'I have a Ranger Engineering Corp generator to install on my PT19B. it's 14 volt, 12 Amp. My question is what voltage regulator should I use? Does the amperage of the regulator matter as long as it is over 12 Amp? I see several on eBay that are in the range of 35 amp.
I think the 12 amps should be sufficient to charge the battery and run a couple of modern radios. Though I'm not sure what the cut in RPM is. It's marked 3300 RPM is that the cut in speed or the max output speed of the generator?
Thoughts?
Regards,'
Re: Voltage Regulator
'Some one out there could correct me, if my memory serves me correctly, You can get a Regulator from NAPA. It is probably set for 25 amps. What would be necessary is to have someone reset the output from 25 amps, down to the 12 amps that you can use. If you put it on the output of your generator set for 25 amps and your load exceeded the 12 amp capacity of your generator, you will be buying a new generator. The 14-13-3 Bellanca that I had years ago had a 25 amp generator, and I made the mistake of touching the output limit setting, and smoked the generator when I went gear up.
Sent: Monday, August 27, 2012 10:15 AM
Subject: [fairchildclub] Voltage Regulator
Thoughts?
Regards,
Thoughts?
Regards,
'Hi,
I have recently had success with Aerotech in Louisville. It will cost a little more than a NAPA regulator but should last longer and be correctly matched to your generator. John Evans at Aerotech should be able to answer most questions.
www.aerotechlou.com
Rick
www.aerotechlou.com
Rick
> Thoughts?
> Regards,
'Thanks for the information. I will contact them and see what they have to say.
Regards,
Thane
Regards,
Thane
'--- In fairchildclub@yahoogroups.com, "RMR" wrote:
> Hi,
> www.aerotechlou.com
> Rick
> > Thoughts?
> > Regards,
'Cut in on mine is about 1600 rpm, engine that is. Not sure what the generator drive ratio is.
Curt
Sent via BlackBerry by AT&T
Sender: fairchildclub@yahoogroups.com
Date: Wed, 29 Aug 2012 03:24:24
Reply-To: fairchildclub@yahoogroups.com
Subject: [fairchildclub] Re: Voltage Regulator
Regards,
Thane
Curt
Regards,
Thane
> Hi,
> www.aerotechlou.com
> Rick
> > Thoughts?
> > Regards,
'Curt,
What generator and voltage regulator are you using on your PT.
Thane
Thane
> Curt
> From: "pt19b2001"
> Regards,
> Thane
> > Hi,
> > www.aerotechlou.com
> > Rick
> > > Thoughts?
> > > Regards,
