'I have a rudder that has all cherry rivets instead of the bucked rivets. It's the only one I've seen that way but it is
factory and not a repair. I suspect that this was a Fleet built rudder since the lighting holes in the ribs have a raised flange around them instead of the typical chamfered edge that I see on all the other parts I have.
Keep 'em Flying !
Mike Kelly
Fairchild Club'
Re: Cherry Rivets on T.E. of elevator on PT.
Michael Kelly
Pete Crawford
'Mike / Jerry,
That's a good idea. What type of rivet in particular? It needs to be 3/32" dia. with a grip of .050". Most of the Cherry rivets I've seen don't go smaller than 1/8". Can you recommend something?
Pete Crawford
Pete Crawford
Sent: Monday, October 10, 2011 3:03 PM
Subject: [fairchildclub] Cherry Rivets on T.E. of elevator on PT.
Keep 'em Flying !
Mike Kelly
Fairchild Club
'PETE...TRY AIRCRAFT SPRUCE.THEY HAVE CHERRY RIVETS.ALSO A HELP LINE.
877-477-7823.THEY MIGHT HAVE JUST WHAT YOUR LOOKING FOR.>>>JERRY
'--- In fairchildclub@yahoogroups.com, "Pete Crawford" wrote:
> Mike / Jerry,
> Thanks,
> Pete Crawford
> From: Michael kelly
> Keep 'em Flying !
> Mike Kelly
> Fairchild Club
Steve Link
'I'd have to agree with the pull type rivet. As delicate an area you are
working with it just be a lot simpler..
On Behalf Of JERRY
Sent: Tuesday, October 11, 2011 3:54 PM
Subject: [fairchildclub] Re: Cherry Rivets on T.E. of elevator on PT.
, "Pete Crawford"
have.
On Behalf Of JERRY
, "Pete Crawford"
dia. with a grip of .050". Most of the Cherry rivets I've seen don't go>
> Mike / Jerry,
It's the only one I've seen that way but it is> Thanks,
> Pete Crawford
> From: Michael kelly
since the lighting holes in the ribs have a raised flange around them>
have.
> Keep 'em Flying !
> Mike Kelly
> Fairchild Club
