697315424 #ygrps-yiv-1316012689yiv0697315424ygrp-reco #ygrps-yiv-1316012689yiv0697315424reco-head { color:#ff7900;font-weight:700;} #ygrps-yiv-1316012689 #ygrps-yiv-1316012689yiv0697315424 #ygrps-yiv-1316012689yiv0697315424ygrp-reco { margin-bottom:20px;padding:0px;} #ygrps-yiv-1316012689 #ygrps-yiv-1316012689yiv0697315424 #ygrps-yiv-1316012689yiv0697315424ygrp-sponsor #ygrps-yiv-1316012689yiv0697315424ov li a { font-size:130%;text-decoration:none;} #ygrps-yiv-1316012689 #ygrps-yiv-1316012689yiv0697315424 #ygrps-yiv-1316012689yiv0697315424ygrp-sponsor #ygrps-yiv-1316012689yiv0697315424ov li { font-size:77%;list-style-type:square;padding:6px 0;} #ygrps-yiv-1316012689 #ygrps-yiv-1316012689yiv0697315424 #ygrps-yiv-1316012689yiv0697315424ygrp-sponsor #ygrps-yiv-1316012689yiv0697315424ov ul { margin:0;padding:0 0 0 8px;} #ygrps-yiv-1316012689 #ygrps-yiv-1316012689yiv0697315424 #ygrps-yiv-1316012689yiv0697315424ygrp-text { font-family:Georgia;} #ygrps-yiv-1316012689 #ygrps-yiv-1316012689yiv0697315424 #ygrps-yiv-1316012689yiv0697315424ygrp-text p { margin:0 0 1em 0;} #ygrps-yiv-1316012689 #ygrps-yiv-1316012689yiv0697315424 #ygrps-yiv-1316012689yiv0697315424ygrp-text tt { font-size:120%;} #ygrps-yiv-1316012689 #ygrps-yiv-1316012689yiv0697315424 #ygrps-yiv-1316012689yiv0697315424ygrp-vital ul li:last-child { border-right:none !important;} #ygrps-yiv-1316012689
TimNC25328
Roger StarrNC77630
Hi all
ThanxTim NC25328
'Go to a tire shop, especially one that does race cars, etc. Used to working on odd sizes and mags. Usually will do them for free because it is something cool and different!
ptcurt@gmail.com From: Tim Potter trp.8888@yahoo.com [fairchildclub]Sent: Saturday, February 21, 2015 8:34 PMTo: fairchildclub@yahoogroups.comReply To: fairchildclub@yahoogroups.comSubject: Re: [fairchildclub] F24 brake master cylinders
TimNC25328
Roger StarrNC77630
Hi all
ThanxTim NC25328
TimNC25328
Roger StarrNC77630
Hi all
ThanxTim NC25328
'NAPA Kit #1 will do it. The NAPA bar code is in one of the old E-mails, somewhere. I don't remember if 100% of the parts that are in the kit will be an exact substitute for all of the internal workings of the master cylinder, but I do remember that all of the rubbers parts work. If NAPA can't find it, I know that I still have one of the kits. You could also try to do a search of the past E-mails, and find some more information. I passed the same information to someone many years ago. There is many shops out there that can reface the wall of the master cylinder. If you have FE-1990, the wall thickness may not allow resurfacing. CD Drawing #42281 shows the cast iron master cylinder at the top, and the Wagner Fe-1990 at the bottom. For the Fe-1990, the one I had, it did have a manufacturers label on it. The drawing didn't say anything.Bob
On Sunday, February 22, 2015 8:19 PM, "Home ptcurt@gmail.com [fairchildclub]" wrote:
TimNC25328
Roger StarrNC77630
Hi all
ThanxTim NC25328
#ygrps-yiv-630909328 #ygrps-yiv-630909328yiv2496323061 #ygrps-yiv-630909328yiv2496323061 -- #ygrps-yiv-630909328yiv2496323061ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;} #ygrps-yiv-630909328 #ygrps-yiv-630909328yiv2496323061 #ygrps-yiv-630909328yiv2496323061ygrp-mkp hr { border:1px solid #d8d8d8;} #ygrps-yiv-630909328 #ygrps-yiv-630909328yiv2496323061 #ygrps-yiv-630909328yiv2496323061ygrp-mkp #ygrps-yiv-630909328yiv2496323061hd { color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;} #ygrps-yiv-630909328 #ygrps-yiv-630909328yiv2496323061 #ygrps-yiv-630909328yiv2496323061ygrp-mkp #ygrps-yiv-630909328yiv2496323061ads { margin-bottom:10px;} #ygrps-yiv-630909328 #ygrps-yiv-630909328yiv2496323061 #ygrps-yiv-630909328yiv2496323061ygrp-mkp .ygrps-yiv-630909328yiv2496323061ad { padding:0 0;} #ygrps-yiv-630909328 #ygrps-yiv-630909328yiv2496323061 #ygrps-yiv-630909328yiv2496323061ygrp-mkp .ygrps-yiv-630909328yiv2496323061ad p { margin:0;} #ygrps-yiv-630909328 #ygrps-yiv-630909328yiv2496323061 #ygrps-yiv-630909328yiv2496323061ygrp-mkp .ygrps-yiv-630909328yiv2496323061ad a { color:#0000ff;text-decoration:none;} #ygrps-yiv-630909328 #ygrps-yiv-630909328yiv2496323061 #ygrps-yiv-630909328yiv2496323061ygrp-sponsor #ygrps-yiv-630909328yiv2496323061ygrp-lc { font-family:Arial;} #ygrps-yiv-630909328 #ygrps-yiv-630909328yiv2496323061 #ygrps-yiv-630909328yiv2496323061ygrp-sponsor #ygrps-yiv-630909328yiv2496323061ygrp-lc #ygrps-yiv-630909328yiv2496323061hd { margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;} #ygrps-yiv-630909328 #ygrps-yiv-630909328yiv2496323061 #ygrps-yiv-630909328yiv2496323061ygrp-sponsor #ygrps-yiv-630909328yiv2496323061ygrp-lc .ygrps-yiv-630909328yiv2496323061ad { margin-bottom:10px;padding:0 0;} #ygrps-yiv-630909328 #ygrps-yiv-630909328yiv2496323061 #ygrps-yiv-630909328yiv2496323061actions { font-family:Verdana;font-size:11px;padding:10px 0;} #ygrps-yiv-630909328 #ygrps-yiv-630909328yiv2496323061 #ygrps-yiv-630909328yiv2496323061activity { background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;} #ygrps-yiv-630909328 #ygrps-yiv-630909328yiv2496323061 #ygrps-yiv-630909328yiv2496323061activity span { font-weight:700;} #ygrps-yiv-630909328 #ygrps-yiv-630909328yiv2496323061 #ygrps-yiv-630909328yiv2496323061activity span:first-child { text-transform:uppercase;} #ygrps-yiv-630909328 #ygrps-yiv-630909328yiv2496323061 #ygrps-yiv-630909328yiv2496323061activity span a { color:#5085b6;text-decoration:none;} #ygrps-yiv-630909328 #ygrps-yiv-630909328yiv2496323061 #ygrps-yiv-630909328yiv2496323061activity span span { color:#ff7900;} #ygrps-yiv-630909328 #ygrps-yiv-630909328yiv2496323061 #ygrps-yiv-630909328yiv2496323061activity span .ygrps-yiv-630909328yiv2496323061underline { text-decoration:underline;} #ygrps-yiv-630909328 #ygrps-yiv-630909328yiv2496323061 .ygrps-yiv-630909328yiv2496323061attach { clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;} #ygrps-yiv-630909328 #ygrps-yiv-630909328yiv2496323061 .ygrps-yiv-630909328yiv2496323061attach div a { text-decoration:none;} #ygrps-yiv-630909328 #ygrps-yiv-630909328yiv2496323061 .ygrps-yiv-630909328yiv2496323061attach img { border:none;padding-right:5px;} #ygrps-yiv-630909328 #ygrps-yiv-630909328yiv2496323061 .ygrps-yiv-630909328yiv2496323061attach label { display:block;margin-bottom:5px;} #ygrps-yiv-630909328 #ygrps-yiv-630909328yiv2496323061 .ygrps-yiv-630909328yiv2496323061attach label a { text-decoration:none;} #ygrps-yiv-630909328 #ygrps-yiv-630909328yiv2496323061 blockquote { margin:0 0 0 4px;} #ygrps-yiv-630909328 #ygrps-yiv-630909328yiv2496323061 .ygrps-yiv-630909328yiv2496323061bold { font-family:Arial;font-size:13px;font-weight:700;} #ygrps-yiv-630909328 #ygrps-yiv-630909328yiv2496323061 .ygrps-yiv-630909328yiv2496323061bold a { text-decoration:none;} #ygrps-yiv-630909328 #ygrps-yiv-630909328yiv2496323061 dd.ygrps-yiv-630909328yiv2496323061last p a { font-family:Verdana;font-weight:700;} #ygrps-yiv-630909328 #ygrps-yiv-630909328yiv2496323061 dd.ygrps-yiv-630909328yiv2496323061last p span { margin-right:10px;font-family:Verdana;font-weight:700;} #ygrps-yiv-630909328 #ygrps-yiv-630909328yiv2496323061 dd.ygrps-yiv-630909328yiv2496323061last p span.ygrps-yiv-630909328yiv2496323061yshortcuts { margin-right:0;} #ygrps-yiv-630909328 #ygrps-yiv-630909328yiv2496323061 div.ygrps-yiv-630909328yiv2496323061attach-table div div a { text-decoration:none;} #ygrps-yiv-630909328 #ygrps-yiv-630909328yiv2496323061 div.ygrps-yiv-630909328yiv2496323061attach-table { width:400px;} #ygrps-yiv-630909328 #ygrps-yiv-630909328yiv2496323061 div.ygrps-yiv-630909328yiv2496323061file-title a, #ygrps-yiv-630909328 #ygrps-yiv-630909328yiv2496323061 div.ygrps-yiv-630909328yiv2496323061file-title a:active, #ygrps-yiv-630909328 #ygrps-yiv-630909328yiv2496323061 div.ygrps-yiv-630909328yiv2496323061file-title a:hover, #ygrps-yiv-630909328 #ygrps-yiv-630909328yiv2496323061 div.ygrps-yiv-630909328yiv2496323061file-title a:visited { text-decoration:none;} #ygrps-yiv-630909328 #ygrps-yiv-630909328yiv2496323061 div.ygrps-yiv-630909328yiv2496323061photo-title a, #ygrps-yiv-630909328 #ygrps-yiv-630909328yiv2496323061 div.ygrps-yiv-630909328yiv2496323061photo-title a:active, #ygrps-yiv-630909328 #ygrps-yiv-630909328yiv2496323061 div.ygrps-yiv-630909328yiv2496323061photo-title a:hover, #ygrps-yiv-630909328 #ygrps-yiv-630909328yiv2496323061 div.ygrps-yiv-630909328yiv2496323061photo-title a:visited { text-decoration:none;} #ygrps-yiv-630909328 #ygrps-yiv-630909328yiv2496323061 div#ygrps-yiv-630909328yiv2496323061ygrp-mlmsg #ygrps-yiv-630909328yiv2496323061ygrp-msg p a span.ygrps-yiv-630909328yiv2496323061yshortcuts { font-family:Verdana;font-size:10px;font-weight:normal;} #ygrps-yiv-630909328 #ygrps-yiv-630909328yiv2496323061 .ygrps-yiv-630909328yiv2496323061green { color:#628c2a;} #ygrps-yiv-630909328 #ygrps-yiv-630909328yiv2496323061 .ygrps-yiv-630909328yiv2496323061MsoNormal { margin:0 0 0 0;} #ygrps-yiv-630909328 #ygrps-yiv-630909328yiv2496323061 o { font-size:0;} #ygrps-yiv-630909328 #ygrps-yiv-630909328yiv2496323061 #ygrps-yiv-630909328yiv2496323061photos div { float:left;width:72px;} #ygrps-yiv-630909328 #ygrps-yiv-630909328yiv2496323061 #ygrps-yiv-630909328yiv2496323061photos div div { border:1px solid #666666;height:62px;overflow:hidden;width:62px;} #ygrps-yiv-630909328 #ygrps-yiv-630909328yiv2496323061 #ygrps-yiv-630909328yiv2496323061photos div label { color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;} #ygrps-yiv-630909328 #ygrps-yiv-630909328yiv2496323061 #ygrps-yiv-630909328yiv2496323061reco-category { font-size:77%;} #ygrps-yiv-630909328 #ygrps-yiv-630909328yiv2496323061 #ygrps-yiv-630909328yiv2496323061reco-desc { font-size:77%;} #ygrps-yiv-630909328 #ygrps-yiv-630909328yiv2496323061 .ygrps-yiv-630909328yiv2496323061replbq { margin:4px;} #ygrps-yiv-630909328 #ygrps-yiv-630909328yiv2496323061 #ygrps-yiv-630909328yiv2496323061ygrp-actbar div a:first-child { margin-right:2px;padding-right:5px;} #ygrps-yiv-630909328 #ygrps-yiv-630909328yiv2496323061 #ygrps-yiv-630909328yiv2496323061ygrp-mlmsg { font-size:13px;font-family:Arial, helvetica, clean, sans-serif;} #ygrps-yiv-630909328 #ygrps-yiv-630909328yiv2496323061 #ygrps-yiv-630909328yiv2496323061ygrp-mlmsg table { font-size:inherit;font:100%;} #ygrps-yiv-630909328 #ygrps-yiv-630909328yiv2496323061 #ygrps-yiv-630909328yiv2496323061ygrp-mlmsg select, #ygrps-yiv-630909328 #ygrps-yiv-630909328yiv2496323061 input, #ygrps-yiv-630909328 #ygrps-yiv-630909328yiv2496323061 textarea { font:99% Arial, Helvetica, clean, sans-serif;} #ygrps-yiv-630909328 #ygrps-yiv-630909328yiv2496323061 #ygrps-yiv-630909328yiv2496323061ygrp-mlmsg pre, #ygrps-yiv-630909328 #ygrps-yiv-630909328yiv2496323061 code { font:115% monospace;} #ygrps-yiv-630909328 #ygrps-yiv-630909328yiv2496323061 #ygrps-yiv-630909328yiv2496323061ygrp-mlmsg * { line-height:1.22em;} #ygrps-yiv-630909328 #ygrps-yiv-630909328yiv2496323061 #ygrps-yiv-630909328yiv2496323061ygrp-mlmsg #ygrps-yiv-630909328yiv2496323061logo { padding-bottom:10px;} #ygrps-yiv-630909328 #ygrps-yiv-630909328yiv2496323061 #ygrps-yiv-630909328yiv2496323061ygrp-msg p a { font-family:Verdana;} #ygrps-yiv-630909328 #ygrps-yiv-630909328yiv2496323061 #ygrps-yiv-630909328yiv2496323061ygrp-msg p#ygrps-yiv-630909328yiv2496323061attach-count span { color:#1E66AE;font-weight:700;} #ygrps-yiv-630909328 #ygrps-yiv-630909328yiv2496323061 #ygrps-yiv-630909328yiv2496323061ygrp-reco #ygrps-yiv-630909328yiv2496323061reco-head { color:#ff7900;font-weight:700;} #ygrps-yiv-630909328 #ygrps-yiv-630909328yiv2496323061 #ygrps-yiv-630909328yiv2496323061ygrp-reco { margin-bottom:20px;padding:0px;} #ygrps-yiv-630909328 #ygrps-yiv-630909328yiv2496323061 #ygrps-yiv-630909328yiv2496323061ygrp-sponsor #ygrps-yiv-630909328yiv2496323061ov li a { font-size:130%;text-decoration:none;} #ygrps-yiv-630909328 #ygrps-yiv-630909328yiv2496323061 #ygrps-yiv-630909328yiv2496323061ygrp-sponsor #ygrps-yiv-630909328yiv2496323061ov li { font-size:77%;list-style-type:square;padding:6px 0;} #ygrps-yiv-630909328 #ygrps-yiv-630909328yiv2496323061 #ygrps-yiv-630909328yiv2496323061ygrp-sponsor #ygrps-yiv-630909328yiv2496323061ov ul { margin:0;padding:0 0 0 8px;} #ygrps-yiv-630909328 #ygrps-yiv-630909328yiv2496323061 #ygrps-yiv-630909328yiv2496323061ygrp-text { font-family:Georgia;} #ygrps-yiv-630909328 #ygrps-yiv-630909328yiv2496323061 #ygrps-yiv-630909328yiv2496323061ygrp-text p { margin:0 0 1em 0;} #ygrps-yiv-630909328 #ygrps-yiv-630909328yiv2496323061 #ygrps-yiv-630909328yiv2496323061ygrp-text tt { font-size:120%;} #ygrps-yiv-630909328 #ygrps-yiv-630909328yiv2496323061 #ygrps-yiv-630909328yiv2496323061ygrp-vital ul li:last-child { border-right:none !important;} #ygrps-yiv-630909328
TimNC25328
Roger StarrNC77630
Hi all
ThanxTim NC25328
Tim Potter
'Thanx for the reply. I ended up going to oreily auto parts. I told them i needed a reybestos MK1 rebuild kit. He cross refrenced it to another part # and had two kits in my hand in about 3 hours. I am going to order 2 more just to have in the future. But they are available still
Tim
NC25328
From: Robert Etter robertetter@ymail.com [fairchildclub] ;
To: fairchildclub@yahoogroups.com ;
Sent: Mon, Feb 23, 2015 6:36:32 PM
TimNC25328
Roger StarrNC77630
Hi all
ThanxTim NC25328
Tim
NC25328
TimNC25328
Roger StarrNC77630
Hi all
ThanxTim NC25328
' One thing I ran into was that the Pistons in the new kits were longer than the originals and there wasn't enough travel for the brakes to release. The seals on the new Pistons do work on the old Pistons so you can use them.
