'Is anyone using A Falin prop on a PT and how did you handle the paper work ?
Virgil Thovson N26PT'
Re: Falin Prop on a PT
'Refer to the Type Certificate Data Sheet A-724 for the propeller limitations. This is FAA approved data you can use for your 337 (if you need to do one).
Sent: Monday, July 13, 2009 1:54:51 PM
Subject: [fairchildclub] Falin Prop on a PT
