Re: Strut packing & jacking the tail
Post by robert Etter »
'I must be having one of those senior moments, I'm not sure what you mean,"upper and lower fairing bulkheads"? I think that the cause of my distractions is going away, or I'm getting used to them.
"donna.e@frontier.com" or 775-482-9243
--- In fairchildclub@yahoogroups.com, "Richard Seifert" wrote:
> Hi Robert
> I need some help on my F24W46. I know you were doing a great job on yours from the pictures you sent me last summer. Do you have any templates or traceings of the upper and lower fairing bulkheads? The Fairchild drawing was superceded by shop templates on these bulkheads and mine were either missing or deteriated beyond use.
> Thanks
> Rich Seifert
> seifertr@...
> 9886 Onyx St.
> Yucaipa, CA. 92399
'Yes, I do. And they are in excess to my needs. Do you, or anyone else out there, know what the composition is the packings are, or know what a suitable substitute might be?
Sorry, for not answering sooner. I have been getting lost within the web page on a regular basis.
--- In fairchildclub@yahoogroups.com, Jp Lorie wrote:
> Bob, do you still have the NOS Strut packing?
>  JP.Lorie
> Florida
> ________________________________
> From: "robertetter@..."
> Sent: Thu, February 3, 2011 4:56:46 PM
> Subject: [fairchildclub] Strut packing & jacking the tail
> I have 2 sets of strut packings.
> I also made a detachable jack pad for the tail of my "24". I need only to draw
> it up, then mail it. My computer isn't up to scanning.
> It will fit between the mounting tabs for the drag link. It is a long "U"
> channel, with a extended pad on the bottom. Than a separate pin will fit through
> the "U" channel, and pinning below the small diagonal tube, just to the rear of
> the attach point.
> Bob
'My phone is 775-482-9243 or Email "donna.e@frontier.com"
>  JP.Lorie
> Florida
> the attach point.
> Bob
James Rice
Post by James Rice »
'Little behind on the email. I am also interest in your tail jacking fixture. Don't want to run up your postage bill.
Any chance you could sent a copy of your drawing to Mike Kelly at the Fairchild Club? Maybe he could
publish it in the newsletter or post it at the Group site.
Jim Rice
Sent: 2/5/2011 7:38:05 PM
Subject: [fairchildclub] Re: Strut packing & jacking the tail
I have the drawing done. What is you mailing address?
--- In fairchildclub@yahoogroups.com, William Creighton wrote:
> Bob,
> I've been traveling, and still haven't worked on my tailwheel problems. Your jacking solution is of great interest.
> Regards,
> Bill C.
> From: robertetter@...
> Date: Thu, 3 Feb 2011 21:56:46 +0000
> I also made a detachable jack pad for the tail of my "24". I need only to draw it up, then mail it. My computer isn't up to scanning.
> It will fit between the mounting tabs for the drag link. It is a long "U" channel, with a extended pad on the bottom. Than a separate pin will fit through the "U" channel, and pinning below the small diagonal tube, just to the rear of the attach point.
> Bob
'If you want, send me your Mailing address to "donna.e@frontier.com" and I will send it to you, or I will send you a "jpg" copy of what I have or both. I am at 775-482-9243 (home) or 702-265-6906 (cell) I don't think that the lower tail end of the fuselage has been altered, and if you have the same fortune, it should work. I built light enough so it wouldn't be a bother to carry it in the baggage compartment all the time. (.3 lbs)
> Jim Rice
> From: Robert Etter
> Bob
> > Bob,
> > Regards,
> > Bill C.
> > From: robertetter@
> > Bob
Jonathan Martin
Post by Jonathan Martin »
'Bob, I would be interested in a jog copy. Thanks! Jon Obliquephoto@Comcast.net.
>Bob
>> Jim Rice
>> From: Robert Etter
>> Bob
>> > Bob,
>> > Regards,
>> > Bill C.
>> > From: robertetter@
>> > Bob
