'Hi all,
This weekend I'm going to start covering the fuselage of an F-24. I have plenty experience covering wings, rudders, ailerons etc., but this is my first fuselage. Any tips will be greatly appreciated.
But I do have a question. Should I dry fit the envelope first, remove it and then prep the airframe (epoxy, poly-brush) or is it best to prep first and then fit the envelope just the one time?
George Sands
Re: Fuselage covering
David Stroud
'Giday, George. Do it the All American way. Follow the instructions of your covering
supplier and no one else. That way if anything goes wrong you can sue them and
the lawyers won't have to far to go.
Christavia C-FDWS
Fairchild 51 replica
under construction C-FYXV
Christavia C-FDWS
Sent: Friday, May 08, 2009 7:33 PM
Subject: [fairchildclub] Fuselage covering
Hi all,
George Sands
Checked by AVG - www.avg.com
Version: 8.0.238 / Virus Database: 270.12.21/2104 - Release Date: 05/08/09 06:34:00
Jay Thomson
'I too have done a lot of covering. If I were doing that job I would prep the airframe first then put the covering on only one time. However, I would NOT cover the airframe with an envelope, specially if you want a nice professional looking job with straight seams. That's just me, hope I didn't offend you! ;>)
'--- On Fri, 5/8/09, DAVID STROUD wrote:
Subject: Re: [fairchildclub] Fuselage covering
Date: Friday, May 8, 2009, 7:32 PM
the lawyers won't have to far to go.![]()
Christavia C-FDWS
Hi all,
George Sands
'Have fun. All that I can say is to take a really good look at the fuselage and try to catch the things that you have forgotten.
If you have stringers that don't have an even progression/spread, believe me, you will hate yourself for not catching it before you covered them. I reinforced curvature of the top center stringer, just above the rear hat spar carry-thru. All too many time, I've seen a knot where it has cracked. Where fabric contacts metal, I used epoxy primer, I didn't see any problems otherwise. All of the wood/balsa had a couple of good coat of varnish. I would go into fabric, but I am really old school in many ways. I went with Grade A.
Robert Etter
PO Box 974
Tonopah, NV
89049
Tele. 775.482.6820
Cell 702.265.6906
Robert Etter
PO Box 974
Tonopah, NV
89049
Tele. 775.482.6820
Cell 702.265.6906
Sent: Friday, May 08, 2009 4:33 PM
Hi all,
George Sands
George Sands
'No offense taken. The envelope was provided, my preference would have been blankets.
Date: Friday, May 8, 2009, 8:59 PM
Christavia C-FDWS
Hi all,
George Sands
George Sands
'Bob,
Thanks. As I'm prepping I'll keep an eye out for that.
Date: Saturday, May 9, 2009, 9:01 AM
If you have stringers that don't have an even progression/ spread, believe me, you will hate yourself for not catching it before you covered them. I reinforced curvature of the top center stringer, just above the rear hat spar carry-thru. All too many time, I've seen a knot where it has cracked. Where fabric contacts metal, I used epoxy primer, I didn't see any problems otherwise. All of the wood/balsa had a couple of good coat of varnish. I would go into fabric, but I am really old school in many ways. I went with Grade A.
Robert Etter
PO Box 974
Tonopah, NV
89049
Tele. 775.482.6820
Cell 702.265.6906
Hi all,
George Sands
David Stroud
'While prepping, you can stretch a few wraps of plastic wrap or something similar to test
your fairing/ smoothness of convex or concave shapes etc. Something that is not obvious
to your eye with a naked fuselage can be easily detected with some temporary wraps and
a second or third set of eyes from different angles can be a big help. You've invested a lot
already....don't skimp on the last minute stuff....one little bump overlooked will last you a
lifetime.
Christavia C-FDWS
lifetime.
Christavia C-FDWS
Sent: Saturday, May 09, 2009 8:21 PM
Bob,
Robert Etter
PO Box 974
Tonopah, NV
89049
Tele. 775.482.6820
Cell 702.265.6906
Hi all,
George Sands
Version: 8.0.238 / Virus Database: 270.12.23/2106 - Release Date: 05/09/09 06:54:00
George Sands
'David,
Thanks.
Thanks.
Date: Saturday, May 9, 2009, 5:28 PM
already....don' t skimp on the last minute stuff....one little bump overlooked will last you a
lifetime.
Christavia C-FDWS
Bob,
Robert Etter
PO Box 974
Tonopah, NV
89049
Tele. 775.482.6820
Cell 702.265.6906
Hi all,
George Sands
