Re: Fabric covering Qestion?
Stuart Burgess
Post by Stuart Burgess »
'Definitely use a soldering iron for the hole, but I would certainly always first glue on a grommet.
From: fairchildclub@yahoogroups.com [mailto:fairchildclub@yahoogroups.com] On Behalf Of Cy Galley
Sent: 10 March 2011 03:33 PM
Subject: RE: [fairchildclub] Fabric covering Qestion?
Why use a Grommet at all. Melt the hole in your polyesther fabric with a small soldering iron.
www.eaa75.com
From: fairchildclub@yahoogroups.com [mailto:fairchildclub@yahoogroups.com] On Behalf Of DAVID STROUD
Sent: Wednesday, March 09, 2011 9:18 AM
Subject: Re: [fairchildclub] Fabric covering Qestion?
I don't think bulkiness will have much affect on anything. Flat washer type would
work fine too but make sure the hole is right under the lowest aft surface where
moisture could puddle.
David Stroud Ottawa, Canada
Christavia C-FDWS
Fairchild 51 replica
under construction C-FYXV
Sent: Wednesday, March 09, 2011 9:55 AM
Thus far, I have installed only seaplane grommets on the wing (opening to
the rear!). When I posted the question I was referring to washer style drain
grommets. Thanks for the reference. Would you suggest sea grommets on the
control surfaces as well? Or will they be perhaps too bulky?
JP.Lorie
Florida
Sent: Wed, March 9, 2011 9:41:00 AM
Just wondering, JP...if the seaplane grommets are on the bottom and rear of the
surfaces with
the drain hole pointing towards the rear, under what conditions could ram air
enter. If anything I
think it might actually create some suction.
Like Hugh said, check the manual from your supplier.
By the way, AC43.13.1B says ....Install drain grommets on the underside of all
components at
the lowest point in each fabric panel when the aircraft is in stored attitude.
Earlier, it says....
atmospheric temperature changes cause the humidity in the air to condense on the
inside of aircraft
surfaces in all low areas.
Christavia C-FDWS
--- On Tue, 3/8/11, Jp Lorie wrote:
Subject: [fairchildclub] Fabric covering Qestion?
Date: Tuesday, March 8, 2011, 9:28 PM
Hi,
I am trying to finish my long overdue F-24W46. Have installed the fabric and the
wing seaplane grommets on the wings.
The question is should I install drain grommets on the ailerons and elevator or
not? It appears to me that as those control surfaces deflect into the wind air
will be rammed into the drain hole and cause ballooning of the control surface.
As this is new to me, I need your response.
Thank you
JP.Lorie
Florida
Checked by AVG - www.avg.com
Version: 8.5.449 / Virus Database: 271.1.1/3493 - Release Date: 03/09/11
07:25:00
Version: 8.5.449 / Virus Database: 271.1.1/3493 - Release Date: 03/09/11 07:25:00
No virus found in this message.
Version: 10.0.1204 / Virus Database: 1497/3495 - Release Date: 03/09/11
Ashley Messenger
Post by Ashley Messenger »
'Well, because the grommet just looks better, plus they ensure a consistent hole diameter. Done without a grommet, the holes tend to elongate, become oval, and not line up in a good sight line. In addition, cover the grommet with a doily, a nice 2 inch round patch of preshrunk light fabric will hold the grommet in place when the fabric cement eventually becomes brittle and fails. Aluminum grommets are wonderfully thin. We make our doilys with a die-cutter from the scrapbooking store so they are consistent and we can turn out a lot of them quickly.
Ashley Messenger
Sent: Thursday, March 10, 2011 8:32 AM
www.eaa75.com
Christavia C-FDWS
JP.Lorie
Florida
surfaces with
components at
inside of aircraft
Christavia C-FDWS
Hi,
Thank you
JP.Lorie
Florida
07:25:00
Stuart Burgess
'I am with Ashley completely on this one although I don't do that much
covering that I want production quantities. I trace a circle on a piece of
fabric with a circular stencil of the right size and cut it out with pinking
shears. Makes the application of the grommet more secure and it just looks
the business beautifully
On Behalf Of Ashley Messenger
Sent: 10 March 2011 04:05 PM
Ashley Messenger
www.eaa75.com
type would
where
Christavia C-FDWS
drain
JP.Lorie
Florida
of the
surfaces with
air
all
components at
attitude.
on the
inside of aircraft
Christavia C-FDWS
Hi,
and the
elevator or
air
surface.
Thank you
JP.Lorie
Florida
07:25:00
07:25:00
Cy Galley
Post by Cy Galley »
'USE a washer as a template when melting.
Sent: Thursday, March 10, 2011 8:05 AM
Ashley Messenger
www.eaa75.com
type would
where
Christavia C-FDWS
drain
JP.Lorie
Florida
of the
surfaces with
air
all
components at
attitude.
on the
inside of aircraft
Christavia C-FDWS
Hi,
and the
elevator or
air
surface.
Thank you
JP.Lorie
Florida
07:25:00
07:25:00
Hugh Loewenhardt
Post by Hugh Loewenhardt »
'For the prefectionist, it is best to layout round patches (doillies) using a pencil compass divider so one knows exactly where the the center is; or transfer the center mark from a pattern layed out with the pencil compass.
Date: Thursday, March 10, 2011, 2:04 PM
Ashley Messenger
  www.eaa75.com
  Christavia C-FDWS
  JP.Lorie
  Florida
  surfaces with
  components at
  inside of aircraft
  Christavia C-FDWS
  Hi,
  Thank you
  JP.Lorie
  Florida
  07:25:00
Post by Curt Kinchen »
'I particularly like the clean look and simplicity of the melted hole on
control surfaces.
> Ashley Messenger
> From: Cy Galley
> www.eaa75.com
> type would
> where
> Christavia C-FDWS
> From: Jp Lorie
> drain
> JP.Lorie
> Florida
> From: DAVID STROUD
> of the
> surfaces with
> air
> all
> components at
> attitude.
> on the
> inside of aircraft
> Christavia C-FDWS
> --- On Tue, 3/8/11, Jp Lorie > wrote:
> From: Jp Lorie
> Hi,
> and the
> elevator or
> air
> surface.
> Thank you
> JP.Lorie
> Florida
> 07:25:00
> 07:25:00
ptcurt@gmail.com
