Re: advise
advise
'If a fellow is restoring a F24 46R, what color should the frame be painted?
Jeff
Jeff Whitesell
topfun@fivetogether.com'
Jeff
Jeff Whitesell
Re: advise
'I've seen black, red, green, blue, Zinc Yellow....
I guess it all depends on your need
My frame was zinc-green primer and then Polurathane Green over that to match our WOrld War 2 color scheme on our UC-61K
Sent: Friday, December 7, 2012 12:40 AM
Subject: [fairchildclub] advise
Jeff
Jeff Whitesell
mailto:topfun%40fivetogether.com
Jeff
Jeff Whitesell
Re: advise
'Actually the fuselage frame is 4130 steel, Zink Chromate is for aluminum and Iron oxide primers are for steel.
> Jim Â
> From: Jeffrey Whitesell
> Â
> Jeff
> Jeff Whitesell
Re: advise
'Funny, The military used Yellow Zinc chromate for most anything on aircraft.
Today, Epoxy primers are a must as the paint solvents and fabric liquids
will dissolve most anything leaving the substrate unprotected. Use whatever
color you think you want or need.
On Behalf Of Tom_Downey
Sent: Friday, December 07, 2012 9:20 AM
Subject: [fairchildclub] Re: advise
, james chybicki
, james chybicki
match our WOrld War 2 color scheme on our UC-61K>
painted?> Jim Â
> Â
> Jeff
> Jeff Whitesell
Re: advise
'Thanks, gentlemen. what your feeling on powdercoating?
Jeff
Jeff
> , james chybicki
> > My frame was zinc-green primer? and then Polurathane Green over that to
> match our WOrld War 2 color scheme? on our UC-61K
> > Jim? ?
> painted?
> > Jeff
> > Jeff Whitesell
Jeff Whitesell
Re: advise
'Powder coating prevents proper inspections in the future. It hides cracks
Jim Higham
N81207
F24R46-108
Jim Higham
N81207
F24R46-108
> Jeff
>> , james chybicki
>>> Jim Â
>>> Â
>> painted?
>>> Jeff
>>> Jeff Whitesell
> Jeff Whitesell
Re: advise
'Are you asking about original colors or what others are doing? PM sent.
> Jeff
> Jeff Whitesell
> topfun@...
Re: advise
'So does paint, at about the same rate. After all, powder coating is only powdered paint applied by heat.
> Jim Higham
> N81207
> F24R46-108
> > Jeff
> >> , james chybicki
> >>> My frame was zinc-green primerÃ? and then Polurathane Green over that to
> >> match our WOrld War 2 color schemeÃ? on our UC-61K
> >>> JimÃ? Ã?
> >>> Ã?
> >> painted?
> >>> Jeff
> >>> Jeff Whitesell
> > Jeff Whitesell
> > topfun@...
> > Yahoo! Groups Links
Re: advise
'Metal can corrode under power coating and it cannot be seen. As stated the
integrity of the metal is more difficult to inspect when power coated.
Jack M. Threadgill
1602 Brook Hollow Dr
Bryan, Texas 77802
979-779-7155
threadgl@suddenlink.net
Sent: Saturday, December 08, 2012 7:31 PM
Jack M. Threadgill
Bryan, Texas 77802
979-779-7155
, Jim wrote:
aircraft.>
> Jim Higham
> N81207
> F24R46-108
> > Jeff
liquids> >>
whatever> >> will dissolve most anything leaving the substrate unprotected. Use
aluminum and> >> Subject: [fairchildclub] Re: advise
to> >> , james chybicki
> >>> JimÃ? Ã?
[Non-text portions of this message have been removed]'> >>
> >>> Ã?
> >> painted?
> >>> Jeff
> >>> Jeff Whitesell
> > Jeff Whitesell
> > topfun@...
> > Yahoo! Groups Links
Re: advise
'I am interested in staying as close as possible to original colors, with of course, modern materials
> > Jeff
> > Jeff Whitesell
> > topfun@...
Jeff Whitesell