Tim
NC25328
TimNC25328
Roger StarrNC77630
Hi all
ThanxTim NC25328
On Feb 23, 2015, at 12:59 PM, Tim Potter trp.8888@yahoo.com [fairchildclub] wrote:
Tim
NC25328
TimNC25328
Roger StarrNC77630
Hi all
ThanxTim NC25328
'In case that doesn't work. NAPA Master cylinder Kit "7 47730 08109 0"Bob
On Monday, February 23, 2015 12:42 PM, "Buell bhpowell@gvtc.com [fairchildclub]" wrote:
#ygrps-yiv-40355171 #ygrps-yiv-40355171yiv3145817826 #ygrps-yiv-40355171yiv3145817826 -- #ygrps-yiv-40355171yiv3145817826ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;} #ygrps-yiv-40355171 #ygrps-yiv-40355171yiv3145817826 #ygrps-yiv-40355171yiv3145817826ygrp-mkp hr { border:1px solid #d8d8d8;} #ygrps-yiv-40355171 #ygrps-yiv-40355171yiv3145817826 #ygrps-yiv-40355171yiv3145817826ygrp-mkp #ygrps-yiv-40355171yiv3145817826hd { color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;} #ygrps-yiv-40355171 #ygrps-yiv-40355171yiv3145817826 #ygrps-yiv-40355171yiv3145817826ygrp-mkp #ygrps-yiv-40355171yiv3145817826ads { margin-bottom:10px;} #ygrps-yiv-40355171 #ygrps-yiv-40355171yiv3145817826 #ygrps-yiv-40355171yiv3145817826ygrp-mkp .ygrps-yiv-40355171yiv3145817826ad { padding:0 0;} #ygrps-yiv-40355171 #ygrps-yiv-40355171yiv3145817826 #ygrps-yiv-40355171yiv3145817826ygrp-mkp .ygrps-yiv-40355171yiv3145817826ad p { margin:0;} #ygrps-yiv-40355171 #ygrps-yiv-40355171yiv3145817826 #ygrps-yiv-40355171yiv3145817826ygrp-mkp .ygrps-yiv-40355171yiv3145817826ad a { color:#0000ff;text-decoration:none;} #ygrps-yiv-40355171 #ygrps-yiv-40355171yiv3145817826 #ygrps-yiv-40355171yiv3145817826ygrp-sponsor #ygrps-yiv-40355171yiv3145817826ygrp-lc { font-family:Arial;} #ygrps-yiv-40355171 #ygrps-yiv-40355171yiv3145817826 #ygrps-yiv-40355171yiv3145817826ygrp-sponsor #ygrps-yiv-40355171yiv3145817826ygrp-lc #ygrps-yiv-40355171yiv3145817826hd { margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;} #ygrps-yiv-40355171 #ygrps-yiv-40355171yiv3145817826 #ygrps-yiv-40355171yiv3145817826ygrp-sponsor #ygrps-yiv-40355171yiv3145817826ygrp-lc .ygrps-yiv-40355171yiv3145817826ad { margin-bottom:10px;padding:0 0;} #ygrps-yiv-40355171 #ygrps-yiv-40355171yiv3145817826 #ygrps-yiv-40355171yiv3145817826actions { font-family:Verdana;font-size:11px;padding:10px 0;} #ygrps-yiv-40355171 #ygrps-yiv-40355171yiv3145817826 #ygrps-yiv-40355171yiv3145817826activity { background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;} #ygrps-yiv-40355171 #ygrps-yiv-40355171yiv3145817826 #ygrps-yiv-40355171yiv3145817826activity span { font-weight:700;} #ygrps-yiv-40355171 #ygrps-yiv-40355171yiv3145817826 #ygrps-yiv-40355171yiv3145817826activity span:first-child { text-transform:uppercase;} #ygrps-yiv-40355171 #ygrps-yiv-40355171yiv3145817826 #ygrps-yiv-40355171yiv3145817826activity span a { color:#5085b6;text-decoration:none;} #ygrps-yiv-40355171 #ygrps-yiv-40355171yiv3145817826 #ygrps-yiv-40355171yiv3145817826activity span span { color:#ff7900;} #ygrps-yiv-40355171 #ygrps-yiv-40355171yiv3145817826 #ygrps-yiv-40355171yiv3145817826activity span .ygrps-yiv-40355171yiv3145817826underline { text-decoration:underline;} #ygrps-yiv-40355171 #ygrps-yiv-40355171yiv3145817826 .ygrps-yiv-40355171yiv3145817826attach { clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;} #ygrps-yiv-40355171 #ygrps-yiv-40355171yiv3145817826 .ygrps-yiv-40355171yiv3145817826attach div a { text-decoration:none;} #ygrps-yiv-40355171 #ygrps-yiv-40355171yiv3145817826 .ygrps-yiv-40355171yiv3145817826attach img { border:none;padding-right:5px;} #ygrps-yiv-40355171 #ygrps-yiv-40355171yiv3145817826 .ygrps-yiv-40355171yiv3145817826attach label { display:block;margin-bottom:5px;} #ygrps-yiv-40355171 #ygrps-yiv-40355171yiv3145817826 .ygrps-yiv-40355171yiv3145817826attach label a { text-decoration:none;} #ygrps-yiv-40355171 #ygrps-yiv-40355171yiv3145817826 blockquote { margin:0 0 0 4px;} #ygrps-yiv-40355171 #ygrps-yiv-40355171yiv3145817826 .ygrps-yiv-40355171yiv3145817826bold { font-family:Arial;font-size:13px;font-weight:700;} #ygrps-yiv-40355171 #ygrps-yiv-40355171yiv3145817826 .ygrps-yiv-40355171yiv3145817826bold a { text-decoration:none;} #ygrps-yiv-40355171 #ygrps-yiv-40355171yiv3145817826 dd.ygrps-yiv-40355171yiv3145817826last p a { font-family:Verdana;font-weight:700;} #ygrps-yiv-40355171 #ygrps-yiv-40355171yiv3145817826 dd.ygrps-yiv-40355171yiv3145817826last p span { margin-right:10px;font-family:Verdana;font-weight:700;} #ygrps-yiv-40355171 #ygrps-yiv-40355171yiv3145817826 dd.ygrps-yiv-40355171yiv3145817826last p span.ygrps-yiv-40355171yiv3145817826yshortcuts { margin-right:0;} #ygrps-yiv-40355171 #ygrps-yiv-40355171yiv3145817826 div.ygrps-yiv-40355171yiv3145817826attach-table div div a { text-decoration:none;} #ygrps-yiv-40355171 #ygrps-yiv-40355171yiv3145817826 div.ygrps-yiv-40355171yiv3145817826attach-table { width:400px;} #ygrps-yiv-40355171 #ygrps-yiv-40355171yiv3145817826 div.ygrps-yiv-40355171yiv3145817826file-title a, #ygrps-yiv-40355171 #ygrps-yiv-40355171yiv3145817826 div.ygrps-yiv-40355171yiv3145817826file-title a:active, #ygrps-yiv-40355171 #ygrps-yiv-40355171yiv3145817826 div.ygrps-yiv-40355171yiv3145817826file-title a:hover, #ygrps-yiv-40355171 #ygrps-yiv-40355171yiv3145817826 div.ygrps-yiv-40355171yiv3145817826file-title a:visited { text-decoration:none;} #ygrps-yiv-40355171 #ygrps-yiv-40355171yiv3145817826 div.ygrps-yiv-40355171yiv3145817826photo-title a, #ygrps-yiv-40355171 #ygrps-yiv-40355171yiv3145817826 div.ygrps-yiv-40355171yiv3145817826photo-title a:active, #ygrps-yiv-40355171 #ygrps-yiv-40355171yiv3145817826 div.ygrps-yiv-40355171yiv3145817826photo-title a:hover, #ygrps-yiv-40355171 #ygrps-yiv-40355171yiv3145817826 div.ygrps-yiv-40355171yiv3145817826photo-title a:visited { text-decoration:none;} #ygrps-yiv-40355171 #ygrps-yiv-40355171yiv3145817826 div#ygrps-yiv-40355171yiv3145817826ygrp-mlmsg #ygrps-yiv-40355171yiv3145817826ygrp-msg p a span.ygrps-yiv-40355171yiv3145817826yshortcuts { font-family:Verdana;font-size:10px;font-weight:normal;} #ygrps-yiv-40355171 #ygrps-yiv-40355171yiv3145817826 .ygrps-yiv-40355171yiv3145817826green { color:#628c2a;} #ygrps-yiv-40355171 #ygrps-yiv-40355171yiv3145817826 .ygrps-yiv-40355171yiv3145817826MsoNormal { margin:0 0 0 0;} #ygrps-yiv-40355171 #ygrps-yiv-40355171yiv3145817826 o { font-size:0;} #ygrps-yiv-40355171 #ygrps-yiv-40355171yiv3145817826 #ygrps-yiv-40355171yiv3145817826photos div { float:left;width:72px;} #ygrps-yiv-40355171 #ygrps-yiv-40355171yiv3145817826 #ygrps-yiv-40355171yiv3145817826photos div div { border:1px solid #666666;height:62px;overflow:hidden;width:62px;} #ygrps-yiv-40355171 #ygrps-yiv-40355171yiv3145817826 #ygrps-yiv-40355171yiv3145817826photos div label { color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;} #ygrps-yiv-40355171 #ygrps-yiv-40355171yiv3145817826 #ygrps-yiv-40355171yiv3145817826reco-category { font-size:77%;} #ygrps-yiv-40355171 #ygrps-yiv-40355171yiv3145817826 #ygrps-yiv-40355171yiv3145817826reco-desc { font-size:77%;} #ygrps-yiv-40355171 #ygrps-yiv-40355171yiv3145817826 .ygrps-yiv-40355171yiv3145817826replbq { margin:4px;} #ygrps-yiv-40355171 #ygrps-yiv-40355171yiv3145817826 #ygrps-yiv-40355171yiv3145817826ygrp-actbar div a:first-child { margin-right:2px;padding-right:5px;} #ygrps-yiv-40355171 #ygrps-yiv-40355171yiv3145817826 #ygrps-yiv-40355171yiv3145817826ygrp-mlmsg { font-size:13px;font-family:Arial, helvetica, clean, sans-serif;} #ygrps-yiv-40355171 #ygrps-yiv-40355171yiv3145817826 #ygrps-yiv-40355171yiv3145817826ygrp-mlmsg table { font-size:inherit;font:100%;} #ygrps-yiv-40355171 #ygrps-yiv-40355171yiv3145817826 #ygrps-yiv-40355171yiv3145817826ygrp-mlmsg select, #ygrps-yiv-40355171 #ygrps-yiv-40355171yiv3145817826 input, #ygrps-yiv-40355171 #ygrps-yiv-40355171yiv3145817826 textarea { font:99% Arial, Helvetica, clean, sans-serif;} #ygrps-yiv-40355171 #ygrps-yiv-40355171yiv3145817826 #ygrps-yiv-40355171yiv3145817826ygrp-mlmsg pre, #ygrps-yiv-40355171 #ygrps-yiv-40355171yiv3145817826 code { font:115% monospace;} #ygrps-yiv-40355171 #ygrps-yiv-40355171yiv3145817826 #ygrps-yiv-40355171yiv3145817826ygrp-mlmsg * { line-height:1.22em;} #ygrps-yiv-40355171 #ygrps-yiv-40355171yiv3145817826 #ygrps-yiv-40355171yiv3145817826ygrp-mlmsg #ygrps-yiv-40355171yiv3145817826logo { padding-bottom:10px;} #ygrps-yiv-40355171 #ygrps-yiv-40355171yiv3145817826 #ygrps-yiv-40355171yiv3145817826ygrp-msg p a { font-family:Verdana;} #ygrps-yiv-40355171 #ygrps-yiv-40355171yiv3145817826 #ygrps-yiv-40355171yiv3145817826ygrp-msg p#ygrps-yiv-40355171yiv3145817826attach-count span { color:#1E66AE;font-weight:700;} #ygrps-yiv-40355171 #ygrps-yiv-40355171yiv3145817826 #ygrps-yiv-40355171yiv3145817826ygrp-reco #ygrps-yiv-40355171yiv3145817826reco-head { color:#ff7900;font-weight:700;} #ygrps-yiv-40355171 #ygrps-yiv-40355171yiv3145817826 #ygrps-yiv-40355171yiv3145817826ygrp-reco { margin-bottom:20px;padding:0px;} #ygrps-yiv-40355171 #ygrps-yiv-40355171yiv3145817826 #ygrps-yiv-40355171yiv3145817826ygrp-sponsor #ygrps-yiv-40355171yiv3145817826ov li a { font-size:130%;text-decoration:none;} #ygrps-yiv-40355171 #ygrps-yiv-40355171yiv3145817826 #ygrps-yiv-40355171yiv3145817826ygrp-sponsor #ygrps-yiv-40355171yiv3145817826ov li { font-size:77%;list-style-type:square;padding:6px 0;} #ygrps-yiv-40355171 #ygrps-yiv-40355171yiv3145817826 #ygrps-yiv-40355171yiv3145817826ygrp-sponsor #ygrps-yiv-40355171yiv3145817826ov ul { margin:0;padding:0 0 0 8px;} #ygrps-yiv-40355171 #ygrps-yiv-40355171yiv3145817826 #ygrps-yiv-40355171yiv3145817826ygrp-text { font-family:Georgia;} #ygrps-yiv-40355171 #ygrps-yiv-40355171yiv3145817826 #ygrps-yiv-40355171yiv3145817826ygrp-text p { margin:0 0 1em 0;} #ygrps-yiv-40355171 #ygrps-yiv-40355171yiv3145817826 #ygrps-yiv-40355171yiv3145817826ygrp-text tt { font-size:120%;} #ygrps-yiv-40355171 #ygrps-yiv-40355171yiv3145817826 #ygrps-yiv-40355171yiv3145817826ygrp-vital ul li:last-child { border-right:none !important;} #ygrps-yiv-40355171Thanx for the reply. I ended up going to oreily auto parts. I told them i needed a reybestos MK1 rebuild kit. He cross refrenced it to another part # and had two kits in my hand in about 3 hours. I am going to order 2 more just to have in the future. But they are available still
Tim
NC25328
TimNC25328
Roger StarrNC77630
Hi all
ThanxTim NC25328
