Re: Spark plug information
John Ellis
Post by John Ellis »
'Good Evening,
I am using REM-40-E plugs in Ranger Engines. Many years ago, I found a shorter length plug that was the same heat range to go behind the carburetor.. I have forgotten the part number
Does anyone know the part number ..
Thanks for you help..
John
Seifert
Post by Seifert »
'Hi John
I use the BG4B2s Spark Plug for that position. It does have a smaller ignition leed fitting and is shorter than the REM40E plug. Fresno Airparts has them.
To: fairchildclub@yahoogroups.com ; fairchild club
Sent: Saturday, December 18, 2010 7:29 PM
Subject: [fairchildclub] Spark plug information
Good Evening,
John
ccmueller001
Post by ccmueller001 »
'The REM37BY is 3/8" shorter than the 40E and fits nicely behind the Ranger carb. It has exposed electrodes.
Charles
--- In fairchildclub@yahoogroups.com, "John Ellis" wrote:
> Good Evening,
> John
Post by Bob »
'John,
I have never had much trouble with a REM-40-E behind the carburator, although I had heard many people complain about them. I had ALWAYS used Champion plugs. One day I switched brands and found that the plugs were of a different shape, and with the newer plug, I could not get a grip with a wrench.
Before you give up on a REM-40-E, be sure that you at least TRY a Champion plug.
Works for me.
1939 Fairchild 24K
Webster, MN
> Good Evening,
> John
