Re: Warner 165 parts
Tom_Downey
Warner 165 parts
Post by Tom_Downey »
'needed 2 mag drive gears, accessory case bronze bushings for the accessory case, and a standard main bearing. new old stock if possible.'
John Duncan
Post by John Duncan »
'Hello Tom,
If you will provide Warner part numbers, I will see what I have.
Kindest Regards,
JD
Date: Fri, 10 Dec 2010 16:42:23 +0000
Subject: [fairchildclub] Warner 165 parts
Tom_Downey
'Providing numbers may take a while, the print I have isn't that great.
--- In fairchildclub@yahoogroups.com, John Duncan wrote:
> Hello Tom,
> Kindest Regards,
> JD
> From: tom-barb@...
Tom_Downey
'The mag drive gears I need are P/N7858, the bushings I need are 7894 one each, and 7853-1 two ea, and 7853-2 one each. and the main bearing is 8648. plus one oil control ring for a .010 over cylinder.
e-mail nc19143(at)comcast.net with prices and availability please.
> Hello Tom,
> Kindest Regards,
> JD
> From: tom-barb@...