'Thanks for the refresher. I thought that there was something in the NAPA Kit that wouldn't work. How is NC 81330 coming along.I am real close to hanging the motor. I got most of the dents out of my dish pan. There was some real tough one on the outer edge. The reinforcement on the outer edge kept me from doing a great job. So... out with the Bondo.Getting the bolt to go through the Motor mounts and the mount were a real head ache. I didn't damage the threads on the bolts much at all. A little on the first thread was all.Another bit of 1948 damage showed up that I didn't notice. The rudder "C channel" had been spliced. Didn't catch that the rear former on the back of the fuselage had been install about 3/4" aft of where it should have been and maybe 1/2" too tall. It made installing the fairings around the rudder & stabilizer interesting.Bob
#ygrps-yiv-100585807 #ygrps-yiv-100585807yiv3864894193 -- #ygrps-yiv-100585807yiv3864894193ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;} #ygrps-yiv-100585807 #ygrps-yiv-100585807yiv3864894193 #ygrps-yiv-100585807yiv3864894193ygrp-mkp hr { border:1px solid #d8d8d8;} #ygrps-yiv-100585807 #ygrps-yiv-100585807yiv3864894193 #ygrps-yiv-100585807yiv3864894193ygrp-mkp #ygrps-yiv-100585807yiv3864894193hd { color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;} #ygrps-yiv-100585807 #ygrps-yiv-100585807yiv3864894193 #ygrps-yiv-100585807yiv3864894193ygrp-mkp #ygrps-yiv-100585807yiv3864894193ads { margin-bottom:10px;} #ygrps-yiv-100585807 #ygrps-yiv-100585807yiv3864894193 #ygrps-yiv-100585807yiv3864894193ygrp-mkp .ygrps-yiv-100585807yiv3864894193ad { padding:0 0;} #ygrps-yiv-100585807 #ygrps-yiv-100585807yiv3864894193 #ygrps-yiv-100585807yiv3864894193ygrp-mkp .ygrps-yiv-100585807yiv3864894193ad p { margin:0;} #ygrps-yiv-100585807 #ygrps-yiv-100585807yiv3864894193 #ygrps-yiv-100585807yiv3864894193ygrp-mkp .ygrps-yiv-100585807yiv3864894193ad a { color:#0000ff;text-decoration:none;} #ygrps-yiv-100585807 #ygrps-yiv-100585807yiv3864894193 #ygrps-yiv-100585807yiv3864894193ygrp-sponsor #ygrps-yiv-100585807yiv3864894193ygrp-lc { font-family:Arial;} #ygrps-yiv-100585807 #ygrps-yiv-100585807yiv3864894193 #ygrps-yiv-100585807yiv3864894193ygrp-sponsor #ygrps-yiv-100585807yiv3864894193ygrp-lc #ygrps-yiv-100585807yiv3864894193hd { margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;} #ygrps-yiv-100585807 #ygrps-yiv-100585807yiv3864894193 #ygrps-yiv-100585807yiv3864894193ygrp-sponsor #ygrps-yiv-100585807yiv3864894193ygrp-lc .ygrps-yiv-100585807yiv3864894193ad { margin-bottom:10px;padding:0 0;} #ygrps-yiv-100585807 #ygrps-yiv-100585807yiv3864894193 #ygrps-yiv-100585807yiv3864894193actions { font-family:Verdana;font-size:11px;padding:10px 0;} #ygrps-yiv-100585807 #ygrps-yiv-100585807yiv3864894193 #ygrps-yiv-100585807yiv3864894193activity { background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;} #ygrps-yiv-100585807 #ygrps-yiv-100585807yiv3864894193 #ygrps-yiv-100585807yiv3864894193activity span { font-weight:700;} #ygrps-yiv-100585807 #ygrps-yiv-100585807yiv3864894193 #ygrps-yiv-100585807yiv3864894193activity span:first-child { text-transform:uppercase;} #ygrps-yiv-100585807 #ygrps-yiv-100585807yiv3864894193 #ygrps-yiv-100585807yiv3864894193activity span a { color:#5085b6;text-decoration:none;} #ygrps-yiv-100585807 #ygrps-yiv-100585807yiv3864894193 #ygrps-yiv-100585807yiv3864894193activity span span { color:#ff7900;} #ygrps-yiv-100585807 #ygrps-yiv-100585807yiv3864894193 #ygrps-yiv-100585807yiv3864894193activity span .ygrps-yiv-100585807yiv3864894193underline { text-decoration:underline;} #ygrps-yiv-100585807 #ygrps-yiv-100585807yiv3864894193 .ygrps-yiv-100585807yiv3864894193attach { clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;} #ygrps-yiv-100585807 #ygrps-yiv-100585807yiv3864894193 .ygrps-yiv-100585807yiv3864894193attach div a { text-decoration:none;} #ygrps-yiv-100585807 #ygrps-yiv-100585807yiv3864894193 .ygrps-yiv-100585807yiv3864894193attach img { border:none;padding-right:5px;} #ygrps-yiv-100585807 #ygrps-yiv-100585807yiv3864894193 .ygrps-yiv-100585807yiv3864894193attach label { display:block;margin-bottom:5px;} #ygrps-yiv-100585807 #ygrps-yiv-100585807yiv3864894193 .ygrps-yiv-100585807yiv3864894193attach label a { text-decoration:none;} #ygrps-yiv-100585807 #ygrps-yiv-100585807yiv3864894193 blockquote { margin:0 0 0 4px;} #ygrps-yiv-100585807 #ygrps-yiv-100585807yiv3864894193 .ygrps-yiv-100585807yiv3864894193bold { font-family:Arial;font-size:13px;font-weight:700;} #ygrps-yiv-100585807 #ygrps-yiv-100585807yiv3864894193 .ygrps-yiv-100585807yiv3864894193bold a { text-decoration:none;} #ygrps-yiv-100585807 #ygrps-yiv-100585807yiv3864894193 dd.ygrps-yiv-100585807yiv3864894193last p a { font-family:Verdana;font-weight:700;} #ygrps-yiv-100585807 #ygrps-yiv-100585807yiv3864894193 dd.ygrps-yiv-100585807yiv3864894193last p span { margin-right:10px;font-family:Verdana;font-weight:700;} #ygrps-yiv-100585807 #ygrps-yiv-100585807yiv3864894193 dd.ygrps-yiv-100585807yiv3864894193last p span.ygrps-yiv-100585807yiv3864894193yshortcuts { margin-right:0;} #ygrps-yiv-100585807 #ygrps-yiv-100585807yiv3864894193 div.ygrps-yiv-100585807yiv3864894193attach-table div div a { text-decoration:none;} #ygrps-yiv-100585807 #ygrps-yiv-100585807yiv3864894193 div.ygrps-yiv-100585807yiv3864894193attach-table { width:400px;} #ygrps-yiv-100585807 #ygrps-yiv-100585807yiv3864894193 div.ygrps-yiv-100585807yiv3864894193file-title a, #ygrps-yiv-100585807 #ygrps-yiv-100585807yiv3864894193 div.ygrps-yiv-100585807yiv3864894193file-title a:active, #ygrps-yiv-100585807 #ygrps-yiv-100585807yiv3864894193 div.ygrps-yiv-100585807yiv3864894193file-title a:hover, #ygrps-yiv-100585807 #ygrps-yiv-100585807yiv3864894193 div.ygrps-yiv-100585807yiv3864894193file-title a:visited { text-decoration:none;} #ygrps-yiv-100585807 #ygrps-yiv-100585807yiv3864894193 div.ygrps-yiv-100585807yiv3864894193photo-title a, #ygrps-yiv-100585807 #ygrps-yiv-100585807yiv3864894193 div.ygrps-yiv-100585807yiv3864894193photo-title a:active, #ygrps-yiv-100585807 #ygrps-yiv-100585807yiv3864894193 div.ygrps-yiv-100585807yiv3864894193photo-title a:hover, #ygrps-yiv-100585807 #ygrps-yiv-100585807yiv3864894193 div.ygrps-yiv-100585807yiv3864894193photo-title a:visited { text-decoration:none;} #ygrps-yiv-100585807 #ygrps-yiv-100585807yiv3864894193 div#ygrps-yiv-100585807yiv3864894193ygrp-mlmsg #ygrps-yiv-100585807yiv3864894193ygrp-msg p a span.ygrps-yiv-100585807yiv3864894193yshortcuts { font-family:Verdana;font-size:10px;font-weight:normal;} #ygrps-yiv-100585807 #ygrps-yiv-100585807yiv3864894193 .ygrps-yiv-100585807yiv3864894193green { color:#628c2a;} #ygrps-yiv-100585807 #ygrps-yiv-100585807yiv3864894193 .ygrps-yiv-100585807yiv3864894193MsoNormal { margin:0 0 0 0;} #ygrps-yiv-100585807 #ygrps-yiv-100585807yiv3864894193 o { font-size:0;} #ygrps-yiv-100585807 #ygrps-yiv-100585807yiv3864894193 #ygrps-yiv-100585807yiv3864894193photos div { float:left;width:72px;} #ygrps-yiv-100585807 #ygrps-yiv-100585807yiv3864894193 #ygrps-yiv-100585807yiv3864894193photos div div { border:1px solid #666666;height:62px;overflow:hidden;width:62px;} #ygrps-yiv-100585807 #ygrps-yiv-100585807yiv3864894193 #ygrps-yiv-100585807yiv3864894193photos div label { color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;} #ygrps-yiv-100585807 #ygrps-yiv-100585807yiv3864894193 #ygrps-yiv-100585807yiv3864894193reco-category { font-size:77%;} #ygrps-yiv-100585807 #ygrps-yiv-100585807yiv3864894193 #ygrps-yiv-100585807yiv3864894193reco-desc { font-size:77%;} #ygrps-yiv-100585807 #ygrps-yiv-100585807yiv3864894193 .ygrps-yiv-100585807yiv3864894193replbq { margin:4px;} #ygrps-yiv-100585807 #ygrps-yiv-100585807yiv3864894193 #ygrps-yiv-100585807yiv3864894193ygrp-actbar div a:first-child { margin-right:2px;padding-right:5px;} #ygrps-yiv-100585807 #ygrps-yiv-100585807yiv3864894193 #ygrps-yiv-100585807yiv3864894193ygrp-mlmsg { font-size:13px;font-family:Arial, helvetica, clean, sans-serif;} #ygrps-yiv-100585807 #ygrps-yiv-100585807yiv3864894193 #ygrps-yiv-100585807yiv3864894193ygrp-mlmsg table { font-size:inherit;font:100%;} #ygrps-yiv-100585807 #ygrps-yiv-100585807yiv3864894193 #ygrps-yiv-100585807yiv3864894193ygrp-mlmsg select, #ygrps-yiv-100585807 #ygrps-yiv-100585807yiv3864894193 input, #ygrps-yiv-100585807 #ygrps-yiv-100585807yiv3864894193 textarea { font:99% Arial, Helvetica, clean, sans-serif;} #ygrps-yiv-100585807 #ygrps-yiv-100585807yiv3864894193 #ygrps-yiv-100585807yiv3864894193ygrp-mlmsg pre, #ygrps-yiv-100585807 #ygrps-yiv-100585807yiv3864894193 code { font:115% monospace;} #ygrps-yiv-100585807 #ygrps-yiv-100585807yiv3864894193 #ygrps-yiv-100585807yiv3864894193ygrp-mlmsg * { line-height:1.22em;} #ygrps-yiv-100585807 #ygrps-yiv-100585807yiv3864894193 #ygrps-yiv-100585807yiv3864894193ygrp-mlmsg #ygrps-yiv-100585807yiv3864894193logo { padding-bottom:10px;} #ygrps-yiv-100585807 #ygrps-yiv-100585807yiv3864894193 #ygrps-yiv-100585807yiv3864894193ygrp-msg p a { font-family:Verdana;} #ygrps-yiv-100585807 #ygrps-yiv-100585807yiv3864894193 #ygrps-yiv-100585807yiv3864894193ygrp-msg p#ygrps-yiv-100585807yiv3864894193attach-count span { color:#1E66AE;font-weight:700;} #ygrps-yiv-100585807 #ygrps-yiv-100585807yiv3864894193 #ygrps-yiv-100585807yiv3864894193ygrp-reco #ygrps-yiv-100585807yiv3864894193reco-head { color:#ff7900;font-weight:700;} #ygrps-yiv-100585807 #ygrps-yiv-100585807yiv3864894193 #ygrps-yiv-100585807yiv3864894193ygrp-reco { margin-bottom:20px;padding:0px;} #ygrps-yiv-100585807 #ygrps-yiv-100585807yiv3864894193 #ygrps-yiv-100585807yiv3864894193ygrp-sponsor #ygrps-yiv-100585807yiv3864894193ov li a { font-size:130%;text-decoration:none;} #ygrps-yiv-100585807 #ygrps-yiv-100585807yiv3864894193 #ygrps-yiv-100585807yiv3864894193ygrp-sponsor #ygrps-yiv-100585807yiv3864894193ov li { font-size:77%;list-style-type:square;padding:6px 0;} #ygrps-yiv-100585807 #ygrps-yiv-100585807yiv3864894193 #ygrps-yiv-100585807yiv3864894193ygrp-sponsor #ygrps-yiv-100585807yiv3864894193ov ul { margin:0;padding:0 0 0 8px;} #ygrps-yiv-100585807 #ygrps-yiv-100585807yiv3864894193 #ygrps-yiv-100585807yiv3864894193ygrp-text { font-family:Georgia;} #ygrps-yiv-100585807 #ygrps-yiv-100585807yiv3864894193 #ygrps-yiv-100585807yiv3864894193ygrp-text p { margin:0 0 1em 0;} #ygrps-yiv-100585807 #ygrps-yiv-100585807yiv3864894193 #ygrps-yiv-100585807yiv3864894193ygrp-text tt { font-size:120%;} #ygrps-yiv-100585807 #ygrps-yiv-100585807yiv3864894193 #ygrps-yiv-100585807yiv3864894193ygrp-vital ul li:last-child { border-right:none !important;} #ygrps-yiv-100585807Thanx for the reply. I ended up going to oreily auto parts. I told them i needed a reybestos MK1 rebuild kit. He cross refrenced it to another part # and had two kits in my hand in about 3 hours. I am going to order 2 more just to have in the future. But they are available still
