'To new member jeffwhitesell.
These guys have F24 projects for sale. Jeff Reece has a 1937 F24J.
262-985-7061. He lives by Janesville, WI.
Bob Kitsler has a 1946 F24 up by Green Bay,WI. 920-866-2609.
They both have Rangers engines. Some of the work has been done already on both of them. They can give you details.
Keep 'em Flying!
Mike Kelly
Fairchild Club'
Re: Looking for a F24 project.
'Mike thanks for the instant response...I'm kinda keen on a Warner powered version.....tho there are some ranger enthusiasts that say I've lost my marbles if I want a Warner..
> Keep 'em Flying!
> Mike Kelly
> Fairchild Club
'Jeff
N-81318 still exists and the FAA says that it is owned by:
MARTIN D BYRD
1110 MONROE LN
DUNN, NC, 28334-7073
1939 F24-K
Webster, MN
MARTIN D BYRD
1110 MONROE LN
1939 F24-K
Webster, MN
> > Keep 'em Flying!
> > Mike Kelly
> > Fairchild Club
'I'll sell my 37-G
http;//www.whidbey.com/fairchild-nc19143/
the warner is off and needs help. I'm in process of rebuilding it. but will sell as is.
make me an honest offer.
Tom Downey nc19143(at)comcast.net
'Tom:
What happened to your Warner?
David Miller NC22036
To: fairchildclub
Sent: Mon, Dec 20, 2010 2:54 pm
Subject: [fairchildclub] Re: Looking for a F24 project.
I'll sell my 37-G
To: fairchildclub
I'll sell my 37-G
'Low oil pressure, I know the cause and will fix it. 2 new mag gears and accessory case bushings will cure the problem. major cause was a oil feed bushing at the max allowable clearance, crank is standard, and perfect. cylinders were reworked at +10 by Holloway engineering, every thing is ready to go back together when I receive the Parts from Harmon Dickerson. and or John Duncan.
I will sell as is, because I need room in the hangar for other projects.
'--- In fairchildclub@yahoogroups.com, DJetMiller@... wrote:
> Tom:
