>If you want, send me your Mailing address to "
donna.e@frontier.com" and I will send it to you, or I will send you a "jpg" copy of what I have or both. I am at 775-482-9243 (home) or 702-265-6906 (cell) I don't think that the lower tail end of the fuselage has been altered, and if you have the same fortune, it should work. I built light enough so it wouldn't be a bother to carry it in the baggage compartment all the time. (.3 lbs)
>Bob
>--- In
fairchildclub@yahoogroups.com, "James Rice" wrote:
>> Little behind on the email. I am also interest in your tail jacking fixture. Don't want to run up your postage bill.
>> Any chance you could sent a copy of your drawing to Mike Kelly at the Fairchild Club? Maybe he could
>> publish it in the newsletter or post it at the Group site.
>> Jim Rice
>> ----- Original Message -----
>> From: Robert Etter
>> To:
>> Sent: 2/5/2011 7:38:05 PM
>> Subject: [fairchildclub] Re: Strut packing & jacking the tail
>> I have the drawing done. What is you mailing address?
>> Bob
>> --- In
fairchildclub@yahoogroups.com, William Creighton wrote:
>> > Bob,
>> > I've been traveling, and still haven't worked on my tailwheel problems. Your jacking solution is of great interest.
>> > Regards,
>> > Bill C.
>> > To:
>> > From: robertetter@
>> > Date: Thu, 3 Feb 2011 21:56:46 +0000
>> > Subject: [fairchildclub] Strut packing & jacking the tail
>> > I have 2 sets of strut packings.
>> > I also made a detachable jack pad for the tail of my "24". I need only to draw it up, then mail it. My computer isn't up to scanning.
>> > It will fit between the mounting tabs for the drag link. It is a long "U" channel, with a extended pad on the bottom. Than a separate pin will fit through the "U" channel, and pinning below the small diagonal tube, just to the rear of the attach point.
>> > Bob
>> > [Non-text portions of this message have been removed]
