Re: door handles for 24
FW: F24 question
'Can anyone help Gene out with this question on the trim cables???
Thanks!
Mike Kelly Fairchild Club
To: Hotfoot49@hotmail.com
Subject: F24 question
Date: Wed, 11 Aug 2010 16:26:32 -0500
Hi Mike, I am assembleing a Jacob's F-24, and I have a question about the trim tab cables.
Could you put my question out to those with email. I am refering to the two short 1/16th cables between the two trim tabs. Question; How are they connected? Each one has a swedged loop on the end and one of these was cut, as if they were swedged together ?? I have put another swedge on that one, and I assume that there is to be a bolt or screw to connect them. Can some one please help me?
Gene Morris
genemorris@charter.net
817-491-9110
Thanks!
Gene Morris
817-491-9110
Re: FW: F24 question
'Hi Mike / Gene
The UC-61 parts catalog Figure 21 identifies two turnbuckle barrels at that location. However I don't think the illistration is entirely correct as it only identifies one chain cable and you have two trim tabs. The trim cable system may be different on different models. What model F24 are you working on?
Sent: Wednesday, August 11, 2010 7:16 PM
Subject: [fairchildclub] FW: F24 question
Thanks!
Gene Morris
817-491-9110
door handles for 24
'Hi Everyone
Does anyone have a set of used Door handles for the F24, both inside and outside? Chrome does not have to be perfect.
thanks
Jim Chybicki
UC-61K 43-14964/HB-690
thanks
Jim Chybicki
'I got a new set of keyed hadles from Wag Aero
they fit and work well and look similar to originals, but if you realy want the
originas you can find them at internet sites that specialize in antique car
parts. circa 1939 Plymoth?
JP.Lorie
Sent: Fri, August 13, 2010 5:48:37 PM
Subject: [fairchildclub] door handles for 24
Hi Everyone
thanks
Jim Chybicki
JP.Lorie
Hi Everyone
thanks
Jim Chybicki
'Hi JP
thanks for the info, We already have gone to La baron Bounty(?) We have an original UC-61 and want an old set of handles that we can powder coat to match our camouflage paint scheme.
Thanks again
Jim Chybicki
Thanks again
Jim Chybicki
'--- On Mon, 8/16/10, Jp Lorie wrote:
Subject: Re: [fairchildclub] door handles for 24
Date: Monday, August 16, 2010, 12:42 PM
JP.Lorie
Hi Everyone
thanks
Jim Chybicki
'Look in Hemmings Motor News, available at Barnes and Noble, Borders or online. You will be amazed at what you can find.
Date: Tuesday, August 17, 2010, 10:59 AM
Hi JP
Thanks again
Jim Chybicki
JP.Lorie
Hi Everyone
thanks
Jim Chybicki
'G'day Jim,
A little bit of information which may be of interest to you.Here in Australia I have two Argus', (or is it Argi)both are Argus Is (EV806 and FK330 ,but a friend had an Argus II (HB619) and despite being originally camouflaged all had chromed (almost certainly nickel in reality)door handles. I have a nice wartime colour shot of a US marked UC-61A in which its possible to see that the door handle appears to be plated but is definitely not coloured to match the camo.If you have a look in the 1945-46 Jane's all the Worlds Aircraft there are photos of both a UC-61A and a UC-61K (US marked)and in both photos the door handle can clearly be seen which would not be the case if they were painted to match the door colour.As the RAF aircraft were painted before delivery it seem logical that the factory followed the same principles when painting them as they did with the US marked aircraft.
It would be silly to be adament about any such issues, particularly the way wartime aircraft were painted, but personally think it more than likely that the handles were not painted.
John Gallagher
join
John Gallagher
join
'--- In fairchildclub@yahoogroups.com, james chybicki wrote:
> Hi JP
> thanks for the info, We already have gone to La baron Bounty(?)Â We have an original UC-61 and want an old set of handles that we can powder coat to match our camouflage paint scheme.
> Thanks again
> Jim Chybicki
> From: Jp Lorie
> Â
> IÂ got a new set of keyed hadles from Wag Aero
> parts. circa 1939Â Plymoth?
> Â JP.Lorie
> From: james chybicki
> Â
> Hi Everyone
> thanks
> Jim Chybicki
> Â
'Hi John
or is it Good Day' Thank you so much for your insite. My partner and I will take it under consideration. Can you forward me any pictures of the UC-61 /Argus you have, including your plane.
Cheers
Keep 'Em Flying
Cheers
Keep 'Em Flying
'--- On Wed, 8/18/10, wackett129 wrote:
Subject: [fairchildclub] Re: door handles for 24
Date: Wednesday, August 18, 2010, 5:19 PM
G'day Jim,
John Gallagher
join
> Hi JP
> Thanks again
> Jim Chybicki
> From: Jp Lorie
> Â
> Â JP.Lorie
> Â
> Hi Everyone
> thanks
> Jim Chybicki
> Â
'John
Thought you might like to know I've just found one of your Fairchild's (FK330) in the logbook of an ATA pilot, Daphne Rumball, whilst it was at RAF Thame. See my website http://www.haddenhamairfieldhistory.co.uk/Daphne%20Rumball.pdf
and go to page 3 of the pdf document.
There are several other Argus' in this and the other two pilots logbooks so members might like to have a look for their particular examples.
Sorry no photos as I am trying to stick exclusively to photos taken on the airfield and they are as rare as hens teeth.
Peter Chamberlain
Peter Chamberlain
'--- In fairchildclub@yahoogroups.com, "wackett129" wrote:
> G'day Jim,
> John Gallagher
'Hello Peter
Can You check your information logs for any record of Argus III HB-690. It arrived in England aboard the USS Samwater in Sept. 1944 and was assigned to ATA Pool.
I would like to find some more data on our plane. HB-690 is currently being restored to flying condition just outside Chicago.
thanks/Cheers
Jim Chybicki
Bob Coon
Argus III / HB-690
USAAF 43-14964
thanks/Cheers
Jim Chybicki
Bob Coon
Argus III / HB-690
USAAF 43-14964
Date: Thursday, August 26, 2010, 2:36 PM
John
Peter Chamberlain
> G'day Jim,
> John Gallagher