Tim
NC25328
TimNC25328
Roger StarrNC77630
Hi all
ThanxTim NC25328
'When hammering bolts. Always use a "Bullet" in the holes first to line everything up. Then tap the bullet out with your new bolt. The bullet gets every aligned. The Bolt just follows resulting very little if any damage. One makes a bullet from the right sized bolt. Cut off the head. Taper one end to act as a drift. Doesn't have to be very long, just long enough for a gentle taper plus a straight section to bridge any gap between the two parts that need aligning and bolted. Make the other end a square as possible. But you being a good mechanic already knew all this. Cy Galley - Chairman of Emergency Aircraft RepairA service project of EAA Chapter 75 From: fairchildclub@yahoogroups.com [mailto:fairchildclub@yahoogroups.com]
Sent: Monday, February 23, 2015 6:11 PM
Subject: Re: [fairchildclub] F24 brake master cylinders Thanks for the refresher. I thought that there was something in the NAPA Kit that wouldn't work. How is NC 81330 coming along.I am real close to hanging the motor. I got most of the dents out of my dish pan. There was some real tough one on the outer edge. The reinforcement on the outer edge kept me from doing a great job. So... out with the Bondo.Getting the bolt to go through the Motor mounts and the mount were a real head ache. I didn't damage the threads on the bolts much at all. A little on the first thread was all.Another bit of 1948 damage showed up that I didn't notice. The rudder "C channel" had been spliced. Didn't catch that the rear former on the back of the fuselage had been install about 3/4" aft of where it should have been and maybe 1/2" too tall. It made installing the fairings around the rudder & stabilizer interesting.Bob On Monday, February 23, 2015 3:51 PM, Robert Etter wrote: In case that doesn't work. NAPA Master cylinder Kit "7 47730 08109 0"Bob On Monday, February 23, 2015 12:42 PM, "Buell bhpowell@gvtc.com [fairchildclub]" wrote: One thing I ran into was that the Pistons in the new kits were longer than the originals and there wasn't enough travel for the brakes to release. The seals on the new Pistons do work on the old Pistons so you can use them.
Tim
NC25328 From: Robert Etter robertetter@ymail.com [fairchildclub] ;
Sent: Mon, Feb 23, 2015 6:36:32 PM NAPA Kit #1 will do it. The NAPA bar code is in one of the old E-mails, somewhere. I don't remember if 100% of the parts that are in the kit will be an exact substitute for all of the internal workings of the master cylinder, but I do remember that all of the rubbers parts work. If NAPA can't find it, I know that I still have one of the kits. You could also try to do a search of the past E-mails, and find some more information. I passed the same information to someone many years ago. There is many shops out there that can reface the wall of the master cylinder. If you have FE-1990, the wall thickness may not allow resurfacing. CD Drawing #42281 shows the cast iron master cylinder at the top, and the Wagner Fe-1990 at the bottom. For the Fe-1990, the one I had, it did have a manufacturers label on it. The drawing didn't say anything.Bob On Sunday, February 22, 2015 8:19 PM, "Home ptcurt@gmail.com [fairchildclub]" wrote: Go to a tire shop, especially one that does race cars, etc. Used to working on odd sizes and mags. Usually will do them for free because it is something cool and different! Curt Kinchen
ptcurt@gmail.comFrom: Tim Potter trp.8888@yahoo.com [fairchildclub]Sent: Saturday, February 21, 2015 8:34 PMTo: fairchildclub@yahoogroups.comReply To: fairchildclub@yahoogroups.comSubject: Re: [fairchildclub] F24 brake master cylinders thanx for the response. I did some research and found that exact kit. I got it in the ol girl today and am going to test it tomorrow. I also put new tires and tubes on......WOW that was a pain in the ass!! Not having split wheels make it very tuff to do. Took me about 8 hours. TimNC25328 On Saturday, February 21, 2015 1:55 PM, "Ellen Starr ellengstarr@yahoo.com [fairchildclub]" wrote: Tim,Believe I have the same cylinders in my brake system. Used some parts from NAPA haudraulic kit #1 to rebuilt them. Think the cup was one item used. Also had the cylinders resleeved and bored by a fellow in CA. Roger StarrNC77630 From: "trp.8888@yahoo.com [fairchildclub]"
Subject: [fairchildclub] F24 brake master cylinders Hi all I have a 1940 F24W-40My brake cylinders are leaking bad. They appear to be made by lockheed and are a round tube with a brass plunger, spring, and rubber cup inside. The part that is leaking is the rubber gasket/o ring around the brass plunger. Any clue where I can buy new gaskets? ThanxTim NC25328
