'Hello all,
     I had a couple of questions for all of you regarding the Warner 165 and the Ranger 200HP engines.  For a little back ground, I was part of this forum before and I had asked some questions because I was considering purchasing a Fairchild 24.  IN my searches, I ended up buying a Stinson 108 instead.  I tell youthis because I have found my old threads and I am used to classic aircraft.  However I'm short quite a bit of info on the engines used on the Model 24 and I am considering adding to my aircraft and I need some info if I am going to do this.
    I will take each engine in turn and ask a couple of questions and any information that I have found on my own.
 Warner Scarab (165hp) radial
 As I understand this engine, there isn't a TBO because normally every 400 hours you tear it down to clean out the sludge buildup because the engine doesn't have an oil filter.  I have also seen a company called Radial Engines Limited that says they will no longer work on these engines due to a shortage of parts.  So, I ask the following questions:
 How reliable are the Warner radials?
 Can you get parts and/or overhauls for these engines?
 What would an overhaul cost?
 Can you add an oil filter system and are there any STC for an oil filter kit?
 Is there anything particular to this engine that someone new to Fairchilds and radial engines need to be aware of (I'm aware of the hydraulic lock precaution)?
 I have seen both fixed pitch wooden and Aeromatic propellors in pictures. What type of propellers are available?
 Are there any spinners available for the Warner?
 Ranger (200hp) Inline
 I gather that there are a lot more of these engines available since Fairchild made a lot during WWII for their various aircraft. I have far less info on these engines as far as TBO, places that work on them, or oil filtration.
 How reliable are the Ranger engines?
 Can you get parts and/or overhauls for these egines?
 Can you add an oil filter system to the Ranger?
 Are there any STCs for an oil filter kit?
 I have seen fixed pitch wood and Aeromatic propellors in pictures.  What types of propellers are available?
 Are there spinners available or necessary?
 Finally, which engine is considered more desirable?  From my searches, it appears the long nose 24s with the Ranger engine have higher asking prices than the Warner powered aircraft.
 Thank you in advance for your help.  I greatly appreciate any info that you can give me.
 Sincerely,
    Karl
						Re: Fairchild 24 Engines
'Karl,
Call me direct,I can answer most of your questions. Cell is fine.
Fairchild Club CD ROM Editor
IAC 5, Chapter President
http://iac5.org
Kelly Airpark (CO15)
http://www.kellyairpark.com
Elbert, CO 80106
Hm/Hgr 303-648-0130
Cell 303-304-7937
Quote of the Month: I hope you either take up parachute jumping or stay out of single motored airplanes at night.
- Charles A. Lindbergh, to Wiley Post 1931
http://iac5.org
Elbert, CO 80106
Hm/Hgr 303-648-0130
Cell 303-304-7937
Sent: Sunday, June 05, 2011 11:33 AM
Subject: [fairchildclub] Fairchild 24 Engines
Hello all,
Sincerely,
Karl
'ADC Installed on f-24 warner 165 no paperwork available.
Sent: Sun, June 5, 2011 2:33:50 PM
Hello all,
give me.
Sincerely,
Karl
Hello all,
give me.
Sincerely,
Karl
