Re: F-24 Main strut rebuild
Jp Lorie
Post by Jp Lorie »
'I have removed the main landing gear struts to replace the Universal Joints.
This makes it a good time to overhaul the struts.
Would like input from experienced members on the subject since I know nothing on
the subject.
 JP.Lorie
Florida
Tom_Downey
Post by Tom_Downey »
'The only time the strut needs rebuilding is if it has corrosion.
I totally rebuilt mine, by replacing the tubing that is used as the barrel. making new pistons and inner tubes that form the upper portion of the strut.
It's an easy do..... see my web, @ http://www.whidbey.com/fairchild-nc19143/id20.htm
> the subject.
>  JP.Lorie
> Florida
Tom_Downey
> the subject.
>  JP.Lorie
> Florida
Jp Lorie
Post by Jp Lorie »
'Tom, thank you for the pictures of your restoration they are helpful and
interesting.
?When you replace the Piston tube with a new structural 4130 tube, do you have
to heat treat the finish product?
?what do I use to refill the struts, is it hydraulic fluid like that used in a
tractor or what?
thanks
 JP.Lorie
Florida
Sent: Wed, January 12, 2011 3:48:41 PM
Subject: [fairchildclub] Re: F-24 Main strut rebuild
>on
> the subject.
>  JP.Lorie
> Florida
Tom_Downey
'You can use any fluid that is compatible with the rubber seal at the top of the larger cylinder that holds the Spring. Be sure to note that to help the next A&P to know what to service it with.
I did not heat treat the new tube, after welding it is a good practice to have the assembly normalized to relieve the welding stresses.
Tom, thank you for the pictures of your restoration they are helpful and interesting. When you replace the Piston tube with a new structural 4130 tube, do you have to heat treat the finish product?
what do I use to refill the struts, is it hydraulic fluid like that used in a tractor or what?
thanks
JP.Lorie
Florida'
Tom_Downey
thanks
JP.Lorie
Florida'
